 Quantas Problem Solving >
Old 04-15-2010 | 11:13 PM
Default Quantas Problem Solving
After every flight, Qantas' pilots fill out a form, called a "gripe sheet," which tells mechanics about problems with the aircraft. The mechanics correct the problems, document their repairs on the form, & then pilots review the gripe sheets before the next flight. Never let it be said that ground crews lack a sense of humor. Here are some actual maintenance complaints submitted by Qantas' pilots & the solutions recorded by maintenance engineers. By the way, Qantas is the only major airline that has never had an accident.
(P= The problem logged by the pilot.) (S= The solution and action taken by mechanics.)
P: Left inside main tire almost needs replacement.
S: Almost replaced left inside main tire.
P: Test flight OK, except autoland very rough.
S: Autoland not installed on this aircraft.
P: Something loose in cockpit.
S: Something tightened in cockpit.
P: Dead bugs on windshield.
S: Live bugs on backorder.
P: Autopilot in altitudehold mode produces a 200 feet per minute descent.
S: Cannot reproduce problem on ground.
P: Evidence of leak on right main landing gear.
S: Evidence removed.
P: DME volume unbelievably loud.
S: DME volume set to more believable level.
P: Friction locks cause throttle levers to stick.
S: That's what they're for.
P: IFF inoperative.
S: IFF always inoperative in OFF mode.
P: Suspected crack in windshield.
S: Suspect you're right.
P: Number 3 engine missing.
S: Engine found on right wing after brief search.
P: Aircraft handles funny.
S: Aircraft warned to straighten up, fly right, and be serious.
P: Target radar hums.
S: Reprogrammed target radar with lyrics.
P: Mouse in cockpit.
S: Cat installed.
Old 04-16-2010 | 12:00 AM
Default RE: Quantas Problem Solving
I doubt these were ever really logged - the regulatory bodies frown on this kind of thing.
These same grips and responses have been circulating for YEARS!.
Still - good for a laugh.
Old 04-16-2010 | 12:37 AM
DelGatoGrande's Avatar
My Feedback: (23)
oldy[8D]
Old 04-16-2010 | 04:14 AM
The old ones stand the test of time.
Old 04-16-2010 | 07:22 AM
My Feedback: (106)
My first to see this. Hilarious. Sounds like the difference between health care workers (service) on the floor and facilities Management (support) when describing physical facilities problems. Ha.
Old 04-16-2010 | 08:08 AM
This same list of squawks has been attributed to the Air Force, and Navy...now Quantas.
Old 04-16-2010 | 08:36 AM
ORIGINAL: Harley Condra
Yep, old one, but with a new way to spell Qantas
Old 04-16-2010 | 09:30 AM
rjbob's Avatar
My Feedback: (8)
First saw this when I was in the USAF in the 1960s.
Bogus...but funny.
Also, in the many times I have seen this reincarnated, there is usually something new added.
Old 04-16-2010 | 09:50 AM
ORIGINAL: ticketec
Sorry about the misspelling, mate.
I had forgotton that the name "Qantas" is an acronym for "Queensland and Northern Territory Air Services".
Old 04-16-2010 | 10:43 AM
grbaker's Avatar
My Feedback: (29)
Old 04-16-2010 | 01:17 PM
rjbob's Avatar
My Feedback: (8)
ORIGINAL: grbaker
As a fleet mechanic for 20 years I have seen several work orders that read:
Problem: Engine missing
Work Performed: Found engine
But not on a Qantas jet.
Old 04-16-2010 | 05:17 PM
My Feedback: (34)
Heh.. I was wondering why Qantas would have Targeting Radar?
Old 04-16-2010 | 06:01 PM
rjbob's Avatar
My Feedback: (8)
IFF (Identification Friend or Foe) is a military acronym. Qantas pilots would not use that designation for a transponder issue.
Old 04-18-2010 | 02:59 AM
JohnMac's Avatar
Yeah, I am sure it's against the anti competion laws to shoot down other airlines
Old 04-18-2010 | 03:42 AM
rjbob's Avatar
My Feedback: (8)
ORIGINAL: JohnMac
Not in Australia.
Shoot away!
Old 04-18-2010 | 07:50 AM
if it doesn't have a Roo on the tail... blaze away, it the competion!!!
