Reload this Page >
BOOMERANG ELAN - New Build & Setup Thread!
Old 03-11-2014, 11:30 AM
  #401
Pete S-RCU
I'll give it a try.
Old 03-11-2014, 11:44 AM
  #402
Pete S-RCU
No change, removed both pins, one at a time.
When I remove the rear pin and push the boom towards the fuse, it just transfers to the other side?
Only cure I can see, is put a shim/filler plate between the boom and fuse.
Or, a different stab with the mounting holes closer together?
Maybe Alan will have an answer?
Old 03-11-2014, 12:10 PM
  #403
cyphur01
cyphur01's Avatar
Pete
if you have not drilled the aluminum tabs in your stab there may be some hope. Put the booms and stab on loosely. Then put the wings on. Push the wings tight up against the boom so thAt the boom makes contact with the entire fuse. Tighten the wings to hold the booms in place and then tighten the stab on. Finally drill the aluminum tabs and put bolts through them. This happened to my fathers when I was building it. No issues from the booms being tilted a little.
Old 03-11-2014, 12:57 PM
  #404
Pete S-RCU
Will give it a shot.
My stab fits on very tight, no play for making adjustments.
Could barley get it seated?
Maybe with a little' adjustment' I can loosen it up a bit to allow for some wiggle room.
Old 03-12-2014, 05:49 AM
  #405
Pete S-RCU
Interesting development, with the stab off, I still can't push the left boom up tight against the fuse.
Maybe a flaw in the fuse itself?
Will do more checking.
Old 03-12-2014, 06:04 AM
  #406
Pete S-RCU
Well, I removed the wing tube and it fits up tight against the fuse.
Will have to make the hole a little bigger in the boom till it fits.
Old 03-12-2014, 06:59 PM
  #407
PaulD
My Feedback: (39)
PaulD's Avatar
A buddy of mine built one last year and said he had to cut the outer wing tubes out of the booms and re-glue them in straight. I'm not sure if he had the same problem as you as I never saw any pics but it sounds like the same problem. Seems like Boomerang has a problem with its jigs.
PaulD
Old 03-12-2014, 08:46 PM
  #408
kev-o
I don't think they are the same as they used to be mine is no where near what yours was Paul , mine is several years old and still goin strong over 130 flights on it. Nothing coming loose it didn't take anything weird to build it. Accept tight wing tubes. It flys straight still today
Old 03-13-2014, 05:34 AM
  #409
Pete S-RCU
I had to sand out the tubes a little and then it fits good.
I don't think I will need to wrap the outer wing tubes like they suggest if they're loose.
Mine seem pretty tight.
Old 07-22-2014, 04:23 AM
  #410
uixkes
uixkes's Avatar
Hi all,
I just wanted to post a couple of pictures of my Elan ready for it's maiden flight.
JetsMunt 100XBL
Electron ER40eVo retracts with electric brakes
Weight (dry): 9.8kg
I hope she flies like my Nano. Then the maiden should be straight forward (I hope :-)
Wish me luck
Ulrich
ID:	2016237   Click image for larger version
ID:	2016238   Click image for larger version
ID:	2016239   Click image for larger version
Old 07-29-2014, 08:52 AM
  #411
cbdane
Unhappy Cupped servo covers?
Long time forum member but infrequent poster. I'm new to fixed wing turbines but I've been flying turbine helicopters for around 4 years. Very excited about the Elan!
Thanks for all the great information on this new thread and the older "Elan has arrived" thread. Both very helpful so far. A quick question that I haven't seen discussed, however (tried a forum search). I just received an Elan Navy grey from Kilroy and everything looks pretty good except for the servo covers. They are badly warped. I'd describe them most accurately as "cupped." So much that the servo mount rails aren't even parallel. The plastic isn't very flexible and I've attempted to gently attach them to one of the servo bays on the bottom of the fuselage and I could hear very light cracking noises as they're forced flat; not good. Not just a "one of" since all 8 covers, left and right, are absolutely identical.
Has anyone come across this problem? I have sent photos to Kilroy and hoping to hear back from him. I did notice that Dreamworks has replacement covers for sale. They'll be next on my "call" list if I don't hear from the new US distributor.
