RC Nitro Stadium Trucks Discuss all aspects of rc nitro stadium trucks here
Official HPI MT2 Thread
Old 10-28-2006 | 05:57 PM
  #8301
46u's Avatar
46u
Default RE: Official HPI MT2 Thread
ORIGINAL: murawskiallen
oh well i guess thats not a problem cause i have the mt2 ss kit...would you recommend the slide carb or the rotary carb on the tz??
I would go with the slide and to make things easy they make a kit to change over from a rotary. At one time they said slide was better for on road and rotary was better for off road. But I think since they have change there way of thinking. I really do not think it makes a big difference.
Old 10-28-2006 | 05:58 PM
  #8302
46u's Avatar
46u
ORIGINAL: crohbober
im having a problem with one of my dogbones in the front of my mt2. the dogbone isnt snugg in the cup joint and now the joint is all bent out of shape. PLEASE HELP ME !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Hard to say would help if you could post pictures.
Old 10-28-2006 | 06:18 PM
  #8303
ok thx
Old 10-28-2006 | 07:25 PM
  #8304
hey 46u i went to my LHS today and they didnt have any hardened diff gears for the mt2 but the had some nitro 3 18ss gears in stock and they said they should work because people use the mt gears for that car. i put them in and shimmed them up and they seem to be working they are a lower ratio but work.... whats your opinion on this do you think its a good idea to run them until the other gears come in?
Old 10-28-2006 | 07:38 PM
  #8305
46u's Avatar
46u
They will work but you have to run them in both diffs, as you cannot have one ratio in one and a different in anther or you will have one running at a different speed then the other and one would be holding the other back They all so are not as strong as the heavy duty. Some on this forum run them.
Old 10-28-2006 | 07:45 PM
  #8306
thanks, well I have them in both because i figured thats what would happen. why would the benefits of them be that would make people use them over the normal diffs?
Old 10-28-2006 | 07:50 PM
  #8307
today when i was puttin the clutch back together i was having toruble putting the small pin in. It seems like it is impossibe to put it back in. how do i put it back in?
Old 10-28-2006 | 07:56 PM
  #8308
do you meen the slipper clutch?
Old 10-28-2006 | 08:03 PM
  #8309
yea
Old 10-28-2006 | 08:07 PM
  #8310
make sure the nut that tightens the spring is as loose as it can be like right at the end of the threads and then you should have enough extra room to put the pin into it.
Old 10-28-2006 | 08:09 PM
  #8311
hey 46u, i was reading older posts and they had something about springs in the diffs. what are thesse springs.
Old 10-28-2006 | 08:13 PM
  #8312
murawskiallen's Avatar
those springs help the diffs lock so that two of the wheels driven by a single diff will spine instead of one
Old 10-28-2006 | 08:14 PM
  #8313
46u's Avatar
46u
http://www2.towerhobbies.com/cgi-bin...=++&search3=Go
It is for making the diffs like limited slip diffs. On my Savage and buggy I use different weight oils but the MT the diff is not sealed so I use the spring. I have heard of some sealing the diffs on the MT and using oil. Most times you will have the front set where it pulls harder then the rear so when going around corners the front is pulling harder to help keep the vehicle from spinning out.
Old 10-28-2006 | 08:15 PM
  #8314
I dont even have the stuff on the other side of it
Old 10-28-2006 | 08:19 PM
  #8315
would it be beneficial for me to get the diff springs?
Old 10-28-2006 | 08:20 PM
  #8316
46u's Avatar
46u
ORIGINAL: ajmernan110
I know what you are talking about but it has been a while since I have been in to mine and cannot remember the procedure. It is one of those things when you are doing it you remember but when someone asks it does not register. Damn I am getting old SORRY.
Old 10-28-2006 | 08:55 PM
  #8317
unclezesta's Avatar
hey guys, how many of those spring sets do you need to purchase to do both diffs? i assume two but....
and also, do the springs help keep the diffs from dieing as well as act like oil?
Old 10-28-2006 | 09:09 PM
  #8318
46u's Avatar
46u
One kit will do both but they do not help with durability.
Old 10-28-2006 | 09:42 PM
  #8319
i was putting a new spur gear on my car just now and when i turn it it wobles so half will be a good mesh and the other half will be to tight? do any of you knwo what would cause this because i cant figure it out.
Old 10-28-2006 | 09:48 PM
  #8320
your engine isnt lined up correctly i had the same issue
Old 10-28-2006 | 09:51 PM
  #8321
is the gasket on the spur gear on properly? and is it really tight?
Old 10-28-2006 | 09:54 PM
  #8322
the gasket on the spur gear? im not sure there is one. if so then i guess not. uhhh i dont think its my engine not lined up because when i spin it freely without the engine on it wobles still.
  #8323
46u's Avatar
46u
I know mine has a good bid of wobble but it does not bind. Try setting the mess at the tight point. I keep saying I am going to check the wobble but I am running a TZ and if that does not tear it up then I figure it is OK and so far no problem.
As for the diff springs I do not see any real advantage if all you do is bash but if you race I highly recommend them.
Old 10-28-2006 | 09:59 PM
  #8324
alright thanks ill try that. i have the tz too and i have been killing every gear that i possibly could in my car.
Old 10-28-2006 | 10:03 PM
  #8325
46u's Avatar
46u
Are you running the SS set up which is the same thing as on the Savage as far as the CB and bearings go?
Like I said my spur wobbles but I do not have a problem with anything wearing out. Setting mesh is very important as well as you have to make sure the alignment is correct.
