RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   An Exercise in Install Practice.... (https://www.rcuniverse.com/forum/rc-jets-120/11497439-exercise-install-practice.html)
lov2flyrc 04-30-2013 12:08 PM
1 Attachment(s)
Thought this might be an interesting and educational exercise in installation etiquette....
When it comes to turbine powered jets, there are some well seasoned "Do's and Donts" we should always consider when laying out our installs. While a good segment of us have acquired this knowledge through the years, we have a large and growing base of "rookies" (for the lack of a better term) that would probably benefit from the knowledge we gained by our own mistakes...
Great time to share what we know; just might save a plane OR .....
Lets start things off with this picture below. I can see numerous DONT's with this setup, can you identify any of them??
stevekott 04-30-2013 12:15 PM
RE: An Exercise in Install Practice....
Ok Todd, I'll take a stab,
What get's me right off the bat, are the antenna wires for the receiver. While it's true 90 degrees is a good orientation these antennas appear to be running paralell with a lot of other wires, including wires with grounds in them. This has the potential to kill the signals going to the antennas.
Better way would be to use some plastic tubes like they use in RC cars and re-orient the antennas so they are still 90 degrees apart from eachother but are like "Car antennas" clear of all masses of metal, batteries wires and electronics. Especially on the last two inches of antenna wire.
SECRET AGENT 04-30-2013 12:16 PM
I'll keep my mouth shut because mine looks worse, HA!!
ianober 04-30-2013 12:18 PM
Looks like the ECU is just stuffed in front of the fuel tanks. It should be secured somewhere and heave the connectors routed neatly to it. Overall the install is just messy, hard to tell what is going where.
Grodus 04-30-2013 12:21 PM
You have may attention Todd. Having done only 2 installs, I am very much a rookie so I will be watching closely and book marking this one. Good topic.
Cody
Wap4life 04-30-2013 12:22 PM
Great tread Todd!
I am one of those rookies for a lack of a better word.  I think the electronics is to close to the fuel and could cause a serious problem if leak develops.
lookilook 04-30-2013 12:33 PM
Agree with Ianober plus any fuel leak from that 'T' on top of ecu might be fatal!
RC_MAN 04-30-2013 12:34 PM
It has a Futaba receiver :)
fuel pump next to power expander causing RF issues.
Vincent 04-30-2013 12:39 PM
Fuel tubing resting on the rx running to the pump...that would weird me out and i would re-route it for sure.
Vin...
Jetkopter 04-30-2013 12:51 PM
Todd , I bet that plane has had a bunch of flame outs, and I have a good idea why. The ECU is trying to bail out and save it self. :D all kidding aside the rule of thumb is when it looks like spagehtti it works like spaghetti. If it where mine i would rip it all out and start over , makes chasing the problems that much easier.
wfield0455 04-30-2013 01:07 PM
Fuel fittings that are pressed over fuel barbs aren't safety wired.
Flynstuff 04-30-2013 01:08 PM
No wire ties on the UAT to pump and elsewhere. Fuel pumps to close to electronics. (Static Issue)
ECU Flopping around
If using a carbon board that's a No no
GRVW 04-30-2013 01:12 PM
My list:
Receiver antennas are not clear of power/servo leads.
Fuel/smoke tubing not safety wired in a few places.
Fuel tubing running right across and under receiver (issue if fuel leaks)
Pumps too close to Powerbox (possible RF issues I guess).
ECU looks to be jammed in and not properly secured.
Generally, too many crossings over between fuel and electrical lines.
Too many components not secured.
Isn't it easy to criticise! Not sure all my installs would pass muster.
siclick33 04-30-2013 01:13 PM
Maybe I'm going blind but I can't see any major don'ts. Sure it's a bit untidy and things like safety wiring would be a bonus but I would think that model would fly perfectly well as it is.
dbsonic 04-30-2013 01:20 PM
Antennas for Futaba RX are loosely hanging about and not ideal. You really want those in tubes(particularly the ends) and fixed at 90 degrees. Hopefully that's not real carbon shielding the antennas. Fuel lines running over sensitive electrical items seems like a bad idea.
JackD 04-30-2013 01:47 PM
ORIGINAL: siclick33
Agree,
Not pretty, but not necessarily unsafe (at least from the picture)
Personally, I´m not a big fan of the over designed installs that are a pain to disassemble. They might look good, but are impossible to service. I want a balance of looking good but being easily serviceable. My friends joke because of my "liberal" use of Velcro haha. (i really don't see anything wrong with using velcro to hold your elevator servos hahahaha).
But seriously, I want easy access to all the layers of my installs.
The only thing I would improve is fixing the ecu. Don't like it stuffed. But again, if it can't go anywhere, besides being ugly, what is the problem?
dubd 04-30-2013 02:25 PM
I agree with Jack about easy access.
Aside from what has already been mentioned, I don't like that the fuel lines from te pump can move with gravity, possibly kinking the line. I'm also not of fan of labels close to the rx. Looks sloppy. I would also add safety wire to the reducer fuel fitting.
madmodelman 04-30-2013 02:30 PM
Lets face it, it's just a complete rats nest.
sirrom 04-30-2013 02:36 PM
Well before anyone starts bagging on that install especially the fuel pump to close to the receiver, I have seen seasoned flyers put their fuel pumps right next to their RX or the ECU. It is a messy install but I have seen worse. As far as the guys who have their installs engineered better than a space shuttle cockpit, think how hard it is to get that back out in the event of a problem. There should be a neat well thought out installation somewhere between unrecognizable mess to over thought out installs.
Patrick
GSR 04-30-2013 03:22 PM
I am with Jack- I will go with serviceability over pretty any day. Scotty
PS and that is not just an excuse for an ugly install:)
HORNET FLYER 04-30-2013 03:43 PM
I remember when 8411s were all we had to build these jets and they worked very well, still use them to this day when some guys ask what I'm using for servos and I tell them 8411s they look at me crazy lol
Btw don't forget that I think as good as a 8411,8611,8711 is, it still has one plastic gear.
Paul
Countryboy 04-30-2013 05:26 PM
1 Attachment(s)
ORIGINAL: GSR
I'm not saying it's pretty, but I will take tidy over that spaghetti mess anyday... even if does make it a ;ittle harder to service.
gio 04-30-2013 06:06 PM
1 Attachment(s)
My Falcon 120.
lov2flyrc 04-30-2013 06:29 PM
Lets be clear; my intent is not about "neat-n-tidy"! The purpose is to pass on knowledge of install dont's that can lead to problems or dangerous situations. And the "do's" that just make things easier, better ect... We have all had at least one of those "DUH" moments where you smack yourself in the head, or your buddy does it for you. ;) Those are the things we need to be passing on so they don't get repeated unnecessarily.
I'll cover some of the things I see that are far from ideal tomorrow.....
dbsonic 04-30-2013 07:13 PM
I think I see a cheetoh in there.
