Reload this Page >
Tomahawk-Design Bae Hawk 1: 3.5
Old 10-18-2012, 02:48 AM
  #676
heraldoboldrin
Default RE: Tomahawk-Design Bae Hawk 1: 3.5
Marcs
what is the difference from you tank from the original?
Heraldo
Old 10-18-2012, 03:13 AM
  #677
schroedm
schroedm's Avatar
ORIGINAL: heraldoboldrin
Marcs
Heraldo
Difference is Marc's aren't available now
Seriously though, Marc's tank is a large rectangular 6L tank designed to fit high up in the fuselage above the wheel wells using the provided CNC formers. This helps free up space lower in the fuselage for equipment etc. As Marc says, it's only up high as it was a scaled up design from the SG Hawk where a full ducting system was designed and thus the tank had to be moved. There is no ducting set for the TH Hawk but it was an easy task to scale up the formers and still use the tank in the upper position.
Old 10-18-2012, 03:39 AM
  #678
Carsten Groen
Carsten Groen's Avatar
And it makes a nice place to mount your turbine electronics, and the space between the wheels can be used for the radio equipment
Marc, stop fooling around with the bikes and design some more clever stuff for us
Old 10-21-2012, 10:23 AM
  #679
Alpenglider
Alpenglider's Avatar
Hi Guys,
here i would like to post some pictures of my progress!
Slowly, but step by step
Cheers
Thomas
ID:	1813420   Click image for larger version
ID:	1813421   Click image for larger version
ID:	1813422   Click image for larger version
ID:	1813423   Click image for larger version
ID:	1813424   Click image for larger version
ID:	1813425   Click image for larger version
Old 10-21-2012, 12:15 PM
  #680
tobba
Nice work Thomas!
Old 10-22-2012, 11:31 AM
  #681
Alpenglider
Hi all Hawk builders!
I would like to order my servo arms from secraft for my Hawk. Can someone tell me which lengthes i will need for the elevator, rudder, aileron and flaps?
Cheers
Thomas
Old 10-22-2012, 06:58 PM
  #682
heraldoboldrin
I am having problem with the cd that came with the kit.. to help a litle the construction.. can any one send me the files..
[email protected]
regards
Old 10-22-2012, 09:14 PM
  #683
Alpenglider
Hello Heraldo!
Whats the problem?
On this CD there a basicly files with pictures;
you should be able to open these!?
But anyway, i will sent these files to you by mail when i get home after work ok!
Cheers
Thomas
Old 10-23-2012, 02:13 AM
  #684
heraldoboldrin
Hi Thomas
The problem isn't with the files.. the CD was perfect before my sister's dog try to it the CD..(rsrsrsrs)
regards
Heraldo
Old 10-23-2012, 03:24 AM
  #685
Alpenglider
.... You better feed a bone ;-)
Will sent tonight ok!
Cheers
Thomas
Old 10-23-2012, 09:24 AM
  #686
Alpenglider
Hi Heraldo,
all files sent one by one!
Hope your email account can take that big data?
Cheers
Thomas
Old 10-23-2012, 09:30 AM
  #687
heraldoboldrin
Thomas i receive 12 emails.
Subject:
- pictures
- files 2
- files 3
- files 4
- files 5
- files 6
- files 7
- files 8
- files 9
- files 10
- files 11
- files 12
regards
Heraldo
Old 10-23-2012, 09:43 AM
  #688
Alpenglider
Hi Heraldo,
thats it!
Can you open them? Everything fine?
Cheers
Thomas
Old 10-23-2012, 11:27 AM
  #689
heraldoboldrin
Yes.. everything ok
Thanks.
Old 11-25-2012, 12:29 AM
  #690
reas
Hello Guys
I'am Andreas from Germany and its my first post on rcuniverse.
I fly the Tomahawk hawk about one year and its the best jetplane i've ever had.
The Engine is an IQ Hammer 180+ and the hawk weights 24,6kg with 5 litres fuel in it.
