RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   Search ideas of assemblage scorpion ADJets (https://www.rcuniverse.com/forum/rc-jets-120/9258298-search-ideas-assemblage-scorpion-adjets.html)
REDBULL FRANCE 11-16-2009 04:39 PM
I have just launched into the assemblage of my scorpion ADJETS and I am has the research of ideas to ameliorate assemblage. If you have ideas and photographs to ameliorate my installation.
Peter A 11-16-2009 04:57 PM
RE: Search ideas of assemblage scorpion ADJets
1 Attachment(s)
Have built and flown the Scorpions and have attached a few pictures for you.
What construction issues are you looking to resolve?
Peter A 11-16-2009 04:58 PM
why on earth do these images uploaad as huge images instead of thumnails?
Eric B. AviationDesign Team Member 11-16-2009 05:11 PM
Salut
Tu cherches quoi exactement comme renseignement?
@++ Eric B
REDBULL FRANCE 11-16-2009 05:13 PM
I seek to have an installation of the most simple and clean as possible.
Because I think some things can be improved in this scorpion.
Thank you for the photos which will give me ideas
REDBULL FRANCE 11-16-2009 05:17 PM
Je recherche des photos pour modifier certaines choses comme EX: éviter de faire des trous dans le fuseau parti avant pour fixer le boitier de train(mettre des vis et des écrous au lieu des vis a bois).
J'ai déjÃ* des photos sur CD qui me servent beaucoup pour des modifications,mais il me reste une belle installation.
PaulD 11-17-2009 09:50 AM
A few things quickly come to mind:
-Take note of the extra ribs installed on the front landing gear mounting - they are weak and break easily
-Build some covers over the wheel wells on the main gear to prevent debris from getting to the turbine inlet
-I made a tray on top of the existing tray so I could make a nice clean installation
-Put the CG on the wheels or maybe on the struts - makes the plane much easier to land
-Make sure there is no slop in the elevator linkage
-Use the jet-tech 4l fuel tank for the Scorpion
PaulD
DominicM 11-17-2009 10:00 AM
Nice long thread here with plenty of tips. RCU search is a marvellous thing. :eek:
http://www.rcuniverse.com/forum/m_49..._1/key_/tm.htm
Heer 11-17-2009 10:13 AM
1 Attachment(s)
Hi - some pics of my equipment in the AD Super Scorpion.
Note: fuel tank is self made !
Rgegards
Fritz,Switzerland
Eric B. AviationDesign Team Member 11-17-2009 02:51 PM
hi
very nice job[sm=thumbup.gif]
regards
Eric B
REDBULL FRANCE 11-17-2009 03:54 PM
1 Attachment(s)
Superb work on the scorpion Heer
My Scorpion is equipped with a turbine FRANK TURBINE TJ74s, the only problem with this turbine consumption but it grows 165N, then the tank 4Lsera mandatory.
So I do think a little mix of all the edits I see here is that it asks for photos, so you can give me some ideas of low points to change
Eric if you have pictures of your scorpion I'm a buyer.
Eric B. AviationDesign Team Member 11-17-2009 05:13 PM
Hi guys,:)
Here is my new After Burner, specially made for Scopions, it is distributed by Aviation Design.
[youtube]http://www.youtube.com/watch?v=jIrS23XJdSI[/youtube]
regards
Eric B;)
UKR-Jet 11-18-2009 05:36 AM
1 Attachment(s)
Hi Fritz!
You have forgotten to show here such photo!;)
I wish to thank it the person, in past Fritz helped in online to collect a mode Super Scorpion!
Once again thanks Fritz!
Alex
DominicM 11-18-2009 05:54 AM
Is the Yellow/Black scheme a standard scheme or was it done just for you? Looks wicked. [>:]
Do you have a link to the After Burner product/price?
Eric B. AviationDesign Team Member 11-18-2009 06:26 AM
Hello
yes it's new standard sheme.
For thé after burner, There is no link right now, but you can just
make a mail to aviation design and they will give an answer.
Regards
Eric B
Peter A 11-18-2009 07:11 AM
ORIGINAL: ditchit
Yes we have the afterburner for the Super Scorpion in stock and I am sure AD in France has them as well. The Scorpion tail is too small for the afterburner ring.
Regards
Heer 11-18-2009 07:54 AM
Welcome Alex !
Best regards.
Fritz /Switzerland
Couch Potato 11-18-2009 08:19 AM
ORIGINAL: bip_bip94220
Hi guys,:)
regards
Eric B;)
Wow, those A/B lights are excellent !
[sm=idea.gif] I need some for my Y/A F-15
Eric B. AviationDesign Team Member 11-18-2009 10:12 AM
You can ask to Eric Rantet from AD,he will tell you if it's possible to use it in your F15.
Regards
Eric B
turbokalli 11-18-2009 10:52 AM
HERR, any problems having e.c.u. situated above inlet as in your photos, i am installing turbine and find that i would have to extend all connections if e.c.u. is in nose section.
My main concern is the heat in that area , but if it has proved to be ok then will do the same as I do not really wish to extend all connections.
THANKS IN ADVANCE
Heer 11-18-2009 02:57 PM
@turbokalli
The heat in this area isn't so high that you have to expect problems.
Accumulate over 300 flights without any problems.
Regards
Fritz/Switzerland
REDBULL FRANCE 11-18-2009 04:58 PM
1 Attachment(s)
ORIGINAL: ditchit
Not finishing yellow / black is a new color, the first to have this color is super scorpion.
Eric B. AviationDesign Team Member 11-18-2009 05:39 PM
1 Attachment(s)
<span style="font-size: medium; ">Hi
<span class="Apple-style-span" style="font-family: Arial, sans-serif; line-height: 25px; ">Here are some pictures of my super scorpion.
</span>regards
Eric B
</span>
Eric B. AviationDesign Team Member 11-18-2009 05:42 PM
1 Attachment(s)
Eric B. AviationDesign Team Member 11-18-2009 05:58 PM
A little video... :D
Regards
@++ Eric
[youtube]http://www.youtube.com/watch?v=1Qf_hpP-2mM[/youtube]
