1 x MiG
Dear Jet - Community,
My name is Jürgen, I'm living in Germany and I would appreciate you posting a report about my first construction in this forums. I posted it in several German forums and got positive feedback. Hopefully it will be the same here. Besides...the Topic is called MiG, because its Made in Germany ;) Some Background information: A few weeks ago, on Jetpower trade fair, I met a friend of my father and we had a little conversatin about Jets. He told me about searching a model that is more broad in the waistline, so that he has more space to work in inside the aircraft. Moreover it should have a big hatch, because that would make it easier to put in the turbine-engine and maintain it. Speed is less important than the ability to make neat manoeuvers. The Jet should keep stability in the air and better not pull into the wrong side while it is doing a vertical side slip. It also would be nice, if the jet is able to take off and land on a short taxiway.....and will fit into an Volswagen Golf after landing ;) After a few days I started designing an aircraft that combines all his wishes and a few more. I designed a mid-wing aeroplane, that is completely made out of glass fiber reinforced plastic, with a hatch that is nearly 3ft long. Furthermore I took big aerobaticairfoils with airbrakes. All moving elevators and exchangeable fins are also part of my idea. Finally the plane shall have an electric landing gear, but ut should have the opportunity to fit in a mechanical one, too. And thats what it looks like: http://www.rc-network.de/forum/attac...p;d=1257865156 http://www.rc-network.de/forum/attac...p;d=1257865156 http://www.rc-network.de/forum/attac...p;d=1257865156 After getting all measures and thanks to my experiance in work with glass fibre I am now able to say which weight the plane will have. Therefor I made this measure index. http://www.rc-network.de/forum/attac...p;d=1257865156 http://www.rc-network.de/forum/attac...p;d=1257865175 http://www.rc-network.de/forum/attac...p;d=1257865175 The first aerodynamic measurements I made with FLZ Vortex. Secondly I built a small model and sent it to a friend of my father, so that he can pu it into the windtunnel. after a few days he wrote me his suggestion for improvements and I directly improved my model. And here the measures: Overall length: 2150 mm (84,64 inch) Wing span: 1750 mm (68,89 inch) elevator span: 812 mm (31,96 inch) aerofoil: 90,33 dm² High from ground: 736 mm (28,97 inch) weight with P80 and Kerosin 9825 g area loading 108,77 g/dm² V Max. about 97 m/s V while landing with air brake 14,63m/s I hope you will like it, =) with best regards Jürgen |
RE: 1 x MiG
keep it coming would be interested to see it fly
RE: 1 x MiG
You have my attention. Looks very interesting.
RE: 1 x MiG
Very nice work!! Will be watching with great interest.
RE: 1 x MiG
Hi! Jurgen; where the air intakes would be? Underside ?
Interesting plane. ENT |
RE: 1 x MiG
Привет Юра!;)
We will attentively observe of your project! Very interestingly!!![:-] Aleх. Ukraine. |
RE: 1 x MiG
1 Attachment(s)
@E.N.T,
Hi! You can see the air intakes on the pic, NACA @UKR-Jet чур мэнэ чур! нааа-шиии http://www.rcuniverse.com/forum/js/f...eeth_smile.gif How about a thrustpipe and the legs for the Orka? http://www.rcuniverse.com/forum/js/f...wink_smile.gif Greetings Jurgen |
RE: 1 x MiG
thats cool looking.. kinda has the old bugatti racer lines to it.
RE: 1 x MiG
Jury,
Pipes it is necessary? There are no problems, will make! landing gear are necessary? There are no problems, will help your project! НАШИ ВЕЗДЕ!!![sm=bananahead.gif] Alex;) |
RE: 1 x MiG
Hello
Your project is really interesting espcially your tests in the wind tunnel.... Keep us informed !! Thanks Jean Philippe :D |
RE: 1 x MiG
OK
First things first: Here you can see the ribs i cut out. http://www.rc-network.de/forum/attac...p;d=1257890948 http://www.rc-network.de/forum/attac...p;d=1257890948 Those will be fixed on a styrodur surface. The styrodur on his part is fixed on a stage i made. http://www.rc-network.de/forum/attac...p;d=1257974918 http://www.rc-network.de/forum/attac...p;d=1257974918 http://www.rc-network.de/forum/attac...p;d=1258060128 http://www.rc-network.de/forum/attac...p;d=1258060128 After fixxing the ribs I installed the planking...... http://www.rc-network.de/forum/attac...p;d=1258060128 ...and finally cut the edge. http://www.rc-network.de/forum/attac...p;d=1258060128 tomorrow i'll go on! greetings Jürgen |
RE: 1 x MiG
Nice model....
Maybe a bigger airplane could make the diference.... João Matos joaomatosjets.blogspot.com |
RE: 1 x MiG
ORIGINAL: JM-PORTUGAL Maybe a bigger airplane could make the diference.... |
RE: 1 x MiG
Sorry i should explain.
Your project bigger and whhaaaooo..... I think the market needs bigger planes 2.0-2.5 meters. Bigger plane better fly... Congratulations for your project. I know that you willl have sucess with this beauty plane. João Matos joaomatosjets.blogspot.com |
RE: 1 x MiG
Very nice, and interesting look to it. It look like a mix of the F-9 Cougar, F-18 Hornet, and the L39's vertical tail.
