KingTech K-80
#776
My Feedback: (21)
RE: KingTech K-80
Tip
You can go to the 3 cell LiFe. Barry has recommended that earlier in this thread.
As far as the fuel ramp I would just reduce it by 1 or 2 points to start. If you stay with the 2 cell lipo. I have a K140F on a 2 cell 3000mHa and do not get any flames on start up.
I can't answer on the warranty but I am Sure that Barry or Dirk From www.Kingtechusa.com will chime in.
Joe Lewis
Kingtech
K-80 and K-140
Owner
Joe Lewis
Kingtech
K-80 and K-140
Owner
#777
My Feedback: (24)
RE: KingTech K-80
DO NOT ever put any oil on the starters Bendix clutch!!! This is not advised; Oil will collect dust and cause the bendix to hang. Check to make sure the starter housing is straight to the shaft nut (Sometimes they get pushed slightly to one side or the other in shipping). Is the starter housing touching anything? The noise sounds like the starter is vibrating against something.
Changed the batt to the 3 cell LiFe and the flames should go away as well....
#778
RE: KingTech K-80
ORIGINAL: Tip22v
I'm using a 2 cell lipo, but I have a 3 cell LiFe. Should I use the 3 cell?
If I remove the starter motor to oil the sprag clutch do I void the warranty?
How much should I reduce the fuel ramp?
Thanks for the help.
No, the warranty would not be voided, but you shouldn't have to because they do come lightly oiled already. What I would also suggest is to go to the INFO menu and "test starter" to see if clutch would engage and disengage with authority. If it pops off immediately and positively as you press the button, than it is fine, but if it rotor has slow down a bit than it releases with hesitation, than most likely like Todd suggested an alignment issue due to shipping, which could be easily adjusted.
The Fuel Ramp Joe mentioned is the second parameter under "start"
Give me a call if anything,
Regards,
Barry
#779
RE: KingTech K-80
Thanks, I will switch out the 2 cell LiPo and use a 3 cell LiFe. I will also try the test starter function, I remember seeing that when going through the menus on the FADEC. I remember opening the box when I first got my Kingtech and thinking it was not very well packed, and the starter motor looked a little off center, I centered the best I could. Any suggestions for how to adjust the centering if the starter motor? The starter housing is not near anything so it cannot be vibrating against anything.
Tom
Tom
#780
AL
RE: KingTech K-80
ORIGINAL: marquisvns
Like Todd suggested 3S LiFe will help much of the problem on starting, much much more user friendly, and you get to fly more per charge.
No, the warranty would not be voided, but you shouldn't have to because they do come lightly oiled already. What I would also suggest is to go to the INFO menu and ''test starter'' to see if clutch would engage and disengage with authority. If it pops off immediately and positively as you press the button, than it is fine, but if it rotor has slow down a bit than it releases with hesitation, than most likely like Todd suggested an alignment issue due to shipping, which could be easily adjusted.
The Fuel Ramp Joe mentioned is the second parameter under ''start''
Regards,
Barry
Regards,
Barry
Barry,
I maiden ed my K-80F today and I was the hit of the meet. With 3 to 4 foot flames on EVERY start marshmellows were flash fried in seconds. I thought it would get better but only got worse. I even made sure to top off my 9.9v life. Diesel with 5% of your oil toasted every time. Starts took a very long time and most time raw fuel would be pouring out the exhaust on light off. It's a Da** good thing I had a flame tube, otherwise I would have returned home with ashes. Check out the attached picture.
I have not pulled the data off of the Fadec with my laptop of yet, but I will and send you the info if it will help.
KingTech Kero start HAS to do better than this, and I hope it does.
Mike in AL
#781
My Feedback: (8)
RE: KingTech K-80
Tip22v's K-80 Throws about the same amount of flame, just not every time. His was the first Kingtech I have seen. It didn't seem to take too long to settle into "running" mode. Once running it behaved perfectly. I was very satisfied with the throttle response in flight, small adjustments during the landing approach got immediate results. I flew it twice and both times it was flawless. The engine is a bit heavy and bulky compared to my Rabbit, but when one considers that the K-80 was Kingtech's first offering, I would call it nothing less than a total success. The price is simply a generous bonus. I'm impressed. If Kingtech's have a fault, it's the fact that while they are "plug and play" out of the box, the settings in the ECU are not as highly refined as some of the more established brands of turbines. Choosing to go with Gaspar's wonderful Xicoy ECU was a very shrewd move and no small part of their success. I think Kingtech is well on their way to becoming a major player in the turbine business.
#782
RE: KingTech K-80
I ran the starter in "test" mode and the clutch sounded like it was disengaging positively. I turned the fuel ramp back by one, will see how it does tomorrow.
#783
RE: KingTech K-80
ORIGINAL: dmscpu
Barry,
Mike in AL
Regards,
Barry
Regards,
Barry
Barry,
Mike in AL
Barry
#784
AL
RE: KingTech K-80
ORIGINAL: dmscpu
Hey Mike, obviously it was too rich most likely during the ignition phase, dial it down leaner to 15-17 for Diesel, and probably dial down some on the preheat and fuel ramp. Call me if anything...
