Reload this Page >
BVM T-33 Build
BVM T-33 Build
Old 05-15-2013, 08:41 AM
  #76
JDjetjock
JDjetjock's Avatar
Default RE: BVM T-33 Build
ORIGINAL: sideshow
Has anyone bought the composite wings? I'm looking at either getting the new wings or modifying what I have. The last time I called BVM they didn't have a price. Any info on price or how they fit would be appreciated.
Since my post above, my T-33 experienced some non-destructive outer wing LCO flutter at approx 120 mph. The wings are old vintage with balsa skins. It caught me off guard as it was a medium speed pass, but the flutter commenced after I initiated a slight bank...meaning the aileron stimulated the wing flutter at that speed. I immediately landed without incident and there was no apparent damage to the wing, and the wing stiffness felt to be unreduced. However, the classic T-33 wing is not very stiff in torsion, say compared to a Composite Bandit wing, and has tip tanks at the tips to keep aligned against the aero forces. I have since improved the torsional stiffness of the wings with adding 2oz fiberglass cloth over the outer skins with the grain of cloth on 45 deg to the span. After finishing, this added approx 3 oz in weight to each wing, but has significantly increased the stiffness. Also, the wing tubes were a little sloppy in their housings, which could have also contributed to the problem. After speaking with Bob V, he wanted me to buy new wings and to paint the wing tubes with primer to slightly increase the diameter to remove the slop.
All this work is done (added 2 oz cloth and eliminated slop with the tubes), but I haven't flight tested it yet. I will let you know how it works out.
Cheers,
Old 05-15-2013, 03:03 PM
  #77
sideshow
sideshow's Avatar
OROGINAL: JDjetjock
Looking forward to hearing about it.
ORIGINAL: JackD
I havent started the build (finishing other project right now) but I soon as I start, we should compare notes
Later
jack
Sounds great Jack. My kit has the old plastic retracts which I'm going to replace with the new purple ones. I was going to put a solid carbon spar attached to the wing tube in. Looking forward to hearing about your method.
Old 05-15-2013, 04:33 PM
  #78
JackD
JackD's Avatar
ORIGINAL: sideshow
Agree on the landing gear. worth the splurge.
Tell me about the carbon spar. Where are you putting it? One of the issues to solve is that the tube can come loose inside the wing. SO that is why I want to "sandwich" the tube with the 2 balsa/carbon stringers on top and bottom. that will create a more solid continuity between the wingtube and the wing.
And i meant using 2oz cloth, not 1.5Oz (i dont even think that exists...)
Old 05-15-2013, 04:52 PM
  #79
AndyAndrews
AndyAndrews's Avatar
I still love mine. I put Glennis wheels on it last year. P80 though.
ID:	1882283   Click image for larger version
Old 05-15-2013, 04:57 PM
  #80
hooker53
My Feedback: (106)
Jack. Sounds like you have a good plan for that wing. Hope we can talk you into to photos as you do that carbon upgrade. I will need to do it to mine this winter when I build it and think I have about the same vintage kit you do.
Old 05-15-2013, 06:29 PM
  #81
Kelly Rohrbach
You may want to double check the main wing spar center section. The wing flutter could have started there. Remember, that vintage of kit was designed well before the first turbine jet flew. The main wing spar if I remember has an open hoop design that went around the ducted fan but was left open on the upper half. Like on the F-16 BVM put a hoop section on the top of the spar to complete the hoop so to speak. Picture a horse shoe upside down, there would be a carbon former made to connect the two open ends of the shoe. This will greatly reduce the amount of wing flex.
Old 05-15-2013, 06:47 PM
  #82
sideshow
sideshow's Avatar
ORIGINAL: JackD
Tell me about the carbon spar. Where are you putting it? One of the issues to solve is that the tube can come loose inside the wing. SO that is why I want to ''sandwich'' the tube with the 2 balsa/carbon stringers on top and bottom. that will create a more solid continuity between the wingtube and the wing.
I was thinking along similar lines as you. I was thinking I'd take a strip of sheeting and foam off both top and bottom on the same line as the wing tube. Then take a solid piece of flat carbon rod and epoxy it to the wing tube and the foam most of the way to the wing tip, then cap and finish. That wouldn't really help with twisting though...
