Smoke spryer at end of Pipe???
<div style="margin: 0in 0in 10pt">Guys.
Has anyone done a smoke system with the smoke spryer at the end on the pipe instead of the turbine tail cone?</div><div style="margin: 0in 0in 10pt"></div><div style="margin: 0in 0in 10pt">Is there enough heat??</div><div style="margin: 0in 0in 10pt"></div><div style="margin: 0in 0in 10pt">Thanks for your input.</div> |
RE: Smoke spryer at end of Pipe???
Won't work....needs to be right at the back of the turbine.
Chad |
ORIGINAL: SinCityJets Won't work....needs to be right at the back of the turbine. Chad Check out the BD in my profile picture to the left of this post. |
http://www.rcuniverse.com/forum/m_9591914/tm.htm check out post #4 that is the BD with the brass tube running 24" between the daul wall exhuast pipe.
I did it on my SM Viperjet. Didn't work that great, all I got was oily grass at the back of the plane ;)
Moved it right at the turbine, works much better. I didn't use the 'preheat' trick, so that might have been the problem. I'd say, give it a try, but don't drill all your mounting holes yet ;) Hans |
Depends on the distance and pre heating helps alot, need to get a fine mist to work best.
There is still a fairly high temp at the end of the pipe not much different from a Gas engine so will also probably work better with the smoke oils rather than just diesel/kero. |
1 Attachment(s)
ORIGINAL: Flynstuff <div style=''margin: 0in 0in 10pt''>Guys. Has anyone done a smoke system with the smoke spryer at the end on the pipe instead of the turbine tail cone?</div><div style=''margin: 0in 0in 10pt''> </div><div style=''margin: 0in 0in 10pt''>Is there enough heat??</div><div style=''margin: 0in 0in 10pt''> </div><div style=''margin: 0in 0in 10pt''>Thanks for your input.</div> I run a 3/16 brass tube between the dual walls of the tail pipe then bend it at the end of the pipe. I stick a #11 Exacto blade in the of the brass tube then squeeze it and take the blade out. This set up works great. I have may Smoke pump travel in my radio set down to 35% and I get a nice thick smoke trail. Joe Lewis Kingtech K-80 owner |
There was a guy on here last year who used a oil fired boiler injector to spray oil into the exhaust, it made very good smoke, never know it may help to have a very fine spray at the back of the tube?
Mike |
ORIGINAL: Jetpilot24 ORIGINAL: Flynstuff <div style=''margin: 0in 0in 10pt''>Guys. Has anyone done a smoke system with the smoke spryer at the end on the pipe instead of the turbine tail cone?</div><div style=''margin: 0in 0in 10pt''> </div><div style=''margin: 0in 0in 10pt''>Is there enough heat??</div><div style=''margin: 0in 0in 10pt''> </div><div style=''margin: 0in 0in 10pt''>Thanks for your input.</div> I run a 3/16 brass tube between the dual walls of the tail pipe then bend it at the end of the pipe. I stick a #11 Exacto blade in the of the brass tube then squeeze it and take the blade out. This set up works great. I have may Smoke pump travel in my radio set down to 35% and I get a nice thick smoke trail. Joe Lewis Kingtech K-80 owner |
ORIGINAL: Xairflyer ORIGINAL: Jetpilot24 ORIGINAL: Flynstuff <div style=''margin: 0in 0in 10pt''>Guys. Has anyone done a smoke system with the smoke spryer at the end on the pipe instead of the turbine tail cone?</div><div style=''margin: 0in 0in 10pt''> </div><div style=''margin: 0in 0in 10pt''>Is there enough heat??</div><div style=''margin: 0in 0in 10pt''> </div><div style=''margin: 0in 0in 10pt''>Thanks for your input.</div> I run a 3/16 brass tube between the dual walls of the tail pipe then bend it at the end of the pipe. I stick a #11 Exacto blade in the of the brass tube then squeeze it and take the blade out. This set up works great. I have may Smoke pump travel in my radio set down to 35% and I get a nice thick smoke trail. Joe Lewis Kingtech K-80 owner Xairflyer I have the Bifricated tail pipe. I only have the smoke tube on one side as in a full scale twin turbine jet. The pipe is 25 inches long. Joe Lewis Kingtech K-80 owner |
I myself am debating the placement of the smoke injector on one of my current projects .. I have always had great results with it right behind the turbine exhaust cone, however if it would work all the way in the back of the pipe with the preheat, then it would sure keep things a lot cleaner ... Running smoke through the pipe results in that nasty grimy build up and it needs to be cleaned regularly ...
~V~ |
ORIGINAL: wojtek Running smoke through the pipe results in that nasty grimy build up and it needs to be cleaned regularly ... ~V~ Joe |
How do you guys keep the tube from wobbling in between the 2 walls of the pipe ?
xmmm interesting...
ORIGINAL: i3dm How do you guys keep the tube from wobbling in between the 2 walls of the pipe ? |
Good info..Thanks guys.
I will try it at the end of the pipe. Thanks again |
ok let us know of the result please.
| All times are GMT -8. The time now is 05:10 AM. |
