Skymaster Wheel Leaking
My Feedback: (27)
GA
I have a set of L39 tires that both leak around the junction of the tire and the rim.
Before I start taking things apart, I would like to get some input from any of you that have had this problem and know the fix.
My Feedback: (60)
Hi Keith. I had that problem with my Skymaster F-15. I pulled the wheels off, cleaned everything very well and re-installed. There was some sort of leak between the brake and wheel hub but once cleaned it work perfect...again. Do you mean the actual tire is leaking air?
SM
SM
My Feedback: (27)
GA
ORIGINAL: smaze17
SM
SM
Sounds like I will need to take them apart tonight.
Anyone ever filled them with the expanding foam to get away from the leak problem?
My Feedback: (16)
Keith,
The Skymaster wheels have an O ring in a shallow groove that seals the 2 wheel halves. If the wheel has ever been pulled apart to release air, there is a good possibility that during re-assembly the O ring was not seated in the groove and was pinched. It doesn't take much to damage the O rings to the point where there will be an air leak. I do not know the wheel size that you're working with but the O ring size for the F-4 is 1mm x 50mm.
Hello Keith:
If the leaking is from the junction of the tire and the rim, the problem must be caused by damaged tire rubber, tiny pin hole or small crack are exist in this area and cause leaking. Changing new tires will solve the problem.
If you can see bubbles from nipple in water, the leaking is from the 42mmX3.5mm O-ring which acts as a check-valve. Taking it out and lubricating by thick silicon oil and assembling it again will solve the problem.
The 50mmX1mm O-ring is just for sealing two half of rims, it is only functional when you are inflating the tire, so it will not cause tire leaking.
Please send me your address for sending new tires to you.
Best regards
Best regards
My Feedback: (10)
NV
I just want to say that as a Sky Master customer (MB339) their customer service is excellent. I had an issue with the canopy glass on my kit, which I purchased two years ago and only recently finished building...I made a post about my issue and before I could even contact them a new canopy was on the way, no charge to me.
Here you make a post about leaking tires and asking for solutions and Sky Master sees the post and is sending you new tires no questions asked.
That is service. They will get more of my business that is for sure!
Good luck with the tires, in the end I am sure it will get resolved.
My Feedback: (27)
GA
ORIGINAL: Likai
Hello Keith:
Best regards
Hello Keith:
Best regards
My Feedback: (27)
GA
ORIGINAL: InboundLZ
My Feedback: (16)
ORIGINAL: Likai
Hello Keith:
Best regards
Hello Keith:
Best regards
Would Skymaster consider abandoning the air filled tire on the F-4 and producing a solid tire? The problem is that when inflated to 40 lbs., the tire diameter grows to a size that will not clear the wing root and go into the wheel well. When the tire is inflated to a diameter that it will enter the wheel well, apx. 22 lbs., then the tire is not rigid with the weight of the jet on it. This makes for a longer take off roll and flexing of the tire sidewalls.
Thanks for considering this change.
My Feedback: (24)
ORIGINAL: f106jax
Hello Likai,
Hello Likai,
I simple, hard, solid tire seems to be a much better solution IMHO...
Bob
ORIGINAL: Likai
Hello Keith:
Best regards
Hello Keith:
Best regards
Hope all is well with you. I'm curious to find out how long the wheels that ship with the Big F-16 can hold air for. Mine loses all air after sitting in a box for a month or two. Is this normal? The wheels have never been used. If it is a problem, can I send them in for a replacement?
Thanks.
