JetCat 180rx
Does anyone know when the JC 180RX will be available ?
RE: JetCat 180rx
<div id="gt-res-wrap"><div id="gt-res-content" class="almost_half_cell"><div id="gt-alpha" data-tooltip-align="l,c" data-tooltip="<div style='max-width:300px'>Você está usando uma linguagem Alpha. Essa linguagem ainda está em estágios iniciais de desenvolvimento, mas gostaríamos de mostrar uma prévia para você!</div>" aria-label="<div style='max-width:300px'>Você está usando uma linguagem Alpha. Essa linguagem ainda está em estágios iniciais de desenvolvimento, mas gostaríamos de mostrar uma prévia para você!</div>" style="display: none"><span class="hps">That's a great</span> <span class="hps">question</span><span>, I sent</span> <span class="hps">this same</span> <span class="hps">question</span> <span class="hps">to the</span> <span class="hps">JetCat</span><span>,</span> <span class="hps">it</span> <span class="hps">told me it was</span> <span class="hps">to</span> <span class="hps">be available</span> <span class="hps">in August</span><span>,</span> <span class="hps">Masate</span> <span class="hps">now nothing</span> <span class="hps">they arrive.</span>
<span class="hps">What I</span><span>'ve been</span> <span class="hps">knowing</span> <span class="hps">that</span> <span class="hps">they walked</span> <span class="hps">and</span> <span class="hps">having some problems with</span> <span class="hps">some turbines</span> <span class="hps">RX</span> <span class="hps">180</span> <span class="hps">that</span> <span class="hps">were</span> <span class="hps">the first to be</span> <span class="hps">marketed</span><span>.</span> <span class="hps">Here in Brazil</span> <span class="hps">had 3</span> <span class="hps">180RX</span> <span class="hps">turbines</span> <span class="hps">that have</span> <span class="hps">problems and</span> <span class="hps">were returned</span> <span class="hps">to</span> <span class="hps">the</span> <span class="hps">JetCat</span></div></div></div> |
RE: JetCat 180rx
<span class="hps">What I</span><span>'ve been</span> <span class="hps">knowing</span> <span class="hps">that</span> <span class="hps">they walked</span> <span class="hps">and</span> <span class="hps">having some problems with</span> <span class="hps">some turbines</span> <span class="hps">RX</span> <span class="hps">180</span> <span class="hps">that</span> <span class="hps">were</span> <span class="hps">the first to be</span> <span class="hps">marketed</span><span>.</span> <span class="hps">Here in Brazil</span> <span class="hps">had 3</span> <span class="hps">180RX</span> <span class="hps">turbines</span> <span class="hps">that have</span> <span class="hps">problems and</span> <span class="hps">were returned</span> <span class="hps">to</span> <span class="hps">the</span> <span class="hps">JetCat.</span> |
RE: JetCat 180rx
There has been some turbine wheel issues due to a foundry problem. Checks before assembly are slowing down the deliveries, but more P-180RX turbines will be coming through very soon. Existing owners might want to talk with the supplying dealer, who can deal with JC about any questions. Basically there are a few turbine wheels with a less than perfect profile on one blade.
Dw |
RE: JetCat 180rx
Its more than just a bad wheel, the NGV needs to be opened up to let more oil flow to the rear bearing and the combustion chamber needs modification or exchange. I think Jetcat USA has contacted all P180 owners to advise them to send there motors in for the upgrades. The good news is that the 180 rx will start shipping the end of September. I have had several on order since January and am glad to see that this motor has finally been sorted out.
RE: JetCat 180rx
<span class="hps">I really hope</span> <span class="hps">the</span> <span class="hps">JetCat</span> <span class="hps">has solved</span> <span class="hps">all the problems</span> <span class="hps">of the</span> <span class="hps">RX</span> <span class="hps">180</span><span>, because</span> <span class="hps">I'm</span> <span class="hps">an F</span><span>-86</span> <span class="hps">turbine</span> <span class="hps">only</span> <span class="hps">waiting</span> <span class="hps">to fly</span><span>.</span> <span class="hps">If</span> <span class="hps">they</span> <span class="hps">take longer</span><span>'m</span> <span class="hps">thinking of putting a</span> <span class="hps">EVOJET</span><span>.</span>
RE: JetCat 180rx
Been waiting since January myself, it usually ends up being worth the wait. JetCat Germany seems to have the best technology when it comes to turbines but you would think that they could make a clock that actually keeps the same time where on or a calendar whos months are the same as ours, not the fantasy land time there on.
