piston/sleeve for ofna .26?
my savage has been on vacation since i got my revo, but i lately decided to get it back into severe bashing condition. i decided to open up the engine while i was doing the rebuild, even though the engine had been running great. once i removed the piston, i saw some damage to the piston, and a little nick out of the air intake port of the sleeve. I want to replace the piston/sleeve before any damage is done to the bearings, but i cant find the correct part no. I called the lhs, and they said they have 2 differrent part #'s for ofna/picco .26's, but they nor i know which one is the correct one. can anyone help? if you have this engine, and the paperwork that came with this engine, please help[]
this is the engine i have. http://www2.towerhobbies.com/cgi-bin...?&I=LXESC2&P=0
RE: piston/sleeve for ofna .26?
part #52045 for piston and sleeve 87.96. This is for the force .26 made by ofna. you might as well buy the whole motor for 109.00 or look on ebay for the part. I found this at nitrohouse.com site. Either that or put the force back together and run it till it blows, and then buy a new engine.
ORIGINAL: speedfreak1234
well its obviosly the picco 26 piston and sleeve you want
ORIGINAL: silverman1
51422 if your picco .26 is the outlaw version. Like I said go to nitrohouse.com
close, its actualy 51442, but thanx again for pointing me in the right direction[sm=thumbup.gif]
im almost sure that the picco and the wasp are the same so maybe this will work http://www2.towerhobbies.com/cgi-bin...?&I=LXFLM4&P=Z but dont buy that until u ask somebody else cause im not sure
why dont you run the engine till it blows then just buy a new one ?? you might get 2 or 3 more gallons out that motor theres no since in wasting money??
WA
Do you mean this piston and sleave set.
[link=http://www.carttonic.com/catalog/index.php?file=catalog&action=catalog_productinfo&uid=466&pi_id=90807&clist=0,9835,11305]Picco .26 7 Port Piston/Sleeve Set [/link]
ORIGINAL: AJ DRAGON
can you use any .26 piston and sleeve set in a picco .26? i bought one that needs a rod and piston online and i was needing to know if i would be making a mistake buying a Team Losi Aftershock Mach .26SS Piston sleeve and rod kit...if anyone knows please let me know. Thanks... and btw this isnt a reply...that was the only way i could figure out how to post a question.
