RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   Unexpected engine performance. (https://www.rcuniverse.com/forum/rc-jets-120/1721830-unexpected-engine-performance.html)
Robrow 04-14-2004 04:33 AM
1 Attachment(s)
Hi, I'm not sure if any of the engine guys amogst you can help with something that has been puzzling me.... I have built an engine which uses the AMT Mercury(20lb thrust) wheels and naturally assumed I would get similar performance to this commercial engine. My engine has now completed some 2 hours flight testing, (around a dozen flights), with max power dialed down by 10krpm, so on paper for this rpm I would expect maybe somewhere around 15lb thrust max ? But the Super Reaper the engine is installed in has a t/o weight of around 23lb and goes straight up after rotation.... this just doesnt seem to add up.
Another guy flying a Jetcat P80 powered Super Reaper asked what my engine was because in his opinion it had better flight performance than his ????
Fuel efficiency seems good with only 1.5litres (around 40ozs) used in a 10 min flight, this may be because of the lower set max rpm.
I have downloaded the flight data from the Fadec ecu and the engine is definately only *****g out at 140krpm with max temps in the mid 600C area, this rules out over revving.
Any theories as to why this is happening ?
Rob.
GrayUK 04-14-2004 06:46 AM
RE: Unexpected engine performance.
What thrust is it putting out?
Flyjets 04-14-2004 07:11 AM
Hi
What don't you get a digital fish scale with some SS wire and hook it around UL mains.
This should give you an idea of your static thrust output.
If that doesn't appeal to you, use a digital scale cover the nose with foam and measure thrust that way.
Sounds like she has good power..........
Ian
unknown 04-14-2004 07:23 AM
I think its the tail cone design. Like a tune pipe. Question is your turbine wheel 66mm?
Robrow 04-14-2004 09:22 AM
1 Attachment(s)
Not sure what the thrust is, I'll bolt the engine in the test rig and check it, but I would not be expecting more than 15lbs at this conservative rpm setting.
The turbine wheel is 65mm, the exhaust is modified AMT (demountable) but all the critical dimensions are the same. I have modified the diffuser system, not sure if that is producing more case pressure.
Another unusual trait the engine exhibits, similar to the TJT 3000, is the lack of noise, it really is very quiet in the air, just the exhaust efflux roar on higher throttle settings.
Rob.
jason 04-14-2004 10:29 AM
Hi Rob,
Just out of intrest which NGV are you using?
jason
unknown 04-14-2004 10:30 AM
I think don't quote me :D, but your turbine wheel dimension is alot more than the standard 66mm. So more thrust for less RPM.
How do you modified the diffuser ????.
Robrow 04-14-2004 11:46 AM
1 Attachment(s)
Hi Jason,
good to hear from you again, hope you got sorted with a longer thermocouple for your MW44 ?
The ngv is again a modified AMT item, the critical vane geometry is unchanged but whereas AMT bolt their shaft tube solidly to the ngv mine uses a TJT tube with a sliding interface and bearing carriers.
Turbine wheel is definately 65mm as you can see in the size comparison with the Wren 66mm wheel and the diffuser is only really modified to try and improve airflow to the front face of the combustion chamber due to a chamber/diffuser gap reduction.
Perhaps I should build a second engine with the parts I have to see if this first one was just a fluke ;)
Rob.
unknown 04-14-2004 12:17 PM
So AMT ngv is bolted on to the the bearing housing. I like that setup better, Before assembling the case you can tell if your turbine wheel and the ngv is align properly sweet
I always wonder how AMT all in one case and cone work.
Looking at your caliper reading your turbine wheel 65.20 but your ngv 65.15 ??? . How many injectors your engine as ?.
I'm doing some experiment my self with a 32 lb engine. Its running ok with EGT of 480 max power.
Glorfindel 04-14-2004 02:35 PM
Hummm...I know that some 66mm commercial engine are putting 25lbs trust. You have about 2 things to get more trust. Optimized diffusor or optimized combustion chamber.
You played with diffusor...That can be the answer..can you post a pic of you diffusor??
140K with 66mm engine seems to be quit high isnt it??? Since we run 54mm at 160000...
Wayne22 04-14-2004 03:09 PM
Not familiar with the AMT stuff, but the highest I have seen a 66mm turbine running is 127K....... so at running at 140K would produce a lot more thrust - all other things being equal.
unknown 04-14-2004 03:35 PM
I think he is using the 65mm wheel. But at max RPM 140k is very high for that size wheel. At some point there must be compressor or turbine wheel stall.