RE: JetCat 180rx
Bruno - I hope you are ahead of me, then i can move up on the list. I hear that the pump, and filter may be under the hood, making the installation just that much better. Im waiting.
John |
RE: JetCat 180rx
Its is under the hood, they took the stock pump and milled the corner off it, they also have the solenoids under the cover as well. The trick is the new software and the bubble detection feature they have come up with for priming since now you cant see the pump.I know how its supposed to work and sounds good on paper but Ill be running it on the test stand first!
RE: JetCat 180rx
Sounds like the P 180 RXI
Faster response, and a whole lot tidier, and simpler to install. Thats progress. Along with other improvements in our planes. No air, and no propane, hope to never go back to those inconveniences. Are we loosing anything? Such as mystique, the joys of complexity??? The questions of whats that for? We are becoming just like the electrics. Engine, fuel, radio, switch. No more awe of tubes of all colors, and actuators, and electronic duplicators. John |
RE: JetCat 180rx
I'll be very surprised if you see an RXi this year....my face to face talk tells me its a way off. The 90RXi has finished development and is a month and a half away, I'm expecting all my next few deliveries to be P-180RX's as they are. We have had no bearing or combustion chamber issues and have motors with over 10 hours running. None of the pilots I have spoken to in Europe have had problems either...!?
Dw |
RE: JetCat 180rx
Does the P140RX have any issues given it is exactly the same can?
On that note what exactly is the difference between a P140 and P180? Mav |
RE: JetCat 180rx
I just hope the JetCat has solved all the problems of the RX 180 as an excellent brand and turbine and want to continue using it.
<div></div><div>For turbine equal to 160 had not, I never heard that she had been a problem, this turbine was one of the best that the JetCat already produced.</div> |
RE: JetCat 180rx
There is no issue with the 180 RX combustion chamber as is, there fine. Problem is that the other mods like the mod to the rear oiler are causing the combustion chamber to be moded or replaced . Big difference between 140 and 180 totally different internals 140 run like clocks!!!!
RE: JetCat 180rx
ORIGINAL: Jetkopter There is no issue with the 180 RX combustion chamber as is, there fine. Problem is that the other mods like the mod to the rear oiler are causing the combustion chamber to be moded or replaced . Big difference between 140 and 180 totally different internals 140 run like clocks!!!! Also what makes the 180 give 4kg extra thrust from same can size 140 and same compressor and turbine wheel size? Mav |
RE: JetCat 180rx
Different compressor, ngv, combustion chamber, egv and wheel not to mention more fuel. Dont know how the 180 spools as I dont have any yet!!!!!!!!!!!!!! Im sure there close. We are all so concerned about how fast they spool, truth is there all very close and where getting spoiled,some of my first turbines you could nail the throttle and go get a cup of coffee and not miss anything, you actually had to be a head of your airplane. New guys today dont know how good they have and how far these motors have come in a short time.
RE: JetCat 180rx
I have a 140 yet to fly it (just bench start).
I wanted a 180 but was put off by all the issues. When will we see reliable 180's? Mav |
RE: JetCat 180rx
Chris
I have a 180 in my Euro and it runs like a treat. How abouts you take the Euro for a spin on the weekend, I'm sure you will like the way the 180 pushes her around. Shane |
RE: JetCat 180rx
I'm flying not only jets but also all sort of planes, from small to big scale, electric powered (up to half scale), gazoline powered, or jets. My Jetcat P160SX is by far not the slower reactive engine that I fly ! Even my electric engine (AXI 5330) is less reactive on my half scale plane with it big propeller !
