RCU Forums
-   RC Monster Trucks (https://www.rcuniverse.com/forum/rc-monster-trucks-160/)
-   -   Tips for Smartech Magic Wheel (https://www.rcuniverse.com/forum/rc-monster-trucks-160/2552577-tips-smartech-magic-wheel.html)
hozza 01-29-2007 05:16 AM
RE: Tips for Smartech Magic Wheel
hey
im carving up every thing with the magic wheel but braking is an issue basicly it sucks it hardley evean stops i pulled it out and sanded the disc back and the calliper that pushes the disc was bent so i made that flat and put it all back in and knoe its worse then ever it doesnt stop at all i dont know whats wronge with it and we dont have a hobby shop here and i need all the suggestions i can get
Fallen Angel[FLC] 01-29-2007 05:32 PM
I've upgraded the clutch-(burnt the other one out running the engine in:eek:)I've had it for about a month, so far-the only thing is I'm getting air bubbles in the fuel line-tried to extend the line away from the exhaust.
Ripped well today-3ft jumps no probs-even climbs kerbs from standstill.-well impressed for the price-I'm trying to get my old hornet up and running for my son(now I've knicked his magic wheel off him;))......any ideas on getting idle speed down?.....is there a better way of heating up the glow plug?-the rechargeable battery thingy only lasts for a bit,so if I stall it its end of sports.
hozza 01-30-2007 01:52 AM
if it only last for one start i suggest u get another one it should last for bout a whole day and more any one got any more ideas on my brakes i dont wan to run it if she aint got brakes but when i do get it running i might make a movie
unlawfullactions 02-01-2007 01:18 AM
well, the magic wheel was my first RC car, i've always been interested in the gas(nitro) powered cars ever since i was a kid, simply because i figured it would be a heck of a lot easier since you dont need to recharge batteries all the time (like in electric RC cars) boy was i wrong..lol.....i bought my magic wheel off a coworker, he had gotten a special snap-on edition for free with a toolbox he bought...when i bought it he was having trouble getting it started and blamed it on bad gas (was about a year old) so i got new gas and cleaned out the system and the car worked great......i didn't know anything about these cars and it was kind of a learn as i went experience. so i spend a good few hours trying to get the car to go into reverse...which was becoming rather annoying since i figured for 250 dollars the car should go in reverse....but after doing some research there aren't that many cars that do go in reverse too....so to sum it up quick....first thing to break was the nipple on the gas tank that comes from the exhaust (pull start got stuck on the line and pulled the part off) was able to fix that with a coupler piece from a fish tank and some high temp hot glue. so next problem was when i was drilling out the fuel tank for the coupler i think some plastic got in the fuel lines and was blocking it, so i removed all of those and cleaned them....next, the battery box broke into 500 pieces...then the pull start broke, so i spent a few hours rebuilding it..... then one of the axles broke and a wheel hub...had to wait 2months for my lhs to get the wheel hub part in...when it finally came in i worked into the night getting the car back up and running and i took it to work the next day to tune it on my lunch break and to use it in a nice gravel parking lot next door. well the car was running great, no problems at all....i let my buddy use it and he drove it up onto the blacktop part of the parking lot, and right there is a major highway.....well the car went out of range and went full throttle into teh highway,.....surprisingly it made it all the way across but seconds later a car drove by and dragged the car about a block away....so right now the car is still in pieces 8months later.....i thought about fixing it, but am overall looking at getting a new car, maybe fix this one if i come across some used parts, or sell it for parts....basically it needs a new carb (the throttle arm broke off) 2 new tires, 2 new body posts, a battery box with battery holder, and a body...surprisingly the car was in excellent shape after the devestating wreck.. i would recommend a magic wheel to anyone who doesn't have a lot of money to start off, or that is unsure if they are going to stick with the hobby, its not a bad truck, i had a lot of fun with mine....but do make sure you can readly get replacement parts, preferable from tmaxx.
Fallen Angel[FLC] 02-01-2007 06:27 AM
Hozza-brake problem....
the two plates are stamped out of metal-put the rough side(with a burr) towards the brake disc-tighten the springs up fairly tight and make sure your brake/throttle servo is adjusted properly-worth while investing in a fail safe-a bit fidly to set up-but working great now.
Make sure the disk isn't fuel soaked-failing that invest in a traxxas disc brake!-happy truckin.
nitrosteve22 02-01-2007 12:31 PM
Anyone know off hand how many teeth are on the stock CB and spur for the MW?
Thanks.
Fallen Angel[FLC] 02-03-2007 12:12 PM
Clutch bell 20 teeth-spur gear 73/74(lost count:eek:)-had it running perfect today-awsome jumps at a BMX track near us.I'll try and vid it next time.:D.......I think we'll upgrade to alloy chassis runners and alloy skid plates.......skid plates had a battering today.The body supplied has withstood a high speed multi roll....and next time I'm going to fit underside plate-it stalled in the woods due to a stick coming up through the chassis and jamming the flywheel.Can't believe the hammering I've been giving it-and it's still in one piece!!
Been thinking of digging out my old hornet for my son-I think I'll buy another Magic Wheel-theyre unstoppable!!!!!!:D
mbe301 02-15-2007 02:25 PM
1 Attachment(s)
Does anyone have the 1/6 version of the magic wheel?