Barry
Barry,
Mike in AL
Barry,
Mike in AL
Barry
Barry,
I'm a bit unsure exactly the items you are talking about, let me see if I understand you:
"too rich most likely during the ignition phase, dial it down leaner to 15-17 for Diesel" Is that Pump Power Ignition? Currently set at 21
"probably dial down some on the preheat" Is that Engine Fuel Preheat? Currently set at 30%
"probably dial down some on the fuel ramp" Is that Pump Start Ramp? Currently set at 2
I attached a screen shot of my current info for your consideration.
Sorry to be so anal but I want to make sure I get everything correct so that KingTech can represent better at the next fly in I go to.
Mike in AL
#785
RE: KingTech K-80
Yes Mike, those are the parameters to adjust, without a video of the GSU as things happen. I don't know which stage it is "hanging" meaning temperature remaining for more than a few seconds without increasing. That's the phase you like to make it leaner, but sometimes this richness will carry over onto the next phase and that's when it gets flamy. On a Diesel start, lean out the "pump ignition" only first, I think you should be seeing improvement already.
#786
My Feedback: (21)
RE: KingTech K-80
ORIGINAL: Tip22v
I ran the starter in ''test'' mode and the clutch sounded like it was disengaging positively. I turned the fuel ramp back by one, will see how it does tomorrow.
When you ran the starter in test mode did you still get the buzzing sound that we heard on your video?
Joe Lewis
Kingtech
K-80 and K-140
Owner
#787
MN
RE: KingTech K-80
Hi Mike,
What software are you using to import your ECU data to your PC?
Chris
Chris
ORIGINAL: dmscpu
Barry,
Mike in AL
ORIGINAL: dmscpu
Barry
Barry,
Mike in AL
Barry,
Mike in AL
Barry
Barry,
Mike in AL
#788
AL
RE: KingTech K-80
ORIGINAL: JOHNSCHR
Hi Mike,
Chris
Hi Mike,
Chris
Chris,
First you need the adapter:
http://www.xicoy.com/catalog/product...jn76ntk6611is6
and Noooo it's not a simple servo connector to USB, it's got chips inside the black box.
Then the software is at:
http://www.espiell.com/FadV5cInst.zip
Mike
#790
AL
RE: KingTech K-80
Yes Mike, those are the parameters to adjust, without a video of the GSU as things happen. I don't know which stage it is ''hanging'' meaning temperature remaining for more than a few seconds without increasing. That's the phase you like to make it leaner, but sometimes this richness will carry over onto the next phase and that's when it gets flamy. On a Diesel start, lean out the ''pump ignition'' only first, I think you should be seeing improvement already.
I did a lot of changes all one at a time and with the engine cooling down between starts.
The best results we got were:
Pump Power Ignition: 15 tried 16 no change
Engine Fuel Preheat: 10 had the biggest effect but down from 45%
Pump Start Ramp: 2 only prolonged the start cycle and still had flames
Also tried AUTO+2 at 1 and 0 only prolonged the start cycle and still had flames
The video is at:
Pump Start Ramp: 2
Also tried AUTO+2
This is the link to view the video, and if anyone is wondering what the computer interface looks like, take a look:
http://dl.dropbox.com/u/46660307/201...-12-51_759.wmv
So Barry, where do I go from here?
Mike
#792
AL
RE: KingTech K-80
ORIGINAL: KC36330
Mike, link is a NoGo here, 404 error.
I used Chrome, Firefox, Opera, and even IE and it worked on all......
Mike
#794
RE: KingTech K-80
Joe,
I did three more flights today and I don't recall hearing the buzzing sound during start up, maybe tweaking the starter motor alignment fixed it?
Tom
Tom
#796
RE: KingTech K-80
I was trying to find the fuel ramp menu setting to adjust the fuel ramp (as recommended on this thread) but cannot find it. I have look all through the book for the FADEC and it talks about fuel ramp but does not appear to mention how to adjust it. What am I missing? The Batmobile looks really cool but I sure would like to tame it down if possible...
Thanks, Tom
Thanks, Tom
#797
OK
RE: KingTech K-80
With the Gsu plugged into the ECU press the #2 button on the GSU twice ( it must say TRIM LOW to acces the menu ). It will display a screen labeled start, press that, then scroll through.
#799
RE: KingTech K-80
ORIGINAL: mdeseve
Hi Guys anyone using mobile dte oil with the kingtech turbine. Is it authorise for the waranty.
thanks
mike
thanks
mike
Barry
#800
RE: KingTech K-80
ORIGINAL: dmscpu
Barry,
The video is at:
Pump Start Ramp: 2
Also tried AUTO+2
Mike
The video is at:
Pump Start Ramp: 2
Also tried AUTO+2
Mike
