RC Monster Trucks Discuss rc monster trucks in this forum
gearing
Old 02-02-2003 | 04:01 AM
Default gearing
I have a stampede with a speed jems saphire motor, and I cant find a good gear . I either flip it over or have no take off but go really fast. I have tried from stock all the way to a 32 tooth any suggestions???????? Please HELP!!!!
Old 03-05-2003 | 01:01 AM
cummins driver's Avatar
My Feedback: (31)
Default gearing
I am running a stock motor with 13/87 and it still wont wheelie from a stand still.What spur are you using?Maybe add a little weight to the front end,and then it wont flip over? If youve tried all kinds of gearing,then i dont know what you could do.
Old 03-05-2003 | 01:27 AM
Default gearing
I am not posative with out looking but I think i am running a 74 or78 tooth spur. I can't seem to find that happy medium. It is either all lowend or all high end. I have tried pinions from 13 to38. Hope this helps you with wanting to wheelie..
Old 03-05-2003 | 01:30 AM
Default gearing
I forgot I changed to a stock motor and it still wheelies good but doesn't flip over now, and still goes pretty fast.
Old 03-05-2003 | 01:50 AM
My Feedback: (31)
Default gearing
Thats just wierd . I dont know why you couldnt find a happy medium because i would think one of those gears would make it a good happy medium. If you have a slipper clutch,loosen it,and then it shouldnt do wheelies,and youll still have good speed.When i said stock motor,i meant the 20 turn stinger.Is that what motor you was talking about?
Old 03-05-2003 | 01:56 AM
Default gearing
I dont know how many turns my motors are i just buy 24 degree timing stock motors. I like them better because they go pretty fast and don't eat batteries. I have a custom built racer that i run a stock motor in and it will pull the front wheels and still goes almost 40mph thats why this stampede is bothering me. I have even used the gears and motor from it on my stampede and it still doesn't do good. I have also played with the clutch and again no luck..
Old 03-05-2003 | 02:02 AM
My Feedback: (31)
Default gearing
I can loosen my clutch up to where my truck wont even move,so i dont see how you cant have any luck adjusting it.Are you sure your turning the nut the right way to loosen it?Maybe you should take the clutch apart and check the little pegs in there to make sure they are in the slots right,and not jammed around where it wont let it slip.
Old 03-05-2003 | 02:07 AM
Default gearing
When I adjust the clutch it all works ok but I don't like to let it slip a whole lot. It just seems to me the more it slips the faster it wears out. I have a lot of money in my other stuff and this one is my play toy. It is the one I ramp and run over stuff with. It runs ok but when compared to my other stuff it just doesn't seem to run right.
Old 03-05-2003 | 02:18 AM
My Feedback: (31)
Default gearing
I wouldnt worry to much about letting it slip because all that can really wear out is the little pegs which im sure would be cheap,or the slipper plates,but i would think they would wear the pegs out before they wear out,and i wouldnt think they would be too expensive anyway.The manual says to let the slipper slip for 2 feet from a stand still when you take off wide open.
Old 03-05-2003 | 02:20 AM
Default gearing
I'll try to go with a bigger gear and loosen up the clutch a little. Thanks a bunch..
Old 03-05-2003 | 02:24 AM
My Feedback: (31)
Default gearing
No problem.
