RC Monster Trucks Discuss rc monster trucks in this forum
part
Old 01-18-2005 | 06:45 PM
Default part
well i ran my savage in the snow and the rode had salt and it kinda croted the glowplug and the thing that holds it. im going to get a new one but i cant find the thing that holds it on tower cuz i dont know what it look for. so what plug do i get and whats the thing that holds it? thanks
Old 01-18-2005 | 07:31 PM
Default RE: part
:Cough: Should have got an E-maxx :Cough: HAHA J/P... Sorry I can't help you with this one.
Old 01-18-2005 | 08:16 PM
neil.jb's Avatar
Default RE: part
a good plug to buy is the OS#8 and the part you are looking for is called the under head button
Old 01-18-2005 | 08:54 PM
Default RE: part
thanks
Old 01-19-2005 | 07:47 PM
Default RE: part
mmm can you find that part fopr me on tower. i cant seem to find it.
Old 01-19-2005 | 07:48 PM
Default RE: part
also i got a little rust on the dog bones and the diffs. do i need to replace them or will they be fine
Old 01-19-2005 | 08:02 PM
neil.jb's Avatar
Default RE: part
give you truck a good clean then cover it with WD40, this will displace moisture and prevent rust, dont worry about the odd bit of rust here and there, as long as its not to bad and it doesnt effect how your truck works then you dont need to replace the parts
http://www2.towerhobbies.com/cgi-bin...?&I=LXFRD9&P=7
Old 01-19-2005 | 08:10 PM
Default RE: part
OIL!!!!! Clean/touch them up with an sos pad. Get all the"crud" off of them. It's not full blown rust yet, just tarnish. Take some motor oil, or some gun polishing oil and a paper towel, pour the oil (2-3oz. maybe) in a bowl. If you don't wanna get your hands oily, put gloves on. Dip the paper towel in the oil and polish all your steel parts that can rust up like that. The paper towel will evenly absorb and evenly distribute the oil. For your driveline joints, get a cu-tip and oil to the best of your ability. ALSO, if you use the oil on your plastic, it will look TWICE AS GOOD AS ARMOR ALL AND LAST TWICE AS LONG!!!! Makes it looks better than when it was new. I oil my E-maxx after every run. It stays shiny. If my buddies didn't see me run it, they would sware I never did... The oil should protect from any future tarnish/rust. Just re-apply after ever so many runs depending on what you romp through in the run. If you run through snow, then you will need to re-apply after every run. Just dirt? Then wipe off the dirt and see for yourself whether it needs more. DOOOOOOO ETTTT!!!!!! Lemme know how it turns out. :my2c:
Old 01-19-2005 | 08:15 PM
Default RE: part
Snow = Water
Water + Steel = Rust
Oil + Steel = Rust Protection
Oil & Water don't mix (everyone knows that).
However, the snow mixed with the salt is nothing but bad news for the steel drivelines.
Peace:::::
Old 01-19-2005 | 08:16 PM
neil.jb's Avatar
Default RE: part
or do it the easy way and get a can of WD40 and spray it on
Old 01-19-2005 | 08:19 PM
Default RE: part
WD40 was also a good idea. However, it will need to be applied repeatedly. Wheras the oil could last you a few runs (depending) like I said above.
Old 01-19-2005 | 08:48 PM
Default RE: part
il just get some wd40 thanks guys. i also got alot of crud in the motor. what should i do about that.
