MGT BROKEN
CA
MGT BROKEN
I know, another worlds smallest violin post... After many months of bashing, it first appeared that my spur striped. But the entire spur shaft is wobbling big time, either the bearing went, or the case broke inside. Anybody have this happen to them? The main gears are ok, just the shaft with the side gears... I havent opened it up yet. No holiday bashing for me.
IN
RE: MGT BROKEN
I just ripped my whole truck apart cleaned it, changed the diffs oil, new clutch, and new springs. It took me about 3 hours to do all that. You should be in and out in a half hour... If you dont run into complications. good luck you could have on the road... off road by the holiday.
