Reload this Page >
FEJ F-16 1:5.5 Camo assembly
Old 05-10-2010, 02:02 PM
  #51
babish
Default RE: FEJ F-16 1:5.5 Camo assembly
Great job Ziv!!!
Keep it going, I can't wait to see it in the air...
I hope to be invited to the maiden.
Babish
Old 05-10-2010, 03:24 PM
  #52
ZivBit
ZivBit's Avatar
ORIGINAL: babish
Great job Ziv!!!
Babish
Hi Ofir
Do not worry, you will be my guest of honor at the maiden..
Hope its airborn around the begining of July... Im Yirze Hashem ...
Shalom,
Zivo
Old 05-11-2010, 12:21 AM
  #53
POWER JET
ORIGINAL: Kmarks
Hello Zivo,
I am glad you mentioned that you will be strengthening the elevator shaft assembly area. This point has been covered before.
For any one else who is upgrading, please reinforce the elevator shaft assembly area. Mine has been flawless for the last 27 flights and counting.
Great job Zivo, keep it up and show how you figured out the moving parts.
Kevin
Hi Kevin,
how i must reinforced the elevator shaft assebly area?Cause i have one of these birds.Can you tell me?Do you have photos or something?
Thanks in advance..
Old 05-11-2010, 12:27 AM
  #54
POWER JET
ORIGINAL: ZivBit
Hi Guys
Upgraded landing gear set from FEJ - I sent the original LG to the factory after I noticed they have an upgrade with a self locking mechanism and upgraded pistons. Did not think twice.
The landing gear upgrade is a must. The pistons are HD, works with 4mm tubing. I pressure tested the system and it was flawless. Holds pressure without any issue. plus the locking mechanism works great as well. No need for the extra valve that was needed with the original LG.
Cheers,
Zivo
Hi Zivo
Αbout the landing gear upgrade,where you sent the set for upgrade?Are they workable now?I have one of this bird me too for a year now.
Old 05-11-2010, 12:40 AM
  #55
Kmarks
My Feedback: (36)
Hello Nick,
Follow this thread "FEJ 1/5.5 F16 build thread" and most all building and upgrade questions will be answered. Great flying ship, with awesome presence.
Best Regards
Kevin Marks
Old 05-11-2010, 02:02 AM
  #56
ZivBit
ZivBit's Avatar
ORIGINAL: POWER JET
ORIGINAL: ZivBit
Hi Guys
Cheers,
Zivo
Hi Zivo
Hi Nick
I sent the gear to the FEJ factory in china. I contacted James first and got his approval and then sent it to an adress he gave me.
The new gear works great, looks like a winner LG.
Zivo
Old 05-11-2010, 08:58 AM
  #57
gjhinshaw
My Feedback: (303)
gjhinshaw's Avatar
Fly Eagle Shipping
TO: WANG YI CHIANG
Add:NO.208 3FL 1 building qinshi road sonzao town jinwandist
zhuhai city guangdong province china
area code:519040
Tel: 13250067881
Old 05-11-2010, 09:21 AM
  #58
rbxbear44
My Feedback: (86)
Nick,
Matrix Manufacturing has a GREAT aftermarket and VERY scale operating gear for this plane too. I have worked with Matrix and had the prototype in my F-16 and it works flawlessly from the start. It is basically a drop in set up with exact screw allignment to the formers. The Nose Gear has justa little bit of work since it a true direct drive steering.
Good luck!
Rex
ID:	1434300   Click image for larger version
Old 05-11-2010, 10:18 AM
  #59
gjhinshaw
My Feedback: (303)
gjhinshaw's Avatar
I looked at these, Nice BUT.... 1700.00
http://home.earthlink.net/~matrixmt/id15.html
Old 05-11-2010, 11:01 AM
  #60
rbxbear44
My Feedback: (86)
Yep...but no belly landings failed downlocks. I know fej is working to get this gear in good working order. Best wishes!
