Help Please!!!!!
All,
I have a Savage .21 and need to know a part number and where to buy one. hpi purchase sight has been down.
I think the part I need is a dogbone. It is not the ones directly underneath the truck. It is actually one that goes from the back wheel to the truck and makes the back wheels work. Right now when I drive the truck only the front wheels work. Can someone help????
Basically you should be able to get the dog bones at your LHS. Your going to have to pretty much take 3/4 of the screws, that are on the sides of the truck and take them off till you get to about the engine. The reason is you have to drop the transfer case to put the dog bone in.
While your doing that put some glue on the hex nut that your brake is one. They have a tendency to spin the plastic flat.
Hope that helps
Hope that helps
Just make sure its not the hex screw in the dogbone(s). My buggy lost 4wd (lost the front) while I was driving once and it was because my hex screw came loose. If it is make sure you put it in like this:
1. Turn wheel till you can see down the screw hole
2. Turn the other wheel to make it spin inside of it (hard to explain)
3. Turn it till you can see the flat side
4. Screw it with lock tight till it is in there as tight as you can get it
Ok for #2, to get more detail. What I mean is that its like a shaft going threw the middle and thats what you will see turn down inside the screw hole.
#3 The shaft like thing in #2 will have a flat side to it and you will see it if your using a flashlight. Once the flat side is up with the screw hole then you do #4
Hope this helps any and I hope thats the problem.
