RCU Forums
-   RC Monster Trucks (https://www.rcuniverse.com/forum/rc-monster-trucks-160/)
-   -   Project Monster Force (https://www.rcuniverse.com/forum/rc-monster-trucks-160/5755872-project-monster-force.html)
pythonfan 05-11-2007 12:59 AM
RE: The Dreams Are Starting! Update, pics are loaded!
ORIGINAL: -Force1-
Have u though about locking the diffs?
I'm not locking the diff jeff.
pythonfan 05-11-2007 01:01 AM
Ebay here i come for parts!
JUCD VPR 05-11-2007 08:28 PM
it's coming along good man, how much longer till you think it'll be completed?
pythonfan 05-11-2007 08:30 PM
if all goes right this weekend i will have it up and running by the end of next week!
nik77356 05-11-2007 08:31 PM
hey try www.rccrawler.com they can help you with all the solid axle and links and stuff but not so much with the nitro. try it they are really helpful
pythonfan 05-12-2007 02:01 PM
Well i'm almost ready to order, is there anything else i shound conder buying now?
pythonfan 05-17-2007 01:25 AM
Well here is the list!
Well guys here is my project parts list!
Madd Force Adaptor Kit
http://www.maximizerproducts.com/maxstore/stores/1/Madd_Force_Adaptor_Kit_P83C8.cfm?UserID=224729&jse ssionid=2430905e0200$F5H0$FB
My clutch combo
Hot Bodies Flywheel for 2pc Shoe Lightning
http://www2.towerhobbies.com/cgi-bin...p?&I=LXHZK7&P=
Hot Bodies Clutch Spring 3-Shoe Lightning (2)
http://www2.towerhobbies.com/cgi-bin...?&I=LXEPA3&P=7
Golden Horizons Alum Clutch Shoe Prpl Savage 21/25/28SS
http://www2.towerhobbies.com/cgi-bin...?&I=LXFZZ8&P=7
My diff set up
HPI Bearing 10x16x5mm Savage 21 (2)
http://www2.towerhobbies.com/cgi-bin...=++&search3=Go
HPI Heavy Duty Differential Shaft 14x34mm Savage (2)
http://www2.towerhobbies.com/cgi-bin...?&I=LXGJU3&P=Z
HPI Alloy Diff Case Savage X SS
http://www2.towerhobbies.com/cgi-bin...?&I=LXPLW0&P=Z
HPI 4 Bevel Gear Differential Shaft 4x27mm Hellfire (4)
http://www2.towerhobbies.com/cgi-bin...?&I=LXLZX9&P=Z
Hot Bodies Differential Gear Set Hard Steel Lightning
http://www2.towerhobbies.com/cgi-bin...?&I=LXLGV5&P=X
Hot Bodies Bevel Gear Spiral 10T Lightning
http://www2.towerhobbies.com/cgi-bin...?&I=LXJBM3&P=X
Hot Bodies Bevel Gear Spiral 43T Lightning Stadium
http://www2.towerhobbies.com/cgi-bin...?&I=LXJBM4&P=X
My drive shafts
Hot Bodies Heavy Duty Dogbone
http://www2.towerhobbies.com/cgi-bin...?&I=LXJKM7&P=7
Replacement parts
Suspion arms x2
3speed gears
brakes
kyosho long drive cup
center bulk
body posts
kyosho engine mount
bell guide
3pice clutch nut
Wheel and tire combo
Big joe tires and wheels,
imex web rims,
maxx onroad tires
will have pics of the web and tire in a bit!
Lst2 shocks
carb bolt for the mach
new ball bearing in the diffs!
Well thats it for now! I will keep u updated!
-SomeGuy- 05-19-2007 11:28 PM
Now i understand why you want that python skin anodizing. Im sorry to hear about your loss, i know its a snake but a pet is a pet. And i hope you get better soon.