Rex
Old 05-11-2010, 12:35 PM
  #61
rc_buster
rc_buster's Avatar
Hey Zivo ,
Looks super good.. the F16 Scheme.. can't be better !
nice work , and keep us updated!
Best Regards
Ido
Old 05-11-2010, 12:55 PM
  #62
ZivBit
ZivBit's Avatar
Thanks Dodo
I am now entering the workshop for 5-6 hours... see what will come up
Updates soon.
Cheers,
Zivo
Old 05-11-2010, 03:32 PM
  #63
ZivBit
ZivBit's Avatar
On we go:
First - the air brake shells are glued and in place, aligned to the elevators. I also used some grease on the main shaft to prevent glue from sticking to it. Used Hysol to glued it in place. Before I closed the hatch made sure to fill any gap and give more strength to the elevator shaft.
Well the airbrake is in place and will be cured by morning.
As for the servos that will operate them - 2 X Hobbico CS-170 - same as the 7995 servos, titanium gears, super torque. Great servo I have it in all my jets with no issues.
ID:	1434408   Click image for larger version
ID:	1434409   Click image for larger version
ID:	1434410   Click image for larger version
ID:	1434411   Click image for larger version
Old 05-11-2010, 03:35 PM
  #64
ZivBit
ZivBit's Avatar
Glued the nose structure. Before I did so I covered teh ply formers with carbon layer, glassed. It is super strong now, and also gives it a nice shiney carbon look...
The nose cone was aligned and in place with no issues.
One more thing: I did another layer of gray paint for the interior, and thats done.
Zivo
ID:	1434414   Click image for larger version
ID:	1434415   Click image for larger version
ID:	1434416   Click image for larger version
ID:	1434417   Click image for larger version
ID:	1434418   Click image for larger version
Old 05-11-2010, 03:39 PM
  #65
ZivBit
ZivBit's Avatar
A quick word about the medical devices and model airplanes build: I have found that some medical devices such as these long clams (also known as Endo Clinches) are super helpfull when it comes to the need to pull something from the fuse or wing, when there is no other way to get it, or for example to pull a servo extension through tight places....
Well luckily enough I work in the medical field and whenever a device gets thrown from the OR, It comes to me and starts its second career... as a building device...
Zivo
ID:	1434420   Click image for larger version
ID:	1434421   Click image for larger version
Old 05-11-2010, 03:43 PM
  #66
ZivBit
ZivBit's Avatar
And one last thing for tonight - Introducing my stinky little friend - a snake, also known as "popcorn" ... belongs to my son and keeps me company for these late night hours.
He is quiet, does not eat much, and very friendly...
Very tired, will make more significant progress tomorrow.
Cheers,
Zivo
ID:	1434423   Click image for larger version
ID:	1434424   Click image for larger version
Old 05-12-2010, 05:17 PM
  #67
ZivBit
ZivBit's Avatar
Comrads
I had a dificult night with the airbrake scale covers. I modified the whole system to have less moving parts and eventualy it came OK, I am happy.
Dan - this is my version to the bottom tear drop covers, no need for the robart-spring operated cover. Tell me what you think.
I spent too many hours on this part, but I guess it will be worth it.
The wood parts I made already covered in primer , tomorrow I will sand and prepare for paint.
Ziv
ID:	1435062   Click image for larger version
ID:	1435063   Click image for larger version
ID:	1435064   Click image for larger version
ID:	1435065   Click image for larger version
ID:	1435066   Click image for larger version
ID:	1435067   Click image for larger version
Old 05-12-2010, 05:20 PM
  #68
ZivBit
ZivBit's Avatar
Final thing about the airbrake is the pivot covers. this was rather easy, and adds so much to the overall scale look.
