RC Monster Trucks Discuss rc monster trucks in this forum
glo plug igniter
Old 01-11-2006 | 07:54 PM
Default glo plug igniter
how long do i let the glo plug igniter charge on the wall before i can use it?
Old 01-11-2006 | 08:26 PM
RCtruckRacer's Avatar
Default RE: glo plug igniter
If it was totally dead, or brand new, dont let it charge for more than around 6 hrs. It might even be fully charged within a few hours, depending on the output rate of the transformer. Do you know what kind of battery (MAH rating) of the battery inside of the ignitor? If so, and you know the output of the charger, you can pretty easily figure out how long to charge it.
Old 01-11-2006 | 10:33 PM
ya it was brand new and i plugged it in at around 5 ish and i just now unplugged it afteri read your comment
thanks
logan
Old 01-11-2006 | 10:35 PM
on the glo plug charger itself it says 1.2 V SC1600mAh ??
what does that mean
Old 01-12-2006 | 01:10 PM
My Feedback: (13)
it's a 1600mAh battery is what it means, you can use the mA rating on the charger to calculate how many hours it takes to charge...
my glow ignitor said to plug it in for 15 hours when new, and 12 hours after that, and that should be pretty standard, and is close enough... you can't really over charge the batteries using the charger they give you, which is thier point...