This is a nice project your working on and i would be glad to help out. I'll get to work on the python design as soon as i have some time to play around with colors and patterns. Byte and I have been keeping it in mind and coming up with ideas to get as close to what you want as possible and i think we might have a really good plan. The only hold up is that we have some orders to fill in and other requests of colors and designs that were asked before yours but dont worry your on the list.
So far from the pics you've posted i really like the one with the black lst shocks or are those from your muggy? i dont know much about that truck but the shocks look like the aftershock shocks.
Keep working on it, im looking forwards to the final product.
pythonfan 05-20-2007 10:07 AM
ORIGINAL: -SomeGuy-
Thanks man. those are the muggy shocks, i like to keep the truck lower so those should to just fine with thinner oil and a softer to medum spring!
And the mach from the muggy is going to be sick!
SAVAGEJIM 05-29-2007 07:34 AM
Scanning over this thread, I noticed that the Hot Bodies and Kyosho helical gears are only 43T/10T bevels. This low gear ratio is what rock crawlers want, but I want to put helical bevel gears into a Savage. For Savages, they use a 43T/13T ratio and I want to keep this ratio for this application.
I know that HB does not offer a 43T/13T helical option, does anyone know if the Kyosho gears come in a 43T/13T helical option?
pythonfan 05-29-2007 09:35 AM
Nope, They only come in as all i have seen is 43/10, the stock gearing in my truck is 43/10 so it won't harm me, but for u savage guys, there going to be a bit more low end.
SAVAGEJIM 06-01-2007 07:36 AM
That sucks. Those three miniscule gears would totally throw off my entire overal gear ratio in my Savages. I wonder if the Gigacrusher also uses the same Kyosho 43T/10T helical gears? If the Gigacrusher uses 43T/13T or higher gear ratio, does anyone know if these are a direct fit onto Savage diff cups?
pythonfan 06-05-2007 10:09 PM
Hey guys i just got a werid idea?
I got stung by the drifting secne.
ANd i was thinking about making a drift force, that has a ring to it, "Drift Force"[:-]
But slaming the truck, and with the new axial .28rr uhhhh it would make a sick Drifter, put some slicks on it, or pvc. uhhhhh That would be sick!
What do you guys think?
Dale Gribble 06-05-2007 10:56 PM
Why not? If you want to play around and have some fun, go for it. It would probably be a novelty- I am sure you would have some meaty tires back on there after a few PVC drifter runs.
pythonfan 06-05-2007 11:04 PM
it was just an idea, i want to jump into the drift secne but i'm having probs doing so!
pythonfan 07-21-2007 11:22 PM
Well guys I'm gonna be ordering my parts finally, so keep an eye at for updates.
guy4x4 07-22-2007 10:37 AM
Hi pythonfan will this work on my Mad Force Im not sure thanks.
http://www.jrradios.com/Products/Def...odID=JRP234275
pythonfan 07-22-2007 11:21 AM
are u getting just the radio, or the radio receiver? if your getting just the radio, it will work, u just need to make sure u have the same crystals, but if ur getting the entire setup, with or with out servos, as long as it comes with the receiver, it will work just fine! unless u have a FM radio installed right now?
guy4x4 07-22-2007 01:04 PM
Just want radio and reciever to work with stock servos my stock radio was no good.
pythonfan 07-22-2007 01:31 PM
yes it will work just fine!
guy4x4 07-22-2007 01:40 PM
Thanks man.
pythonfan 07-22-2007 01:44 PM
No problem!
The Winner 10-03-2007 08:22 AM
9 pages?o pythofan!!! 9 pages for a project that is at zero point! please dont imagine in 9 pages just do it the f***ing project! and at the kyoshomonster.com you did the same! and first af all this truck is not clean!
pythonfan 10-03-2007 11:37 AM
ORIGINAL: The Winner
give it time man, when u have 0 money it kinda makes things go slow.
The Winner 10-03-2007 12:03 PM
and with my force i have 0 money!but i made it as is right know!yes but if you have zero money don't start your imagine in the forum one year ago!just be sure what you will make!
