send us a picture of your motorcycle
RE: send us a picture of your motorcycle
Have you raked the forks forward? I haven't read this whole thread through, but I had the same issue & by raking the forks further forward I got rid of it. There should be a screw to unwind onthe stearing stock that will do the trick. if it only does it on acceleration or braking there are some other things you can try. I used to have a document that I downloaded with all the tricks on setting up a bike. I'll see if I can find it for you.
Go to this link and read up on the steering article and the NF setup article. They'll help you a lot.
http://www.rcbike.com/tech_tips.htm
put the rake out to max, it looks a little steep in the pic. Add a small amount of diff grease inside the fork legs to help with damping.
Thanks for the info, Will try *****g out the rake as much as i can. Guess Im going to be taking apart the forks in the near future..............
#31
They just unscrew and there only a spring inside bottom, add a finger nail worth of grease and it stop it from pattering and help the rebound over the bumps.
#32
Once again, Thanks for the info. I probably would have filled er up with grease. The forks are the only thing Iv left alone so far, Cant wait to get home in a week or so and start on it again. Too bad its still a long wait to run it again[&o]
#35
VA
ORIGINAL: 773W
Nice.................you running Lipo's in that thing?
