nitro feul boiling in carb
WA
Is it shutting off? Check your temp. shouldn't be more than 220 degrees. I keep mine a little richer at 200 Degrees too prolong engine life. If it don't stall or flame out, don't worry about it.
WA
Does it boil right away? or does it take awhile? If it takes awhile, you may be too lean, getting it too hot and flaming out. Heat is the only thing that is going to cause that.
ORIGINAL: ranger2011
the feul is boiling in carb after a few moments of driving is this normal ans how do you stop this
ORIGINAL: gearhead777
my mgt 8.0 gets pretty toasty like 270F but runs great with a good smoke trail and no signs at all of a too lean setting, but my JPX and Nova p5X probably run 220-230.
the only time i use a temp guage is when im breaking in a engine or, if im new to the engine, other than that, sound, smell and smoke trail is all i need to dial it in.
are you sure your not overfilling your tank and its not just the tank back-pressure bubbling it up like a hookah?
tried it again today i think its flameing out i get through about a half tank feul and it quits grab it let it set for a moment fires right back up and quit again before the tank was empty.