Even my Zenoah 62cc with tuned pipe and 22x10 propeller is less reactive than my JC 160SX for the slower throtlle response ! Thi splane is a tow plane so I have hundreds of landings with it ! I've fly for a try a big plane engined with a 150cc 3W engine and was astonished how poor was the response of the engine was compared to what I know. So when I maindened my Futura I was very scared to what should be the turbine response during approach and landing, but finaly found it to be just as my well known gazoline engines ! Since that I've bench tested a P140Rx for a friend and my feeling is that it's an instant response turbine and that we don't need more ! We are even manualy regulating the movement on our stick just to ensure a minimum of realism and not to endure too much secondary effects ! Spool up time of any engine (electric, gazoline, jet) is one of the parameters a pilot have to work with. Speedy engines are simpler to fly maybe, but that should not let you not anticipating your flight and actions... I'm currently looking to replace my P160SX for a P180RX in my futura, I need the P160 for a scale project... I'm sure Jetcat will produce very soon a perfect engine, as usual for Jetcat. |
RE: JetCat 180rx
ORIGINAL: Aussie Bart Chris I have a 180 in my Euro and it runs like a treat. How abouts you take the Euro for a spin on the weekend, I'm sure you will like the way the 180 pushes her around. Shane See you shortly! Chris |
RE: JetCat 180rx
Hey guys, I have the newest version of the 180 RX. As far as I know, it's the only one out there right now. It is the latest verions with all the above mentioned mods done. It's got the new combustion chamber, a shaft tunnel mod, oil system mod, and new turbine wheel. This is the version that will be availabe soon as the production 180RX.
I have 4 hrs run (29 runs or so) time on it now. Bob sent it to me and told me to "torture it". I've been really pleased with it. It has very good acceleration and hasn't missd a beat. Very smooth and consistent starts each and every time. I am able to set both the throttle response for IDLE RPM to "FAST" and the HIGH RPM to "FAST" and slam the throttle stick from a stabilized idle and get very smooth transitions to max RPM. This was done at 8000' density altitude without issue, so it will be superb for you "flat landers". No matter what I do to the throttle, I can't get it to hiccup. As I mentioned, acceleration is very good even up here in CO. The best part is that is has a really nice "feel" to it in flight. Nice response and feel when making throttle changes at low RPM on final. A very nice turbine. The wait was worth it. |
RE: JetCat 180rx
I take it that the pump is under the hood, and when you say these are the mods, then may we be optimistic that the i version will be available soon? As in the next delivery of the180RX (i).
From what Dave said, it might be a two step - Internal mods like you mention, then the geographic move of the pump and filter later. That s the problem with mods. Once you hear of them you want them sooner than later. But i will take the 180 RX when its available. And maybe the move inboard can be done later with "parts". John I had heard that you had the prototype of the full - new 180RXI? |
RE: JetCat 180rx
As far as we know, the 180 will not be the i version at this time....only the 90 for now.
RE: JetCat 180rx
So...... Does anyone know when we will start seeing these start shipping in the US ?
RE: JetCat 180rx
ORIGINAL: furloughed ual Hey guys, I have the newest version of the 180 RX. As far as I know, it's the only one out there right now. It is the latest verions with all the above mentioned mods done. It's got the new combustion chamber, a shaft tunnel mod, oil system mod, and new turbine wheel. This is the version that will be availabe soon as the production 180RX. I have 4 hrs run (29 runs or so) time on it now. Bob sent it to me and told me to ''torture it''. I've been really pleased with it. It has very good acceleration and hasn't missd a beat. Very smooth and consistent starts each and every time. I am able to set both the throttle response for IDLE RPM to ''FAST'' and the HIGH RPM to ''FAST'' and slam the throttle stick from a stabilized idle and get very smooth transitions to max RPM. This was done at 8000' density altitude without issue, so it will be superb for you ''flat landers''. No matter what I do to the throttle, I can't get it to hiccup. As I mentioned, acceleration is very good even up here in CO. The best part is that is has a really nice ''feel'' to it in flight. Nice response and feel when making throttle changes at low RPM on final. A very nice turbine. The wait was worth it. Hi, Please can you explain what you mean by "the only one out there", "latest version with all the mods" etc etc. When did you get your 180 and when was it produced by Jetcat? As an owner of 4 180s I'm keen to find out exactly what engine you have compared to mine. There have been 180RXs out since the beginning of the year. I have spoken to Jetcat Germany about your post (to see if mine were due updates) but they are not aware of 'new versions' or 'latest mods'. There was a minor manufacturing issue which led to some 180RXs needing some remedial work but that was a just a casting issue - not an engine redesign. Look forward to the gen. Rgds, Mark |
RE: JetCat 180rx
Mark, it has the turbine wheel and combustion chamber Dave mentioned above. I'm a rep and Bob got one to run and then sent it to me. No magic, just a few updates already mentioned above.