Good night,
Zivo
ID:	1435069   Click image for larger version
ID:	1435070   Click image for larger version
ID:	1435071   Click image for larger version
ID:	1435072   Click image for larger version
ID:	1435073   Click image for larger version
ID:	1435074   Click image for larger version
Old 05-12-2010, 06:04 PM
  #69
Details 4 Scale
ORIGINAL: ZivBit
Comrads
Ziv
Ziv,
The overall look and fit seems to be more than adequate. I like your idea of No moving parts. I think I'll modify the cover parts to do it your way. I'll make some nice molded covers and the extension front piece instead of the moving hinged covers
Nice job.
Dan
Old 05-14-2010, 10:19 AM
  #70
Tazmanian-Devil
What can I say brother.
It looks every day like the real one.
Hope you'll finish it till the end of August...you know what is going to happen than....
You're going to have your own, jet runway...
Adi
Old 05-18-2010, 04:43 PM
  #71
ZivBit
ZivBit's Avatar
Little progress today:
I painted the gear doors interior to look more scale rather than the white they come with.
I also painted the wood ring of the tail section in the tail cone in gray primer. Thsi part will accept the afterburner lighting ring in it.
After that I installed the gear in place and tested it - PERFECT.
Nose gear done including steering - HS7955 on the nose. Gonna use a GY401 gyro on it too.
Tommorrow I will do the tail section servos install including the airbrake servos and testing.
Good nacht.
Zivo
ID:	1438489   Click image for larger version
ID:	1438490   Click image for larger version
ID:	1438491   Click image for larger version
ID:	1438492   Click image for larger version
ID:	1438493   Click image for larger version
ID:	1438494   Click image for larger version
ID:	1438495   Click image for larger version
ID:	1438497   Click image for larger version
ID:	1438498   Click image for larger version
ID:	1438499   Click image for larger version
Old 05-18-2010, 05:36 PM
  #72
fasteddi
I like the grey primer for the interior!!!
i am thinking to copy this idea for my agressor too.
today i have send the gear to james - hope to get it back soon.
because i get my AMT-OLYMPUS-HP. that will be the 23 to 24kilo burner for this huge model. i bought that turbine used with 4 hours on the clock and will change it to kerostart.
i let you know how it will work.
Uwe
Old 05-21-2010, 11:34 AM
  #73
ZivBit
ZivBit's Avatar
Comrads
today I finished witht he lighting system - did the fin illumination lights. I like this one the most. the effect is awsome.
Did a ply housing for the led, painted it black, and glued inside the fuse, with the transparent lens on top. The led has an angle that reflects the light directly on the fin. Without this angle it would just light the sky and not the fin...
Turned off the lights on the room, and this is how it looks...
ID:	1439797   Click image for larger version
ID:	1439798   Click image for larger version
ID:	1439799   Click image for larger version
ID:	1439800   Click image for larger version
ID:	1439801   Click image for larger version
ID:	1439802   Click image for larger version
ID:	1439803   Click image for larger version
Old 05-21-2010, 11:40 AM
  #74
gjhinshaw
My Feedback: (303)
gjhinshaw's Avatar
THAT IS THE COOLEST!!!!!!
Old 05-21-2010, 11:42 AM
  #75
ZivBit
ZivBit's Avatar
Tail cone adjustments and afterburner ring:
Since I bought the TAM pipe, which is a little smaller in diameter, I had to make a new ring to secure it and glue on thop of the original one.
The D4S AB ring is robust. I have not tested it yet, but will do so tomorrow. I glued 5mm carbon spacers on the bottom of the ring to lift the components from the wood ring.
The wood ring will be painted next in gray primer as well.
I also intend to cut the electrical cord and weld detachable tips so I can remove the cone alone for maintenance moer easily.
ID:	1439806   Click image for larger version
ID:	1439807   Click image for larger version
ID:	1439808   Click image for larger version
ID:	1439809   Click image for larger version
ID:	1439810   Click image for larger version
ID:	1439811   Click image for larger version
ID:	1439812   Click image for larger version
