TMAXX upgrade help for newbie/oldie
GA
I put this up in the nito forum,then found the moster truck forum,oops.
I have had a pile of rc cars between 1975-1990. but things have really changed.
I was planning on starting back into rc cars with a 2.5 TMAXX.
It used to be all cars had a few weak points and upgrade spots that really did help.
What do you TMAXX guys like? There is a ton of after mrkt. and Traxxas upgrade parts.
Which ones are worth it?
Any help much appreciated.
Chas
Chas
RE: TMAXX upgrade help for newbie/oldie
the t maxx is a great truck to start back in with. for a while your truck will be fine, but after a bit it can take a beating. If you want to go the aluminum way hardcore racing parts are very good. if you want to save weight and go with the plastic/nylon go with RPM. they have great parts and has a great warranty plan. if you break it just send it in and they will give you new parts no questions asked!!
VA
get everything RPM
a fantom .18 engine when the 2.5 makes you POed
a strong(120+oz in of torque) metal gear servo
and some aluminum bulkheads if/when you break the plastic stock ones
either way, just replace what breaks.
oh yeah, and aluminum shocks
GA
thanks for your help. My local hobby store is out of tmaxx's now but will have some in a week or two.
also where is the best selection of bodys to purchase?
Chas
Chas
Avistarpilot is right on the money. The best bet is to (as Flatlander_14 describes) "just replace what breaks". You can spend a ton of money trying to bulletproof it ahead of time but that never seems to work or you will spend more than you need to
Just a question....does it have to be a T-Maxx? We have three T's and they are great....but for what it's worth, don't forget about the Savage!
GA
well I did think about the savage,and will go try to find the other posts on it.
You have 3 t's do you have a savage? if you were starting out with no cars would you get a couple of t's or savages, and why?
Chas
Chas
I have Maxx's and if I were buying a new MT today I would wait until Traxxas upgraded the Maxx to a BIGBLOCK and beefed up the tranny and a few other points! The Savage is a better choice as it stands right now. Wait and get the "New" RTR .25 Savage. It should be out in a month or so. Traxxas will have a new Maxx but when???
