Best break-in method for LST?
LA
What is the best method to break-in LST, the Losi manual indicates one way and the Dynamite Mach 26 indicates another? So far I have just ran three full tanks through engine. Do I need to lean out high end?
CA
RE: Best break-in method for LST?
Here is the best method in my opinion that I follow with all my engines coming from a well known engine modifier. Check out.
http://www.rbmods.net/enginetempering.html
Follow the manufacturers reccomendations if you do not want to void your warranty. IF you want to take your chances, I would open up the engine and check for shavings to be safe and then follow redmikes plan.
J~
J~