Robrow 04-14-2004 04:23 PM
1 Attachment(s)
If you look at the throughput area of the AMT wheel you can see it is much less than the Wren 66, so although they are of a similar o/d the actual 'working' area is much reduced. The AMT wheel is designed/built from the outset for high rpm(150k+) the same as the 60mm Garrett compressor wheel up front. I burned many litres of fuel at max rpm before commiting the engine to an airframe.
The shaft and turbine wheel were machined/ground to within a couple of microns runout after a few heat cycles to allow the hot components to 'settle'. I then spent an evening concentrating on getting the rotor balance as good as my equipment would allow.
The turbine wheel/ngv tip clearance is just enough to avoid any 'rubbing', this I am told can lead to better fuel efficiency.
I thought the engine would sound similar in the air to an AMT but it's completely different, possibly due to the turned from solid alloy casing.
Next project engine will use the wheel on the right :D Shaft has just been turned ready for final grinding to size.
Rob.
johnnyjet 04-14-2004 07:41 PM
Fantastic work.
Johnny
Robrow 04-15-2004 02:10 AM
Hi Unknown, good to hear from a fellow engine builder, the caliper measures are for an unfinished wheel.
Can we see some pics of your 32lb engine ? What size is it ? Sounds like you've got plenty of scope for squeezing more power out of it, your egt is way too low.
Rob.
Robrow 04-15-2004 02:50 AM
1 Attachment(s)
Thanks for the compliments Johnny, I have a lot of good friends that help me, so as with most successful things in life it's the culmination of a team effort.
This big titanium compressor wheel is slated for another big thrust project.
Also building a second 54 size engine to pair with my PST J600 for the Fokker 100 twin, this should be a load of fun to fly I reckon, not enough civil stuff around the shows if you ask me ;)
Way too many projects and not enough time as always !!
Rob.
jason 04-15-2004 03:45 AM
Hi Rob,
Yes I did get the longer thermo couple sorted thanks everything is fine now and just waiting for monday for the test flight.
I have a simjet 2300 which is rated at 27lb. I was unsure if this was right as they are normally about 23ish so I phoned Lars to ask him and he confirmed it was 27lb.
jason
Robrow 04-15-2004 04:06 AM
Hi Jason, glad you got sorted, you'll have to let us know how the test flights go.
The Simjet sounds like a powerful beast, do you know if it uses the KKK 2038 compressor wheel as in the KJ 66 and Jetcat P80 ?
Rob.
jason 04-15-2004 05:48 AM
not too sure what it is but its not the same as a p120 one but I know it is a wren 66.5 mm wheel and NGV.
jason
Robrow 04-15-2004 08:31 AM
OK, there a few different wheels around that different manufacturers use, I more or less know most of them and what they can put out in terms of thrust.
Rob.
unknown 04-15-2004 09:13 AM
Hi ROBROW i will post some pictures of some of my engine. For compressor i'm using the lager wheel to the kkk 2038. I think its the GT 30 series not sure i will check my receipt.;)
Robrow 04-15-2004 11:05 AM
That will be great, looking forward to seeing the pics.
Rob.
GJr. 04-15-2004 06:50 PM
If possible, please post some pictures of the difference between your engine modifications and the original AMT setup. It would be interesting to compare to see where the actual performance increase is coming form, especially the diffuser/chamber, ngv/turbine wheel, shaft/tube carrier system, and case design.
Have you measured the actual/true thrust difference of the modified engine versus the stock AMT Mercury?
Thanks for posting your findings.
Robrow 04-16-2004 10:25 AM
1 Attachment(s)
I'll post some pics when I next take the engine down to check thrust and see how the internals are fairing.
I aimed for as reliable a set-up as possible and after 100+ cycles the Fadec autostart ecu has not missed one start, light-up is instantanious every time. As a precaution max rpm was detuned by 10krpm and acceleration/deceleration times increased a little for flight assesment. I'll give it a few more hours flight time, then pending all still being OK mechanically I'll up the max rpm and shorten the accel/decel times and see what it is really capable of.
I'll also try to get a few more objective pilot opinions of the airborne performance in the meantime.
