RE: FEJ Customer Voting
A lot of us don't have access to a flying field that will accomodate most of the large jets that keep coming out. I'd like to more planes for 14 - 18# turbines; like a Mig-29, F-4, F-18, Mig 15, or Bandit type sport jet.
Joe |
Concentrate on building a good reliable model first then go on with other projects. FEJ needs some attention to proper R&D other than pretty airplanes with nice panel lines. Do it the right way and don't hurry with design concepts. I have first generation FEJ F-15C it needs much work. I have had to modify everything on that model, I am close to finishing it but I am considering using it as a glider.
take a close look at the moments and lines of the ra-5 vigiante great looking and would make a great flyer !!!
Sukhoi Su 25 Frogfoot - so ugly that it's pretty if you know what I mean.
A large scale Eurofighter - the Comp-ARF one being proof of it as a great flyer - hundreds can't be wrong. MiG 17 or 19 or the Chinese- built equivalent (easy access for scale references for FEJ ) |
F2H Banshee......
Somebody should try to revitalize the old D/L series of planes. There was a Cyclone III sport jet kit that was good looking and a fantastic flyer. It could be flown as a ducted fan or turbine jet. I mean one kit could be changed from d/f to turbine and back to d/f if wanted. The conversion took about 30 minutes. I saw the plane flown as turbine, landed and converted to d/f and flown in 35 minutes. It had a large hatch areas that ran from the nose to the strake of the vertical fin that allowed fantastic access and provided lots of room. It would be perfect for EDF use to day as well as turbines from 10-20+ lbs fo thrust. The wingspan was around 60", fiberglass fuse with balsa covered foam wings, and weighed in the 11lb plus range, depending on power source.
D/L also designed and kitted an MB339 kit, before the kit was built overseas and marketed by Cermark. Again, it was a geat flyer and the D/L kit did not have the problems of the Cermak version that was changed to accomodate mass production. This kit would be great for the smaller turbines as well as the new EDF stuff. D/L also had a small scale F20 and a beautiful smaller MiG 21 that was flying, but never put into production. Both of these would be great for the 10- 19 small case turbines available today, as wll as EDF. |
| All times are GMT -8. The time now is 02:17 AM. |