Thanks so much in advance for your advice!
ID:	2018318   Click image for larger version
ID:	2018319   Click image for larger version
Old 07-29-2014, 10:31 AM
  #412
mtnflyer14
mtnflyer14's Avatar
I have had two Elans and did not have that problem. Looks as if they got hot in storage someplace and warped. Perhaps you can heat them and over bend them back to be flat?
Regards,
Gus
Old 07-29-2014, 01:12 PM
  #413
Xairflyer
Xairflyer's Avatar
Try a bit of heat with a hot air gun
Old 07-29-2014, 01:57 PM
  #414
cbdane
Default Servo covers resolved!
Sent an email with photos to Kilroy (new Boomerang USA distributor) and he gave me a call to let me know new covers are in the mail! Very grateful!
Update: Covers are beautifully flat! Great service from the new Boomerang USA distributor. Thanks Kilroy!
Old 07-29-2014, 04:58 PM
  #415
Colin Allen
Colin Allen's Avatar
Glad you got a solution. Mine were fine (although there were other QA problems!).
Old 08-08-2014, 08:54 AM
  #416
cbdane
Default Simulated after-burner?
What do you think? Will I just burn up this ring? I am tempted to consider the smaller diameter version that will tuck further into the outlet. Actually being nearer the turbine nozzle may protect it more, before the hot exhaust stream has spread? I've noticed in some of the pictures in the Elan threads that the thermal discoloration of the paint actually seems to increase a bit toward the outlet of the fiberglass cone. Of course, the wire would be brought inside the fuse immediately forward of the ring.
You input would be very valued!
Old 08-08-2014, 05:03 PM
  #417
mtnflyer14
mtnflyer14's Avatar
I would be very surprised if the afterburner ring isn't damaged/destroyed very quickly.
Regards,
Gus
Old 08-13-2014, 11:11 PM
  #418
Colin Allen
I think it will melt the first time you try it. I have that whole area painted with BVM heat shield on mine.
Old 08-14-2014, 05:29 AM
  #419
STICK MODE
STICK MODE's Avatar
i would go along with the thoughts that it will melt burn self destruct ect the inside of mine has a layer of thin heat blanket. Works well no issues in over three years flying .
Old 09-02-2014, 09:19 PM
  #420
cbdane
Thanks guys! Not giving up on this yet. I noticed that on the Boomerang-Jet site, there is a photo of an Elan in flight with the Xicoy afterburner LEDs installed so I know it's possible. I'm going to build a thin stainless steel tail pipe (0.012" = 0.3mm thick) to shield the LED ring from direct turbine exhaust flow and with a small gap between the fiberglass and the pipe to provide cooling airflow. Your advice has been valuable and will lead me to a more robust solution than I originally imagined.
Old 10-02-2014, 01:59 PM
  #421
NC Jetguy
Hi Guys,
I have a question regarding the canopy and cockpit:
Just finishing the build on my second Elan. The manual indicates that the floor of the cockpit should be cut out to accomodate the cockpit interior. On my first oe, I cut the floor out of the interior piece and glued it. I didn't want to take that big a piece out of the actual cockpit. What have others done? Any pix?
Ken
Old 10-02-2014, 08:05 PM
  #422
PaulD
My Feedback: (39)
PaulD's Avatar
I just blacked mine out. Painted the inside with Tamiya "Lame Flake" clear and then backed it with black.
Here's a video of 4 Elans flying together with the gopro looking over the canopy.
https://vimeo.com/107549178
PaulD
Old 01-06-2015, 07:12 PM
  #423
cbdane
Default Field stand for Boomerang Elan
What are you guys using for a field stand for the Elan? I'd like a straightforward way of testing the retracts before sending her up. Idon't think the conventional "double-U" cradle will work since there isn't a centered aft fuselage section.
Thanks in advance for your input!
Old 01-07-2015, 01:47 AM
  #424
BaldEagel
BaldEagel's Avatar
Old 01-07-2015, 05:53 AM
  #425
RLPageMD
RLPageMD's Avatar
Harbor Freight sells a portable work stand that is rated to 200 pounds for $20. Add a little extra padding and it works great. Doc