So there i have some pictures of my hawk.
Greats andreas
ID:	1823559   Click image for larger version
ID:	1823560   Click image for larger version
ID:	1823561   Click image for larger version
Old 11-26-2012, 04:59 PM
  #691
u2fast
My Feedback: (37)
have any of you guys experienced the inlet ducts cracking from pressure. my ducts started cracking and ripping with around 20 flights on the jet. i fly with a behotec 180, so she isnt to fast or flown hard. i ordered a new set and added a layer of 1oz cloth to the inlets. not much extra weight, but i will never have to remove them again to fix this issue. barry
here is a pic of one of the cracked inlets and pics of the new inlets.
ID:	1823793   Click image for larger version
ID:	1823794   Click image for larger version
ID:	1823795   Click image for larger version
ID:	1823796   Click image for larger version
Old 11-26-2012, 05:02 PM
  #692
tobba
Cheers Barry - will add some to mine and maybe some carbon tow.
Old 11-26-2012, 05:33 PM
  #693
jetpilot
My Feedback: (48)
jetpilot's Avatar
I glassed mine as well. paper thin.
Scott
Old 11-26-2012, 07:12 PM
  #694
roydefiant
very nice Andreas. I hope to have mine flying in the spring.
Roy
Old 11-26-2012, 07:20 PM
  #695
tobba
Front small door is done - rather tricky but happy. Not 100% scale but OK from a few feet.
ID:	1823897   Click image for larger version
ID:	1823898   Click image for larger version
ID:	1823899   Click image for larger version
Old 12-02-2012, 08:26 AM
  #696
Alpenglider
Hi Toba,
good work as usual, hands up!!
I realized some progress on my hawk too, please see pictures:
Cheers
Thomas
ID:	1825705   Click image for larger version
ID:	1825706   Click image for larger version
ID:	1825707   Click image for larger version
ID:	1825708   Click image for larger version
Old 12-02-2012, 10:19 AM
  #697
tobba
Looks great Thomas - great work.
I test flew my 1.9 Futura on the weekend - 5 great flights. Now the focus can get back on the Hawk!
Seen your gear yet? I havent heard back from PC as yet.
Old 12-03-2012, 12:02 AM
  #698
Alpenglider
Hi Tobba,
thank you for your kind words!
But my building skills are way less good then yours or of some other modelers here.
But thats OK, i do not want to compete or compare my models with others. My goal is to do a good job and have
a functional and good looking plane from in and outside.
Peter just droped me a email saying my gear will be shipped next 2-3 days. It took a bit longer as he had a new idea
on the Breaks which he wanted to realize on my gear as first (yours aswell).
So i should have something laying under my christmas tree lol
Great you maidened your Futura, i loved mine a lot. To bad u sold it on, but maybe who knows? I get the laeger one for christmas too??
Keep fingers crossed my friend!
Cheers
Thomas
Old 12-03-2012, 11:25 AM
  #699
tobba
Hey Thomas,
New brake tech sounds interesting - I'll drop him an email today for an update.
I'm thinking the Futura will be the perfect stick warmer before the Hawk test flight - it was nice and relaxing to fly. Mine flew with a bit of a nose up attitude and climbed into wind so I think I have a CG issue to sort out but other than that pretty good.
Cheers
Old 12-03-2012, 11:50 AM
  #700
Alpenglider
Hi Tobba,
i think i had my CG on my small Futura just at the end of the wing tube and the plane was still a tad nose heavy!
For landing i used a crow set up, the Futura came in with that just nicely.
The crow throws i have used:
Flaps down as per manual
Ailerons up about 1cm mesured on the deepest point next to the flaps
Elevator down about the thicknes of the elevator rudder end (dont know the english name of it?)
Cheers
Thomas
PS: I just missed a large Futura kit on ebay by lousy 10,- Euros [&o][&o][&o]
But got myself a new Turbine for a bargain price So a kit needs to follow too
