I need help NOW...Im fed up with this
RE: I need help NOW...Im fed up with this
alright. i am setting the needles to factory settings for break-in. i am a little confused about the low speed needle. it says to turn 3 times from fully closed. what is fully closed? all the way to the right? or all the way to the left? when i turn to the right all the way, the carb is open. even when i turn out 3 times. this cant be right. can someone help me?
ORIGINAL: Richie-EB4
Set you LSN 1 turn in from flush with the housing
ORIGINAL: Salty0790
HSN=high speed needle
i know what LSN and HSN mean. i meant the "flush with the housing" thing.
sorry for being a pest.
#31
Never a pest...........you see the screw (LSN) goes inside a brass tube thing........thats the housing.
Turn out that screw untill the end is flat with the brass tube bit then turn it in 1 turn.
#33
i set the screws to factory settings back. but, i dont think it did anything. i doubt it will start without someone blowing through the pressure line. too cold to try it out. . thanks for all your help, guys. i really appreciate it.
#35
take a flat something, eg piece of metal and put it across the housing, the needle is "flush"when there is no gap between the metal and the LSN needle, but the needle is not above teh line of teh housing, if this makes sence
flush--- level with...
#36
anyway im off now, Richie u know what ur doin, guide the little man
if u want nemore help l8er Salty, (ie 2morrow or when eva) PM and i'll try and get back asap
#37
thanks. i will remember to do that. i am a complete newb at this stuff. i know how an engine works, i know how a tranny works, i know how a clutch works, i know just about everything when it comes to the basics. but, this stuff has me beat.
#38
1 Post
Jeez, nasty problem...
The only thing i can think of that could be causing such a problem is the carb. I'm not talking settings, becaust even with an un-tuned engine fuel should still enter the carb when the engine is primed.
IMO the problem MUST be a blockage in the carb, most likely where the fuel tubing connects to the carb. Could be dirt, gummed fuel or anything.
My advice would be to remove the carb from the engine, remove the air filter and somehow pressurise the inside of the carb. Put a finger over the air intake on the carb (where the filter sits) and blow HARD into the carb from the part that usually sits in the engine block. The pressure should force any mud etc out. If this does'nt work try flushing the carb out with fuel, same method as before, just dont drink the fuel. [:'(]
Good luck
Good luck
#39
AHA! i found the problem! and i fixed it! it was all in the pressure line! i cut the end that is connected to the muffler by a couple milimeters so that the streched part would be gone. now it fits nice and snug. THEN i cut the other end of the pressure line the same way. nice and snug again. i tried priming it. i put the roto in it and spun it. i saw the fuel vibrate and it didnt move. i got mad. but a second after i stopped the roto start, the fuel shot through the fuel line all the way to the carb! problem fixed! i am so happy right now. that was my biggest problem. it shouldnt have a problem starting now that i can get the frikin fuel to the engine. its 25 degrees here now, so im gonna wait until tommorrow for that 45 degree weather to start her up . i put a some after-run oil in the engine and called it a day. THANKS TO ALL WHO HELPED!!!!!
#40
hey i was getting ready to throw some suggestions out but i am glad to hear you got it running. hope you enjoy your truck. have fun man
Mike
Mike