RE: JetCat 180rx
Bob is gonna update several 180's sold here in the US. Contact your local rep or dealer about yours. I don't know what the story is on any of the 180's sold outside the US. Might be a few serial #'s affected, really don't know.
RE: JetCat 180rx
I have 4 hrs on my P180RX and running perfect. not a fart or hiccup.
Been really happy with mine. I had another in my Shockwave that was screaming as well til it met its dimise in Kentucky from a mid air. It purred like a cat too! I heard there was an update. Scott |
RE: JetCat 180rx
ORIGINAL: furloughed ual Mark, it has the turbine wheel and combustion chamber Dave mentioned above. I'm a rep and Bob got one to run and then sent it to me. No magic, just a few updates already mentioned above. OK thanks, so no real "first one out there...updated this and that etc"? Just a recently supplied bog standard P180RX from Jetcat without the potential casting issue that, as you say, only affected a few serial numbers. Thanks for clarifying. Fortunately, my engines are not affected by the casting issue. I'm with Scott - I have around 3.5hrs on one of mine with no issues at all. Started every time and run perfectly until shut down. Rgds, Mark |
RE: JetCat 180rx
Yep...no magic, just the latest version that will be shipping soon.
RE: JetCat 180rx
i have had one of the first p180rx to hit usa..i have about 4 hours or so on mine..not a failed start or hickup.. fast throttle response and no flameouts.. i was talking to bob wilcox and he was telling me the concerns were on the 100 rx and 180rx not the 140s...he advised me to send it in so why risk anything bad..i boxed it ...i am a jetcat guy through and through. i have no problems sending in for service...its and engine..these things happen...
RE: JetCat 180rx
Guys,
For anyone still waiting for a 180RX, http://jmajets.co.uk/board/viewtopic.php?f=7&t=3261 Rgds |
RE: JetCat 180rx
Hi,
It has been quit here fore a while... Anyone who has any news about when JetCat begins to ship out to the dealers? |
RE: JetCat 180rx
i just got my 180rx 2 week to go from update
RE: JetCat 180rx
ORIGINAL: Helirupert Hi, It has been quit here fore a while... Anyone who has any news about when JetCat begins to ship out to the dealers? I got an email from Bob yesterday... mid-November. |
RE: JetCat 180rx
I got my 180rx back and had 2 awesome flights on my Skymaster 1/6 F-16 on Sunday. Unfortunately on flight #3, I had a flame out. GSU says "low RPM". Plane is unharmed, but I'm very annoyed since the plane has been out of service since March due to engine issues. I am hoping it's me and not the engine. I'm stripping down the fuel system this week to see if I'm getting air somewhere.
RE: JetCat 180rx
hello there... this is interesting... i did read people were getting low rpm readings on the 140rx due to wrong battery voltage and or low pump voltage ..jetcat does recomend with these new ecus that we use 9.9 lifo po...i have never had a failed start or glitch with mine...maybe call bob at jetcat usa ..i am positve he will get you straight...pat....
RE: JetCat 180rx
I am using the 9.9v battery that is supplied with the 180. I also have a few 140rx engines and they've been flawless.
RE: JetCat 180rx
So what is the true thrust on the 180rx? it says "40+" on the website. Dantley, after reading that you didn't get unlimited vertical with the P200 in the Mig, I'm getting nervous...
RE: JetCat 180rx
Mike, I wasn't getting unlimited vertical because the pipe reduces the thrust dramatically. My last F-16 had a p-200 and it was unlimited. The 180 in my current F-16 feels unlimited.
| All times are GMT -8. The time now is 04:36 PM. |
