CNC Machine
Holla,
I would like to get a small cnc machine (or a 2d cutter) to help me while building my airplane, something in the 14 inches and more. Thanks, |
RE: CNC Machine
Not sure on prices, but these units seem well built from having seen them at various rc shows.
marcs [link]http://www.step-four.at/e_index.html[/link] |
RE: CNC Machine
How much you want to spend ,,there are several makers of these machines ,,Okmua,Hardinge,Haas
man oh man forgot to use lower caps..LOL, good luck |
RE: CNC Machine
I bought a Zenbot 1216 with a Bosch Colt spindle controlled with Mach 3.
It is a solid low cost 3 axis machine with a footprint (12' x 16") that is perfect for model size projects. www.zenbotcnc.com Phil |
RE: CNC Machine
Price doesn't really matter ;-), I mean something under 3500$... would be ok, but the less I paid, the better it is if the quality is there...
Zenbot web site doesn't work for me (at least a my office), I will check it later... For Step-four it's look nice, but no price are displayed, so I will have to contact them... Thanks, any other suggestions ? |
RE: CNC Machine
Is there a reason to go CNC rather than a laser cutter?
Mike |
RE: CNC Machine
1 Attachment(s)
Why not build your own ? I did !
RE: CNC Machine
Not sure what you are going to be using it for, wood or metal but if you are going the wood route then I would build your own. Its cheaper in the long run and you end up knowing your machine inside and out. Wood also allows more forgiveness on tolerances but metal needs to be precise to something like .002 at least. When I pool some cash I am highly considering one of these:
[link]http://buildyourcnc.com/blackToe2x4v40.aspx[/link] They are relatively inexpensive for the precision they offer and it will cut up to 2' x 4'. More than enough room. |
RE: CNC Machine
Well I want one to save time, so building it will take me time... lol...
I finally got acces to the zenbot website, and that the best price so far... I think I will buy one (the 1216 or the 1624)... Thanks |
RE: CNC Machine
Phil, do you have a video of it ? (Zenbot)
How do you like it ? Can it cut balsa, is it compatible with autocad or Solid Edge ? Thanks |
RE: CNC Machine
I am positive it will cut balsa, not sure if there is a CNC machine out there that cant.
Robin, AutoCAD and SolidEdge are design programs, you will need a CAM program that will be able to translate the design into GCode and then you will need controller software, most likely Mach3, thats what I use. Your biggest hurdle to overcome will be finding the right CAD/CAM combination that works with your machine and machine software, trust me, I know! |
RE: CNC Machine
ORIGINAL: ianober Not sure what you are going to be using it for, wood or metal but if you are going the wood route then I would build your own. Its cheaper in the long run and you end up knowing your machine inside and out. Wood also allows more forgiveness on tolerances but metal needs to be precise to something like .002 at least. When I pool some cash I am highly considering one of these: [link]http://buildyourcnc.com/blackToe2x4v40.aspx[/link] They are relatively inexpensive for the precision they offer and it will cut up to 2' x 4'. More than enough room. I have cut alum plate upto 3mm but it is very slow, I do intend to build another much more rigid and a smaller table specifically for cutting alum, for making retracts, etc. |
RE: CNC Machine
I am just getting used to it, I bought it for light ply but the colt is 1hp and very solid so it should be able to do think ply and thin aluminum. The only issue I have had was the XY belt was a little loose and needed some adjustment.
So far I have been using ilUstrator to make simple outlines which can be ported to Mach 3.. The znbot is An inexpensive way to start and see if cnc fits into your workshop. Phil |
RE: CNC Machine
Buy a StepFour 540 Basic.
It's not only the machine what counts, but much more important how user friendly the software is. When you're making and trying bulkheads you want to make small adjustments as easy and fast as possible. All the rest is just discouraging your creativity. And the result clearly shows the difference. It's maybe not the cheapest choice but definitely one you will not regret. I have mine now for some 12 years, spent already thousands of hours on it, it never let me down and also their after sales service is prompt and first class. I had also CNC Sherline tools (metal parts), CNC Haase (foam cutter), StepFour CNC Foam Cutter... but StepFour always is a class on its own. Nicolas. |
RE: CNC Machine
1 Attachment(s)
I have a home made unit, they are fairly easy to build. Currently run it on Mach 3 and use Bobcad to translate the files to G-Code. Quick, easy and within .002.
RE: CNC Machine
lov2flyrc
What are you using for your rails that the gantry moves on |
RE: CNC Machine
Looks like Todd is using pipe or drill rod like many other designs. Roller bearings in a "V" configuration, not a bad setup Todd.