Parts build for the larger engine is now coming together, here's the shaft compared with an MW54 size ! Now I will just need something big to fly it in [>:]
Rob.
unknown 04-16-2004 01:56 PM
Robrow
Having some problem posting pictures from my DV camcorder. So PM me your Email and i will send it to you ;)
Robrow 04-16-2004 01:59 PM
done
Robrow 04-17-2004 02:35 AM
We are hoping to put a few more gallons through the engine flying today, I'll take my cameras and get some footage.
I'll try and shoot the start sequence, t/o, climb, general aero's and landing, then put them up on my website and post the url.
Rob.
Robrow 04-18-2004 01:33 PM
1 Attachment(s)
Just enjoyed a good days flying, pics of Super Reaper instalation below.
We shot some digital video but I've no idea how to download it onto the pc, possibly I need a video capture card installing ? Any of you video experts got suggestions, the last pic is of the various connection sockets on the camera, looks like the dv socket is firewire ? I'd welcome any advice.
Rob.
mr_matt 04-18-2004 02:46 PM
You need some sort of software that can interface to what looks like a sony camera you have their. I use Adobe Premier. You just start the software, plug in the camera and then you run everything from the computer. The software controls the camera.
Robrow 04-18-2004 03:03 PM
OK, thanks Matt, I'll check the destruction book, possibly I won't need any more hardware.
Rob.
mr_matt 04-18-2004 03:38 PM
Oh yeah you need a firewire (1394) port on your computer. Not sure if these new cameras can be controlled with the USB interface your camera has, if it is USB 2.0 and your camputer has that, it is almost as fast as forewire.
You definitely do not need any sort of A/D converter, that is the beautiy of the digital camera.
I'LL POKE AROUND TO SEE IF THERE ARE ANY SHAREWARE (oops sorry) packages you can try.
Robrow 04-18-2004 04:02 PM
OK, thanks Matt.
Rob.
MAMMOTH TOUGH 04-18-2004 09:07 PM
WOW you guys rock with your turbines but usb 2.0 is faster then firewire IEEE 1394=400 Mbps usb 2.0 = 480Mbps
Robrow 04-19-2004 12:37 AM
Thanks, I guess I need to checkout what's available.
Rob.
Robrow 04-21-2004 03:40 PM
I have just managed to upload a short take-off movie here
www.btinternet.com/~robrow/Cap0002.zip
This is my first attempt at video capture and it's zipped, so the quality is not the best but hopefully it should give some idea of the engine performance. RPM was set 10k down from full power and the 10" long grass had just been cut but was still lying on the runway so there was mega drag on the u/c resulting in an almost 90deg kick to the right at the point of rotation.
Any comments about the capture quality and climb performance appreciated. I can also upload some longer movies showing the aerobatic performance.
Rob.
TAD1K 04-22-2004 01:12 AM
I think this is the Artes Eagle with AMT wheel 30 lb +
Robrow 04-22-2004 01:23 AM
I wish my engine did have 30lbs thrust but it is definately not the Spanish engine. I will post pics later of the two engines side by side and you wil see there is a major size difference. Mine is only 100mm casing dia.
Rob.
unknown 04-22-2004 07:11 AM
Hi Robrow
Glad to see your engine working OK. I try to sent and post those pictures with no success :(. I have the same setup with the DV and firewire (1394) interface with out analog input . The software for the camera is easer to make movie file than JPG image file :D. I try sending the movie file my Email server ERROR (FILE TOO LARGE) [:@]
Why don't you run your engine at full RPM?. That plane can handle the extra power.
unknown 04-22-2004 07:31 AM
Your are right. He is using the artes setup. To get 30lb just change your turbine wheel and the NGV to the ARTES SUPER EAGLE WHEEL AND NGV setup your ECU the 128 RPM :D)
Robrow 04-22-2004 12:01 PM
Sorry to hear you are still struggling with the file upload. I ended up using the usb conection for this and all worked OK, I also used Winzip to make the file as small as possible, this helps when sending and uploading because of server limits.
As this engine is a one-off and no other like it in the world I wanted to see how things went at 140k, particualrly in flight mode before opening the tap more. As you will see from the aerobatic footage there is sufficient power now. Possibly this weekend I may uprate it to 145k to test. I did run it for a long time at 150k during the ground test running program without any problems so hopefully things should be similar in the air.
I'll try later to upload some longer more aerobatic footage.
Rob. ;)