Not to mention the stealthy nose of the F-35 JSF. Best of luck with the project and hope to see it flies here soon. |
RE: 1 x MiG
@JM-PORTUGAL:
Thank you! I'm glad you like my plane, but it will have a length of 2.0 - 2.5 metres..... rather 2.15 metres http://www.rcuniverse.com/forum/js/f...wink_smile.gif @yf222000: Honestly it is a hybrid of this: http://img9.imageshack.us/img9/9220/m346150.jpg http://img121.imageshack.us/img121/2194/yakp.jpg ....and a fantasy of mine.http://www.rcuniverse.com/forum/js/f...ular_smile.gif Next step: I found a paperwork about building an I-16 Rata.... http://www.rc-network.de/forum/attac...p;d=1258144640 Wooden planks encase the body in an angle of 45°. I used an 2,2mm styrofoam-fibre glass sandwitch to do the same with my model. It was done fast an after fixing it with fast-drying epoxy it will be ready in a few hours. Unfortunately I can not use these technique for the whole body, so i will take balsa 3mm balsa straps to plank the nose, tomorrow. http://www.rc-network.de/forum/attac...p;d=1258144640 |
RE: 1 x MiG
From your blueprints, seems like it is very roomy in the main fuse compartment. Gotta love that,
especially when dealing with installing the engine and other supporting equipment. I lost counts as to how many cuts i got on my hands from installing the engine in my Rafale, although it has some room in it. Over all, it is an eye catching jet. All the best to you sir. |
RE: 1 x MiG
@yf222000:
There will be more than enough room http://www.rcuniverse.com/forum/js/f...wink_smile.gif I wonder how you managed to cut your handshttp://www.rcuniverse.com/forum/js/f...eeth_smile.gif The next target is to finish the body. As I said I used 3mm balsa straps for the nose http://www.rc-network.de/forum/attac...p;d=1258233955 http://www.rc-network.de/forum/attac...p;d=1258233955 After the glue dried I used glass fiber to seal the upside. http://www.rc-network.de/forum/attac...p;d=1258316319 while it was drying I had time to concentrate on constructing the elevators http://www.rc-network.de/forum/attac...p;d=1258316319 http://www.rc-network.de/forum/attac...p;d=1258316319 With kind regards Jürgen |
RE: 1 x MiG
Hi Jurgen.
I would love to be the first one to fly this plane.... I would like to make the first order! I have one Booster 80 ready for it!! João Matos joaomatosjets.blogspot.com |
RE: 1 x MiG
1 Attachment(s)
@ JM-Portugal
I am very glad about your order! How about having one below your christmas tree http://www.rcuniverse.com/forum/js/f...wink_smile.gif I promise you will be the very first one! Back 2 business: Body was spackled and grinded |
RE: 1 x MiG
It was from twisting and turning my hands inside the hatch bay trying to get the engine's tubing and cables to run underneath the bypass. :)
The opening for the hatch has some really sharp edges. I had sanded it down a bit, but still pretty sharp. I lost sense of getting cuts when i was so focus on getting things to where i wanted them to be. Only later after sitting down, only then i realized how many cuts i had received on the top of the hands, and or forearm from reaching inside sometime. :) |
RE: 1 x MiG
This model making thing is becoming more and more dangerous http://www.rcuniverse.com/forum/js/f...eeth_smile.gif
Today I cut out the templates for the wings and prepared the styrofoam. http://www.rc-network.de/forum/attac...p;d=1258574886 |
RE: 1 x MiG
Good evening,
today I spent some time to cut out the sideparts http://www.rc-network.de/forum/attac...p;d=1258664084 http://www.rc-network.de/forum/attac...p;d=1258664084 After that I filled the passages and grinded them, untill they had the right profile http://www.rc-network.de/forum/attac...p;d=1258664084 greetings Jürgen |
RE: 1 x MiG
Hey Folks =)
Last weekend I spent a little bit of time again to work on my plane. At first I put 2 layers of 160g/m² fiber glass and 1 layer of 80g/m² fiber glass on the side parts. The 80g/m² layer was put dry on the side parts to absorb the superfluous resin. So grinding will be easier later. http://www.rc-network.de/forum/attac...p;d=1258818851 Now the elevators: Of course it was possible to make them out of styrofoam and encase them with fiber glass, but then it would have been necessary to make them two-parts and they had to be adjusted, too. So I used ribs and a 0,8 mm balsa-fiber glass sandwitch to construct my elevators. The balsa-fiber glass sandwitch was made in vakuum and after 3 hours of drying I cut it into the right form. After that I glued the Sandwitch with the glass side on the ribs and put sandbags on it, so that tha sandwitch could embrace the ribs. Then I put it into the oven and heated it to 60°C (140°F). To plank the other side without distortion I cut out styrofoam profiles. After that I removed the pedestal of the ribs, put the elevators in the profiles and planked the bottom. http://www.rc-network.de/forum/attac...p;d=1258818851 http://www.rc-network.de/forum/attac...p;d=1258818851 http://www.rc-network.de/forum/attac...p;d=1258818851 After they dryed I put 2 layers of 80g/m² fiber glass on them and fit the hull for the pipe into the rear. http://www.rc-network.de/forum/attac...p;d=1258818873 http://www.rc-network.de/forum/attac...p;d=1258818873 http://www.rc-network.de/forum/attac...p;d=1258818873 Finally I built the side parts for the elevators http://www.rc-network.de/forum/attac...p;d=1258923008 http://www.rc-network.de/forum/attac...p;d=1258923008 http://www.rc-network.de/forum/attac...p;d=1258923008 |
RE: 1 x MiG
1 Attachment(s)
Really cool! Kinda resembles the Russian Yak-130
Bamford |
| All times are GMT -8. The time now is 01:24 AM. |