Old 05-16-2013, 03:39 PM
  #83
JDjetjock
JDjetjock's Avatar
ORIGINAL: Kelly Rohrbach
Hi Kelly,
Good idea...I'll double check the centre section. I do know that it was originally a BVM configured one for a JPX turbine and has the carry through structure in the upper fuse, but will check it anyway. Thanks.
Old 05-17-2013, 03:27 PM
  #84
AVIOJET
AVIOJET's Avatar
You are refering to this one? I built this T-33 for a customer more than 10 years ago. He flew it with a P-60 and no issues with flutter.
BR
Jesus A. Serrano
ID:	1882706   Click image for larger version
Old 05-17-2013, 03:29 PM
  #85
Kelly Rohrbach
Yes
Old 05-17-2013, 10:58 PM
  #86
argyris
argyris's Avatar
ORIGINAL: AVIOJET
BR
Jesus A. Serrano
Mr Serrano how it flew with P-60?how much was the total weight dry and wet?Thank you!!
Old 05-19-2013, 03:12 PM
  #87
AVIOJET
AVIOJET's Avatar
ORIGINAL: argyris
ORIGINAL: AVIOJET
BR
Jesus A. Serrano
It flew very well at scale speed. The P-60 is enough for this aircraft. The final weight was 8.5 Kg, i.e. 19 pounds dry. Sorry, I don´t weighed it wet
Till to day has loged more than 60 flights performing all kind of aerobatics and no issues. Tomorrow I will attach some pics
Old 06-17-2013, 07:01 AM
  #88
JDjetjock
JDjetjock's Avatar
ORIGINAL: JDjetjock
ORIGINAL: sideshow
Cheers,
Hi all, I just flight tested (5 flights) the jet and the wing is solid. I did not encounter any trim changes or bad wing/tiptank behaviour with increasing speed, even beyond 160 mph. I had inspected the carry-through structure in the fuselage and it was sound. However, inspecting the tip tanks revealed the fin on the LH tiptank was more fexible to flap up and down more than the RH tank. So, I removed the fin assembly from the tank. I thought the internal carry-through structure in the tank may have been broken, but it wasn't. So, I added 1/64 ply on top of the poly-ply carry-through and this greatly improved the flapping resistance of the fin. In restrospect, this may have been a major contributor to the previous flight's flutter event of the LH wing as the tip tank fin can behave as a lever arm on the tank and outer wing section.
So, all is to say, that after adding 2oz glass cloth over the outer wing skins (on the 45), removing the wing tube slop, and reinforcing the tip tank fin assemblies, my 17 year old BVM T-33 flies great over a wide speed range.
All the best,
Old 06-17-2013, 11:11 AM
  #89
Harley Condra
Here's the fix that BV gave me for my very old ex-ducted fan T-33.
The attached photo shows the position of the full depth 1/8" plywood spars.
The wing is much stiffer now, and the weight gain was minimal.
One Saturday I took my T-33 over to the shop, as BV had been asking about it. It was almost ready for paint, and any modification that I needed to make to the wings wouldn't be a problem.
He had suspected that the wings were probably too weak for a turbine conversion, and he was correct.
I added these spars in the locations BV determined. They are full depth, and rest on the upper wing skin inner surface, and the forward face of the aft spar socket.
The blue tape shows the position of the new spars, and the dimensions are shown. The wings have a base coat of white paint, in preparation for the yellow color to follow.
The forward spar should fit snugly between the root rib and the servo box liner.
Old 10-25-2014, 09:22 AM
  #90
ole.foll
I just bought a key-ready BVM T33 few days ago. The airplane looks very good, and it's very nicely built. Its powered by a jetcat p80se with kerostart. Im very exited Its built from a old kit with glassed balsacovered wings. Seems like the wing is very strong, but i still have som conserns by reading about some issues on this thread. The airplane has flaps and airbrake and the wing has the scale underchamber. Do i need to fill this or does it preform well as it is? I know it flies well at high speeds, but i heard problems may occur at low speed and its easily bounce when it touch the ground. What do u guys think, do i need to modify?
ID:	2042116   Click image for larger version
ID:	2042117   Click image for larger version
ID:	2042118   Click image for larger version
ID:	2042119   Click image for larger version
ID:	2042120   Click image for larger version
ID:	2042121   Click image for larger version
Old 10-25-2014, 09:34 AM
  #91
Gazzer
Gazzer's Avatar
I tell you what I think..... I wish I had bought it, looks fantastic!!!
