View Poll Results: A poll
Voters: 285. You may not vote on this poll
Rudder question
Ok. I have never done a poll before but wanted to get the opinions of jet flyers. See this whole thing was sparked by a discussion with a friend about flying. He stated that most jet pilots don't use rudder during a normal flight except for maybe take off and landing. I am very interested in seeing the numbers on this one.
Patrick
Patrick
It depends on the occation. I never used rudder other than takeoff and landing on a 1/8 F-16 until one taileron servo failed and the rudder was used to bring the plane out of a death spiral. The rudder saved the day.
So as I write this the poll says 41% of us use the rudder for the entire flight..What utter rubbish! I'd say that at least 8 of of 10 jet pilots cannot use the rudder properly. I see it at every jet meet I go to, on landing the line correction while the plane is flying towards the pilot is done on ailerons and elevator then as soon as the plane in on the ground pointing away from them the rudder miraculously starts to work. Sorry guys but some of you 41%ers are dreamers.
Jason
Jason
ORIGINAL: jason
MO
Your right KC, if you fly helis and then go to a plane you feel strange NOT using the rudder ! However, I do see a lot of plane pilots that do not use rudder out at the field.
oh believe me i see it allot too, our main club filed is 2200' x 800' of concrete, we've got people who have been flying for 50+ yrs who can't use the left stick for anything other than ground taxi and throttle adjustments (and sometimes not even those), if the wind changes direction, they'll turn and fly in the direction of the wind because the field is of such a size that they can and if they go to a location that requires you to fly with a cross wind, they don't fly or they crash trying
My Feedback: (23)
ORIGINAL: KC36330
I'm glad my club isn't the only one with this issue. It drives me insane watching guys trying to land their 1/3 scale cubs that are crabbing into the wind by aileron rolling into the wind and touching down on one wheel. All the while the thing is now pointed at the flight line and pilot stations..[:@][:@][:@][:@][:@]
and if someone can land decently his jet without breaking it, who cares if it uses rudder or not? Many jets don´t react to a rudder input like you guys are talking about.. In a F-15 you got more opposite rolling than yaw, a F-16 can´t be snapped and the list goes on and on.
IMO the only occation that rudder is any worth on a jet, in his true form is from recovering from some problem or doing a nice low knife edge or slow roll over the runway with a plane suited for
that, like the big Viperjet (wich is currently being built for me to this purpose, by the way.. hehehe)
ORIGINAL: KC36330
I'm one of the remaining 2 because i know what it's for and i use it the entire flight and can't imagine NOT using it
ORIGINAL: jason
Now, if only I could make sure that I always use the CORRECT rudder input, life would be good. I still mess up occasionally during inverted flight. [X(]
Gordon
Hah......50 or so years ago (1961) rudder was the ONLY control for most guys..........
http://www.google.com/imgres?imgurl=...26tbs%3Disch:1
Reeds or Galloping Ghost anyone?
-Mike
-Mike
I get the impression from several posts that some, maybe many, people think that you hold on into-wind rudder during crosswind flying, or a crosswind approach. No-one has said it explicitly but several imply that you should be holding on rudder in crosswinds. Is that what you actually think or have I got the the wrong impression from several of the posts?
H.
H.
Actually its opposite rudder in the crosswind with aileron into the wind.
I do think alot of jet guys crab into the wind and just use rudder for sliding right or left to hit the runway, which is a perfectly acceptable way to do it. Thats the way the fighters do it. That I do know from personal experience. The f-16 lands in a crab.
With swept wing airplanes, If you use the rudder too aggressively at low speed and high angles of attack, it will induce roll. So yes it is used, but judiciously..
With my Comp-ARF Flash, I use the rudder for knife edge, 4-pt and slow rolls, blender into an inverted flat spin, and snaps. For my scale jets, other then knife edge and slow rolls, just on take off and landings.
My Feedback: (67)
ME
WRONG! Rudder is used to co-ordinate turns. Banking causes the nose to yaw in the opposite direction. The rudder is used to bring the nose back to the desired direction of the turn. When flying full scale the term used is step on the ball. That is the turn co-ordinator for those that don't fly full size aircraft. Using top rudder will lead to a stall, eventually.
I thought the rudder was for steering on the ground…. Just kidding my instructor beat it in to me so I use at least some during most turns and on landing etc. I appreciate it on those cross wind days at a event. It allows me to fly when others are sitting out.
Step on the ball is a new one on me, the rudder application would be too late by the time the ball has moved to give a coordinated turn, the way I used to instruct it was as you move the stick get the knee out of the way.
Adverse Yaw is caused by the down going aileron causing more drag than the up going aileron therefore the nose goes in the opposite direction to the turn and needs rudder to coordinate the turn correctly.
Mike
Mike