RE: CNC Machine
1 Attachment(s)
My Machine is built from extruded aluminum box rails with aluminum plates for the gantry and steel tubing for the slide rails. Aluminum angle and roller bearings where used to create the slides. Although this system works perfectly, If I where to build another I would probably go with linear slides for the gantry just to add additional precision. I can cut 1/4" ply at about 20-25in/min, balsa can be cut as fast as I desire. I have cut aluminum with this machine but it is hard on the router.
RE: CNC Machine
Todd, upgrade that rotozip to something a little more manly!! :D:D;)
RE: CNC Machine
ORIGINAL: ianober Todd, upgrade that rotozip to something a little more manly!! :D:D;) |
RE: CNC Machine
ORIGINAL: BaldEagel Is there a reason to go CNC rather than a laser cutter? Mike Mike |
RE: CNC Machine
You can get some cheapo China laser cutters for about 4-6K on eBay. Not sure I would trust them though.
RE: CNC Machine
I will have a look, thanks for the reply.
Mike |
RE: CNC Machine
ORIGINAL: BaldEagel ORIGINAL: BaldEagel Is there a reason to go CNC rather than a laser cutter? Mike Mike For basic hobby usage, CNC router is far more economical. |
RE: CNC Machine
Agreed Todd, lasers are super cool but only for BIG budgets!
RE: CNC Machine
Yes for home use CNC router will do all you want.
I am using the same roller bearing setup on my CNC as well, except on the Z axis where I used Igus slides |
RE: CNC Machine
Yes laser are expensive, I just received a call from a rep (dont even remember wich one....lol..) the price for their basic one is 9k.... lol... a bit to much for my home budget...
Question ? I try to find the contact email of step four, and on their english web site, I can't find it ? Any of you was lucky then me ? |
RE: CNC Machine
Ok, I know, it's expensive, but check the video on this page... Imagine how fast you could cut you airplane parts...
it look like a toy (of 9k $) but it's neat and fast... ;-) http://www.rayjetlaser.com/fr-FR/Mac...er_Rayjet.aspx |
RE: CNC Machine
Has anyone seen plans for one with a 4th axis?
Thanks, |
RE: CNC Machine
Try CNCzone
RE: CNC Machine
Thanks for your input on the laser option chaps seems the CNC route (sic) is the way to go.
Mike |
RE: CNC Machine
The one great benefit to laser cutting is square inside corners, but thats about it.
RE: CNC Machine
Never thought about that, but obviously the corners can only be the dia of the cutter, must pay more attention in class. LOL
Mike |
RE: CNC Machine
It is not a problem I tend to use a 2mm cutter which only leaves a 1mm radius and if I need it square 2 secs with the scapel sorts that.
Most of the time with formers and general weight saving holes you want the corners rounded anyway for strength. |
RE: CNC Machine
Your right, square corners act as crack inducers a nice curve looks better anyway.
So which one of you home build guru's are going to do a tutorial on building one of these? the kits do not seem very good value compared to retail bought one. Mike |
RE: CNC Machine
If there is some interest then why not, I do have all the pictures etc from when I built mine about 5 years ago
RE: CNC Machine
I might be interest to see a tutorial to (even if I really don't have to time to one myself...), it could be very cool to see how you did/do it...
RE: CNC Machine
Actually can be built fairly easily, I built mine really to learn about them and had planned to build "a better one" but found that apart from thick alum it done all I wanted.
I am using it now all the time, in that it makes me money as I produce various items on it for my business. My machine can be made by any modeller and was built from easy to obtain materials and many second hand bits like the stepper motors etc bought on ebay. There are many ways to produce the toolpath (commands for the machine to cut the part) I draw it first in Autocad outline the drawing to suit cutter size (autocad feature) then convert the drawing to Gcode with a program that is freeware called ACE converter then I use Turbocnc (which is shareware program with a reg fee of $60) to cut the part out on my machine. There is other software available that you just draw the item and it converts and runs the machine all in one but can be expensive to buy. Most expensive single item I bought for my machine was the stepper motor driver board at about $65 as far as I remember, that includes the PC I use as I bought an old win98 machine for £30 which is perfect to run the machine. |
RE: CNC Machine
Xairflyer
I think the interest in a tutorial would be great, if it could be kept simple, not everyone uses Autocad or even knows what it does, I think you would have to assume we are all Demigog Morons. ;) Mike |
RE: CNC Machine
I never used autocad before hand either and still only know the basics, but easy enough to learn how to do simple drawings
| All times are GMT -8. The time now is 09:16 AM. |
