XTM 24.7 engine problem.
FL
Well i have a Thunderquake with 24.7 engine and when i pull the pullstarter too crank the engine there is no compression. AT ALL. When you pull the pull starter its like pulling a kite string out of the palm of your hand. It's not turning the engine. Whats going on?Is it a serious internal problem?
Thanks in advance.
Thanks in advance.
FL
ORIGINAL: lax195
do you have a glow plug in??! the 24.7 doesnt come with one.
Hi, if the engine is not turning over when you pull on the cord then most likely thhe problem is in the pullstart it's self (broken pull start?, like a one way bearing maybe)
MI
Wow no one even offered the obvious answer...the one way is slipping. Remove and clean the one way with nitro cleaner or denatured alcohol, re-install and all should be fine.
One way bearings tend to slip after break in due to the extra rich settings.
FL
ORIGINAL: binaryterror
MI
Well i made a little spelling mistake on mine i accidently said "dheck your on way bearing" i ment "check your one way bearing"
MI
ORIGINAL: HPI Racing
You must be blind? Did you not see my post? or The Boss's post?
