what do u think about the mega force
WY
Only looked at one in a hobby store and turned around real fast LOL, just not for me!! I havent heard much about them and not realy interested in them, but thats just my opinion.
Banned
They got good reveiws in the mag's!
That chain drive looks like it could take some bashing Or am I thinking of the Mad Force??! Kyosho makes good cars and trucks so, it should be a good buy. JMO
Only thing is that there is not much in the wat of hop-up's but, does it need any??
Mega force is RTR.Come with .15 engine,the manufacturer say that it is for Nitro MT beginner,not very fast,reliable....just check it out,beginner....here is some info about the truck.
This is the Newest .15 Size Nitro RTR (4X4) Monster Truck from KYOSHO.
For those new to Nitro, this is the way to go!
FEATURES:
Factory Built Completely Equipped
Extremely Durable
Easy to Operate
Super Reliable Quick Reverse Clutch (QRC)
Kyosho's "Touch Starter" Ignition System
Complete Ball Bearings (28 Total)
Independent Double Wishbone Suspension
Cooling Fan Unit
125cc Fuel Tank
GS-15R Engine from Kyosho
Huge Low Pressure tires with Foam Inserts already Glued to Rims.
Divided Radio Box, to protect on-board Gear.
Under Carriage Chassis Support
Reinforced Shock Towers with holes to decrease Weight.
Perfex 2-channel Radio Preinstalled.
Forward and Reverse Operation
INCLUDES:
Pre-assembled "QRC" system
2.9"x 6" wheels, "V" tread 6.7" x 3.8"tires,
GS-15R Kyosho engine
Muffler
Air filter
Glow plug
Flywheel
Oil filled shocks
Pre-painted body
Decals
Perfex 2-channel radio pre-installed
Instructions.
REQUIRES:
10%-15% Nitro fuel
12 "AA" Alkaline batteries for radio
6-Cell 7.2V Battery Pack
6-Cell Charger
Misc. Building and Track Equipment
SPECS:
Length:18.9" (480mm)
Width:14.8" (375mm)
Height:11" (280mm)
Wheelbase:12.2" (310mm)
Front/Rear Track:11" (280mm)
Ground Clearance:3.1" (80mm)
Front Gear Ratio:25.1:1
Rear Gear Ratio:34.1:1
Weight:9.25lb (4200g)
Engine:Kyosho GS15R (included)
Radio:Kyosho Perfex 2-channel (included)
COMMENTS:
Fuel: 2-cycle glow fuel with 10%-15% nitromethane, 18% lubricant-
Most of the fuels we carry meet or exceed the lubricant content
required for optimum performance and maximum engine life.In the
past, the conventional lubricant content used in fuel was 18%.But
with new advanced technologies, fuels like Red Alert and O'Donnell
for example, have a better quality of lubricants even though the
percentages of lubricant content are lower. These high-tech
lubricants provide exceptional cooling and protection.
kh11-26-01
SPECIFATION:
Stock Number: KYOD15**
Length: 18.9 in (480mm)
Width: 14.8 in (375mm)
Height: 11 in (280mm)
Wheelbase: 12.2 in (310mm)
F/R Track: 11 in (280mm)
Ground Clearance: 3.1 in (80mm)
Front Gear Ratio: 25.1:1
Rear Gear Ratio: 34.1:1
Weight: 9.25 lb (4200g)
Engine: Kyosho GS-15R (included)
Radio: PerfexTM 2-channel (included)
Requires:Fuel (10%-20%), 6-Cell battery, 12 “AA” batteries
FEATURES:
Extremely Durable
Easy to Operate
Cooling Fan Unit
125cc Fuel Tank
INCLUDES:
Muffler
Air filter
Glow plug
Flywheel
Oil filled shocks
Pre-painted body
Decals
Instructions.
REQUIRES:
10%-15% Nitro fuel
6-Cell Charger
SPECS:
Width:14.8" (375mm)
Height:11" (280mm)
COMMENTS:
kh11-26-01
SPECIFATION:
MD
You have a .21 engine in it?????? What mods did you have to do? Also have you blown the single speed transmission apart yett. I have one also. I also bought a Savage after I was disappointed in the Mega Force. I bought a Ofna Hyper .21 8 port for the Savage and I am going to try and put the stock Savage engine in the Mega force and try to fit a T-Maxx 2 speed tranny in it. I would like to know what mods you had to do to cram the engine in there..
