RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   FeiBao Rafale issues (https://www.rcuniverse.com/forum/rc-jets-120/6510448-feibao-rafale-issues.html)
454 03-13-2008 05:21 PM
RE: FeiBao Rafale issues
do you use expo
its like that but all the way across I have futaba 9156s on my eleivons and they are just to fast for a smooth flight at 200 mph
where not slowing much stock servo speed is .12 slowed its closer to .19 I don't think all jets need this but it sure help on the rafale
for the other guys
you need more eleivon than you think full canard is not good for high speed
think of this plane as a delta only the real rafale is fly buy wire
the canard is realy added for slow speed
mine dose fly good at a moderate speed with the low canard throw (per tams rec)
don't turn it off unless your fast
you DO NOT WANT IT LOCK IN ANY POSITION ACEPTE NUTRAL I tried it it dont work
Rush! 02-05-2012 10:27 PM
1 Attachment(s)
Guys,<div></div><div>Just built and maidened The feibao Rafale! I also experienced the brutal takeoff but it wasnt to bad... just push the nose down...</div><div></div><div>I used high throws to fly with full canards. I found the low rates to be insufficient to move the plane quick enough.</div><div></div><div>Also, My Canards are linked to D/R and Trim of the elevators. Do you guys couple the canards with the elevator trims also? I am not sure of this at the moment if i should have linked the two. </div><div></div><div>Additionally, how long do you guys fly? I have a 120SX in mine....</div><div></div><div>Thanks! </div>
