RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   THE WAIT IS OVER! (https://www.rcuniverse.com/forum/rc-jets-120/2325119-wait-over.html)
Gary Arthur 11-07-2004 06:52 PM
THE WAIT IS OVER!
1 Attachment(s)
The first North American Simjet 700 has landed in a customers hands....MINE! Yeah!
I was with Kevin while he was testing (they test every engine before it goes out) the most recent shipment of engines. Mine was one of them. After testing, delivery consisted of him handing it to me. The others will need to be shipped.
What a cool little engine. The start up was so quick. It has a 280 motor to spin it up. It comes with the Full auto start FADEC ECU & terminal, LiPo batteries and charger, onboard propane tank and valves.
Now I cant wait for my L39 to arrive from Savex.
Lt. Dan 11-07-2004 07:30 PM
RE: THE WAIT IS OVER!
Wow, that's small. What are the specs on it?
Gary Arthur 11-07-2004 08:36 PM
These are the specs from the Simjet web site:
Technical Specs.
Diameter: 75 mm (3 inches)
Weight: 550 g.
Fuel consumption @ 7 lb thrust: 140ml/min (4.7oz))
Max RPM: 190.000
Idle RPM: 45.000
EGT @ 7lb thrust : 600° C. (1100° F.)
Pressure abs. 2,3
Max thrust: 7 Lbf. (31N) - (3.17kg)
Min thrust: 0.5 Lbf.
On the test stand it had 1/2 lb at idle and 7.2 lb at full. We didnt run it for long but I will have it on my test bench tomorrow and run it up some more.
HotelSierra 11-07-2004 09:02 PM
What is the price and availability?
Gary Arthur 11-07-2004 10:20 PM
You would need to contact Great Northern for that Info. All I know is that since I have mine, they are now available over here. Let the fun begin!!!!
Aero65 11-08-2004 07:04 AM
Man that 700 looks cool
Oh the pocket book is gonna hurt again!
Gary Arthur 11-08-2004 08:35 AM
Yeah, it does look cool. I put it on my test bench last night and does it ever look small. Kinda cute! LOL! Maybe it will be a 3000 when it grows up.
sideshow 11-08-2004 09:17 AM
ORIGINAL: KAPTAN KAOS
I didn't see the info on their site.....how much did you pay for it?
SJN 11-08-2004 09:49 AM
Neat engine..... Its great that they include a lipo pack and charger with it too.
A month or so, and ill own one too [8D]:D
SJN 11-08-2004 09:52 AM
oh yea.... did you buy a pipe from wren for the l-39?
or are you going to make your own ?
When it was test run in the bench, did they messure the thrust ?
rcav8tr 11-08-2004 10:20 AM
Hi Bob, Hotel Sierra
The current price is $2399 which includes engine, Autostart ECU, ancilliaries, 2200mah LiPo battery and charger. We haven't had time to update the site yet, but will get that done soon. Availability is on an order only basis. The demand worldwide has caused a waiting list for the 700 at SimJet. We have put a standing order in place at SimJet for our customers so that the wait time is minimized.
If you have any other questions, please do hesitate to contact me.
Gary Arthur 11-08-2004 10:21 AM
I think I will be getting the pipe from Wren. There have been good things said about these pipes.
The test run was short, but it read 7.2 lbs at 190,000 RPM. The load cell in this stand reads low so I will have more details once I run it myself on my test stand. I will record the temp, thrust etc.
I will likely use a throttle curve so I have half thrust at half stick. This is the advantage of running it on a test stand first. I will read the thrust and adjust the curve accordingly. Sorta like a reverse expo.
SJN
I too like the idea of LiPo's as I will try to keep the wieght of my L39 as low as possible.
SJN 11-08-2004 10:30 AM
goodie :-)
Shok 11-08-2004 11:57 AM
whats the length from the top of the starter to the end of the bell?
Lt. Dan 11-08-2004 12:00 PM
ORIGINAL: Shok
Looks like its about another thumblength. :D
K Jorgensen 11-08-2004 02:24 PM
1 Attachment(s)
Hi all
That 700 is just great. I have the first one they made an I have allot of flights on it. And that thing just runs so great.:D:D
So KAOS. You are going to have a lot fun.:D
And the best part is that a L39 will fit in a car with the wing on it.[8D]
If you need any help with the L39. Then just say So KAOS...
rcav8tr 11-08-2004 03:43 PM
Hi Shok
Length over all is 8 3/4". From End of starter to the blue cover is just under 3".
Ed
jlmaviation 11-08-2004 04:13 PM
Who? What? Where? do I get info on the Savex L-39??????
KFalcon 11-08-2004 07:34 PM
http://www.schreiner-savex.de/index_e.html
Gary Arthur 11-08-2004 08:02 PM
ORIGINAL: DMP!
Can you speed up the manufacturing and delivery from Savex. Not that I am waiting for a long time, just that I am anxious.
I am sure this combo will be great. Simjet 700. Savex L39,spring air 301's. All up weight should be 8 to 8 1/2 lbs. Or 10 lbs wet with 1 liter of fuel!
Gary Arthur 11-08-2004 08:04 PM
There have been some not so nice things said about the schreiner-savex, but if you go to [link=http://www.savex.cz]www.savex.cz[/link] you will not be disappointed.
Gary Arthur 11-08-2004 08:11 PM
I ran the engine a few more times on the test stand. 3 quick starts using onboard propane tank. Idles at 60,000 full rpm is 190,000 with a EGT of 640 C SWEEETTT!
stumax 11-08-2004 08:52 PM
So what's the expected waiting time guys?
sengle 11-08-2004 10:16 PM
Be careful - There are two L39 manufacturers. The other is www.savex.cz which is the one that the 36 page RCU thread is referring to!
Cheers from NZ!
Gary Arthur 11-08-2004 11:29 PM
ORIGINAL: sengle
Cheers from NZ!
Like I mentioned, if go to www.savex.cz you will not be disapointed.