FOQRS 02-22-2007 12:12 PM
Anybody know what you need to do to convert engine to a big block motor?Is there any chassis mods ,trans or such things that need to be changed?What's the biggest size motor to upgrade to without big mods?
jaymagic 02-22-2007 02:22 PM
hi . don't go big block,you'll blow every thing a part...
i've been told the OS1.2 is the engine to upgade to much torquer infinattly better than the standard 1.5 smartech
FOQRS 02-22-2007 04:04 PM
Thanks,where can I find one?
hozza 02-24-2007 09:59 PM
cheers i have my brack and throttel servos and linkeges running perfectly i hear ppl saying to get rid of the spring and put fuel tubing i bought an other car a victory hawk (vh-32) for drifdting so that has swayed me a bit from the Mw but ill give that a try i probley have done some thing stuiped
cheers hozza
hozza 03-01-2007 01:38 AM
1 Attachment(s)
hey i got my brakes sorted so i ran it thanks also how do you know if you need a new battery box
A: when the old one has smashed into a thousand pieces this is the second one all i did was come off a jump and it smashed of couse the batterys fell out and it enden up into a tree at 60kmph nothin broken just the battry box
ps: look at the pic the red velcro is to hold the lid down as the place where you put the screw is broken
oldschool77 01-28-2008 02:22 PM
ORIGINAL: Smokinjoe6450
Why do people keep coming on here saying it is an "illegal copy of the T-Maxx"????? If it was illegal, don't you think Traxxas would have done something over the years about it??!! Traxxas probably sold them the rights to make their older version t-maxx. What do they care...they are now "double dipping" with the new AND old stuff. [&:]
Exactly!
Now a larger market has clones, real "original" TMaxx's and 2.5's. More spare parts!
oldschool77 01-29-2008 10:52 AM
QUick question...the RTR version I bought has a 27mhz transmitter, probably without any other rx crystal adjustments or choices. Interference problems? What radio have you upgraded to?
oldschool77 01-31-2008 10:31 AM
Anyone?
I can't wait to get this in the mail!
LAstly, any suggestions for a better steering servo? I have a hunch the stocker RTR is a dog.
oldschool77 02-05-2008 11:01 PM
OK, bought an oldschool FPB Futaba fora steal...check my other Smartech replies...I have some questions!
hozza 02-06-2008 04:48 AM
sorry i t took so long to reply lol my stock receiver was crap so i got a futuba one but the wire on the ariel some how got striped so no i have like a 10 m range 20 m if i start at one side and 10m over the other side.:-) i have the same stock steerign sever it is ok as long as you are moving, there for means its cheap as is the magicwheel
but i like my magic wheel i need a new receiver then i might make a vid of it at our bmx track
04DarkShadowGT 02-07-2008 09:52 AM
My guess would be if you asked Traxxas, they would refute people saying its an authorized copy. Personally I wouldnt buy a knock off but I understand the appeal to some who maybe cant afford the real deal.
My problem with clones is that the RC company, be it Traxxas, Losi, HPI, etc puts millions into R&D, advertising, engineering, support, etc. That has to go into the cost of the vehicle, the chinese and taiwanese knockoffs dont have any of that so they can charge less. But by buying these knockoffs you are not only hurting yourself by getting generally an inferior product but also hurting the entire RC community. If the major companies dont make money they arent going to be able to come out with new and innovative products.
Just my .02 cents.
owen1992 03-17-2008 05:08 PM
1 Attachment(s)
hey this is my first post :D
ive been reading alot of smartech magic wheel forums and i thought i would post some of the upgrades ive made to mine :)
1) hpi 18ss engine :)
2) rpm suspension arms :)
3) futaba throttle servo (already had this lying around not amazing but better than stock) :)
4) the rods that connect to the steering knuckles that keep the wheels striaght and so they dont move ive drilled the hole out and put a nut and bolt through it this makes it alot stronger and they never come loose! :)
i hope the pics have worked not to sure on how to upload them lol
Clymer122693 03-18-2008 08:25 PM
If it runs like a T-maxx and looks like a T-maxx but isn't one then you have a Smartech :)
ssllc902 03-21-2008 02:06 PM
Please help!! My nephew gave me a truck to fix for his kid he got it from snap-on after buying a tool box. After doing a web search it might be a smartech magic wheels.I dont know. How ever it is broken and i need parts. It seems a bit diffrent also.
1. the tranny is not inclosed.
2. the clutch bell has 2 gears on it connecting to the open tranny.
3. there is a chain that goes from the tranny to the dogbones.
He only ran 4 tanks though this truck and then he fliped it on its back and it no longer moves. I thing the front diff is bad along wit something in the tranny. When You you give it gas it the engine just spins and the rear tires barly move and the front dont at all. If you have info or Idea plaes LMK
hozza 08-19-2008 02:39 AM
hey guys
i thought i would try getting this thread started again as it was the best one on the net with out magic wheel haters spamming it.
i was reading some of the post i made omg i was clueless and a dousch.[:-]
does any one know what parts fit the magic wheel from th T-maxx. more specifically the battery and receiver box.
hozza 08-19-2008 02:45 AM
if it has a chain then its not a magic wheel. but its probably a bit late i think it would most likely be your diffs are striped in the front and all the power is going to the front but you probably already know that thought i might be able to help.
NStampede Freak 08-20-2008 09:30 PM
You all might want to read this:
[link]http://monster.traxxas.com/showpost.php?p=3171657&postcount=50[/link]
So basicly, smartech stole the tmaxx design and traxxas can't do anything about it.
Just so you know.