Old 10-25-2014, 09:58 AM
  #92
ole.foll
Yes, it really is This is my first turbine model so im very exited about it. Hope it preform as good as it looks I guess 10kgs thrust is a bit too much for this aircraft but we'l see..
Old 10-25-2014, 03:24 PM
  #93
Vincent
My Feedback: (61)
Vincent's Avatar
Ole
This is not really a good "first" turbine jet imo. Pull the motor and find a nice sport jet to fly and enjoy, come back to the tbird later after you have taken some lumps with the sport jet.
Vin...
Old 10-25-2014, 05:24 PM
  #94
JDjetjock
JDjetjock's Avatar
I've owned and flown a couple older BVM T-33s and had much success. To ensure success, I recommend the following:
- fill in the undercamber as described on the BVM website.
- incorporate crow on the ailerons (I deflect approx 1/4" to 3/8" up). The wing tends to tip stall, so adding crow is like adding washout to delay tip stalling.
- ensure no slop on the aluminum wing tubes (build up tubes with primer until nice fit). Otherwise you may have trim changes in flight.
- do not move CofG behind what is recommended. It tends to be very pitch sensitive on landing.
- replace the landing gear with the new mounts and purple gear (see BVM web site for mod kit). Any side loading on your old gear will break the mechanisms, and the turbine T-33 is much heavier than this version.
- do not fly with more than 30 deg crosswinds
- check if the oleos bottom out with a full fuel load. If so, BVM can provide additional springs to raise the jet up. Mine had this problem.
It's a beautiful flying aircraft.
Cheers,
Old 10-26-2014, 04:36 AM
  #95
ole.foll
Cheers,
Thank you for the good advises. The oleo legs bottom out very easily, so i have to add additional springs to raise it up as u says. I hope this undercarriage is strong enough. Its too expensive to buy the new purple one. My plan was to fly it with the orginal underchamber first for testing, but maybe its best to fill the underchamber in advanced. Adding washout to the ailerons sounds like a good idea. I will do that Is there anything else i should be aware of? What do u recommand for servo throw on the rudder, ailerons, elevator, airbrake? Do i need to add expo?
Old 10-26-2014, 07:35 AM
  #96
hoser
hoser's Avatar
i just got one as well, did not get the tank winglets and thought leaving them off would be better. thanks for the advise on the crow programing JD since im going EVF it will be a lot lighter so I'll do Harley's mod but avoid the 2oz top and bottom and just do bottom after the spars are in
Old 10-26-2014, 09:52 AM
  #97
JDjetjock
JDjetjock's Avatar
BVM's CofG and control throws are in his website: http://www.bvmjets.com/Pages/CG.htm.
For expo, that's a pilot preference. For jets with a large speed range I use considerable expo (up to 60%) as I prefer not to be constantly changing rates by switches.
For the crow settings, I meant to also say that this is recommended when full flaps are deployed.
Cheers,
Old 10-27-2014, 06:13 AM
  #98
ole.foll
Cheers,
Thank you very much Here is a few pictures of the retract mecanism in my tbird. Does'nt look very solid to me, so i dont know if this is strong enough?, Maybe its for the best to buy the new purple retracts from BVM even if i hope not to spend more money on this aircraft. What do u guys think? Is this the first generation bvm retracts?
ID:	2042507   Click image for larger version
ID:	2042508   Click image for larger version
ID:	2042509   Click image for larger version
ID:	2042510   Click image for larger version
ID:	2042511   Click image for larger version
ID:	2042512   Click image for larger version
ID:	2042513   Click image for larger version
Old 10-27-2014, 08:05 AM
  #99
Ron Stahl
My Feedback: (12)
Those are first gen retracts. I would bite the bullet and get the newest versions and have peace of mind when I'm coming in for that first landing. Also do be sure to do the undercamber fill-in mod or you'll be sorry.
Old 10-27-2014, 08:25 AM
  #100
ole.foll
Yepp, thats what i thought. Im afraid its another 500$ for the retracts and the carbon mounts, but this model deserves it. It is in perfect condition and have never been flown yet. I hope i can use the legs and break system as it is. Im gonna make sure everything is perfect before the first flite. I will also fill the underchamber. What servos do u recommand ? Mine has jr8411 servoes on the elevator, ailrons, rudders and flaps. 13kgs tourqe at 6v. Hope this is enough. I consider to change the elevator and rudder to Hitec 7955 servos (tourqe 24kg) but i dont now if its necesarry.
