 Reversed Y-Harness >
Reversed Y-Harness
Reversed Y-Harness
Old 05-03-2010 | 11:55 AM
rcjetsaok's Avatar
My Feedback: (7)
Default Reversed Y-Harness
Any comments or input of using a reversing y-harness on 2.4 ???? It's the only solution to my problem that I can think of other than a Matchbox... All thoughts would be appreciated !!!!
Danno
Old 05-03-2010 | 12:02 PM
jetpilot's Avatar
My Feedback: (48)
Default RE: Reversed Y-Harness
spend the money on a matchbox or reversed servo. The reversed Y's I have had experience with are junk.
Scott
Old 05-03-2010 | 12:15 PM
rjbob's Avatar
My Feedback: (8)
ORIGINAL: jetpilot
Scott
Agreed...don't use a reversing Y-harness on a jet. Just mix it in your tx.
Great meeting you in Mississippi, Danno
Old 05-03-2010 | 12:18 PM
highhorse's Avatar
I don't think that 2.4 affects the servo signal at all, and my own personal experience with rev-y's has been positive, fwiw.
Old 05-03-2010 | 12:27 PM
bcovish's Avatar
My Feedback: (8)
The only problem Dan has with changing out the servo is that the person (not Dan) who installed the servo epoxied them in and they are not coming out without part of the stab attached. :-(
Has anyone had any experience with Smart-Flys equallizer II.
Old 05-03-2010 | 12:33 PM
Spektrum advises against them...
Lost 2 planes before i found the info on their website.
Old 05-03-2010 | 12:36 PM
GSR
My Feedback: (145)
RUN AWAY from the reversing Y harness- Use a matchbox, buy a reversed servo get a rec with more channels-ANYTHING but a reversed harness. Cost me an airplane once. Scotty
Old 05-03-2010 | 12:52 PM
gunradd's Avatar
My Feedback: (9)
I balled up my yaF16 with a reversing Y and spektrum says do not use them with thier equipment.
Old 05-03-2010 | 03:29 PM
rcjetsaok's Avatar
My Feedback: (7)
Thanks guys !!!!! I think my gut feeling was right, but I just wanted to get some reassuring info pro or con... I don't think that using a amplified Y on elevators on a Turbine aircraft is a smart move... Machbox time !!!!!!
Thanks Guys, !!!!
Danno
Old 05-03-2010 | 06:17 PM
CPing's Avatar
Have to agree with not using the y-harness. I prefer the Smart-Fly Equalizer but a Matchbox would be fine as well.
Craig
Old 05-03-2010 | 07:58 PM
Remember Hitec digital servos can be reveresed. I use a Y lead on my elevator and reversed the Hitec servo. So if you ahve Hitec's no problem!!!!
Mav
Old 05-03-2010 | 08:14 PM
rcjetsaok's Avatar
My Feedback: (7)
I'm useing Jr 2721's.. I have a reversed 2721, but the problem is that my buddy that built the airplane expoxied the servo's in a foam core stab.... I will have to butcher it up pretty good to get it out. I told him I have the utmost confidence about JR servo's and odds are it would never need to come out, but I didn't expect him to mop the hole w/ epoxy and jam the servo's in it !!!![sm=spinnyeyes.gif] Their metal gear good servo's, I hope they last !!!![sm=tongue_smile.gif] I'll give ya one guess what airplane/designer I'm talking about !!!!!........ If you guessed Isobar/Eddie Weeks, It all makes sense now doesn't it !!!!
Danno
P.S... Eddie didn't build this airplane I'm talking about !!!!
Old 05-03-2010 | 10:19 PM
My Feedback: (38)
I've used the one from electro dynamics with no problems.
Old 05-04-2010 | 09:19 PM
Veritech's Avatar
I have used the reverser from Electrodynamics for years as well with no issues on 72 Mhz and 2.4 with no issues as well.
http://electrodynam.com/rc/EDR-106/index.shtml
And before anyone asks, yes i am affiliated with ED but am only their show help. I have been flying their stuff years before I started helping them at the Toledo show.
Their stuff works just works, no excuses, no workarounds, no add-ons, no runarounds, no hassle, plus the best after-sales service in the industry, no if's, and's, or but's, as it should be.
Old 05-04-2010 | 09:27 PM
Reverse Y's kill planes-eventually. Not worth it.
Old 05-04-2010 | 09:29 PM
AndyAndrews's Avatar
Ive been using a y harness on my boomer for years FM and 2.4 without any problems. The only problem is that you cannot sub trim with it (well you can but you can only adjust one servo and then the other one has to be adjusted using the clevis). At the time it was a good cheap way for me to save a channel on a RX.
