RC Nitro Stadium Trucks Discuss all aspects of rc nitro stadium trucks here
Official HPI MT2 Thread
Old 01-01-2007 | 08:00 PM
  #11576
Default RE: Official HPI MT2 Thread
looking for cheap tsais rear exhaust pipe. Anyone know where to get them cheap
Old 01-01-2007 | 08:02 PM
  #11577
Nitr0-is-Deadly's Avatar
http://www.southeastrc.com/Items/Std...ookup=OSM11376
do you think that engine is the equivalent of a O.S .18 cv-r or stronger??
Old 01-01-2007 | 08:03 PM
  #11578
i ran twice this summer with my savage, didnt fair so well, still have alot to learn thats why were heading to iowa to get a jump on summer. going down with some lifelong racers and they are so hopefull with pointers, ill let you know should be fun indoor nitro smell in the winter..
Old 01-01-2007 | 08:07 PM
  #11579
cuz im thinking a O.S .12 tz in a gt2
Old 01-01-2007 | 08:11 PM
  #11580
all the guys i talked to here in mn. say no way to the tz its way to hard to control on the track and doesnt keep a great tune, they all say the .12 cvr im going to keep the .15 in mine til i blow it up this summer because it has more than enough power for me right now and i havent even taken out the restrictor yet
Old 01-01-2007 | 08:17 PM
  #11581
can i use [link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXTB55&P=Z]13t HD pinion[/link] on my mt2SS i screwed up only the pinion
Old 01-01-2007 | 08:18 PM
  #11582
i wouldnt say its to much for the track..fine there maybe a thing as to much power...but if some 1 can run a 3.3 jato on my track a .12 tz can run on it too
Old 01-01-2007 | 09:16 PM
  #11583
this just os discontinued the .12 cv-r its being replaced by the tg model
Old 01-01-2007 | 10:56 PM
  #11584
Hello Guys
I just got an HPI mt2 .18ss.
I am new to the nitro mt2 and to this forum, but I have been racing 1/10 scale on and off road for years.
In my area mid-west GA. nitro 1/10 scale 2wd stadium trucks are vanishing. I have a 2wd Losi XXX-NT and
if I want to race I have to race against the 4wd monster trucks. the losi does pretty good usually finishing in the top three
if the track is well watered,but most of the time it's not. I do not like the big and clumsy monster trucks or the
the 1/8 scale truggies/buggies. So that leaves me with the 4wd 1/10 scale hpi mt2.
My mt2 will be strickly for racing. I will toss the hpi .18ss engine for a os .15cv-r non p/s w/slide carb and threaded
crank. I think anything bigger would be hard to handle on a track. Other hop-ups are;
gpm 3mm main chassis (heard bad things about gpm,but it's hard to screw-up a 3mm chassis I think?)
hpi non p/s engine mounts and flywheel (a920 & a926) will use a starter box
hpi diff springs, but will try sealing the diffs and fill with 3k and 1k silicone diff fluid
lunsford titanium turnbuckles, hpi aluminum shocks
I am still putting it together. So if any of racers out there have any tips or sit-up adivce it would be
GREATY APPRECIATED!
Old 01-01-2007 | 11:11 PM
  #11585
I KNOW IN MN. THE ONLY CLASS YOU CAN RUN THE MT2 IN IS MONSTER TRUCK. BUT ASK 46U HES ALSO FROM GEORGIA SO HE WOULD KNOW MORE ABOUT your rules...sorry about the caps wasnt paying attention
Old 01-01-2007 | 11:33 PM
  #11586
are there any simple mods i can do to give my mt 2 more bottom end. i have the stock t-15. i dont have much money to spend. im sure some of you guys have little tricks up your sleeves[8D]
Old 01-01-2007 | 11:45 PM
  #11587
not for that motor get it tuned as well as you can i got rid of mine a week after i had it could never get it tuned right..good luck hope you figure it out
Old 01-02-2007 | 12:15 AM
  #11588
Well you see guys. It is like around -10 outside everyday, and im thinking setting the needles to factory 3 turns out from closed is gonna be either too rich or too lean. And what is the factory settin for the low end needle? cause 3 tourns out from closed is way to much. And, how do you tune top end needle first if the bottom end needle makes your truck bog off the start? figure that one out :P
Old 01-02-2007 | 12:24 AM
  #11589
46u's Avatar
46u
ORIGINAL: topcat-lll
Hello Guys
GREATY APPRECIATED!
Welcome to the forum
You most all ready have or know someone that has an OS 15 CV-R as it has been discontinued ever since they came out with the 18 CV-R which is a couple of years now. I am guessing you have checked out the track rules where you plain on racing as many track do not have a 4 wheel drive stadium truck class. If it was like our track we normally had 3 classes do to lack of racers. 1/10 scales anything, 1/8 buggy and truggy and 1/8 monster truck. Where are you racing? I do believe when I had the OS 15 CV-RX in my MT my Savage would have out run it on the track. Now my Savage is not stock but is running the stock engine. I do no know my Savage has no problem keeping up and beating the Revo. One thing you defiantly need to get for your MT is a set of aluminum knuckles!
Old 01-02-2007 | 12:56 AM
  #11590
can you guy tell me if these clutchbell will work on my mt2 there heavy duty ones
15 tooth #A990
13 tooth #A988
ANDand also what bearings do i need for this
Old 01-02-2007 | 01:18 AM
  #11591
46u's Avatar
46u
ORIGINAL: bubbles31
15 tooth #A990
13 tooth #A988
Is it the RTR or the SS if it is the RTR to change the gearing you have to get engines mounts unless you all ready have them. As far as the bearings you need 5x10mm. If it where up to me I would go with the Race CB, as it is vented and harder then the heavy duty yes those CB will work.
Old 01-02-2007 | 03:01 AM
  #11592
ORIGINAL: 46u
ORIGINAL: bubbles31
15 tooth #A990
13 tooth #A988
could you get me the part number for the race cb plz
Old 01-02-2007 | 04:23 AM
  #11593
rcnz's Avatar
ORIGINAL: bubbles31
HPI Racing Clutch Bell 15T
http://www2.towerhobbies.com/cgi-bin...&I=LXLST7&P=ML
HPI Racing Clutch Bell 13T
http://www2.towerhobbies.com/cgi-bin...?&I=LXLST5&P=7
DuraTrax Bearing 5x10mm (2)
http://www2.towerhobbies.com/cgi-bin...?&I=LXD115&P=V
Cheers
RCNZ
Old 01-02-2007 | 04:44 AM
  #11594
please check my gallery and let me know what u think of the color scheme?
Old 01-02-2007 | 10:24 AM
  #11595
ITS PINK..LOL
Old 01-02-2007 | 10:38 AM
  #11596
nice pink
  #11597
so wait...the mt2 is considdered more a stadium truck or truggy?
you say buggys have 3 diff's..is this counting rear diff/front diff/spur?
and ya the pink is kinda funny
Old 01-02-2007 | 10:51 AM
  #11598
pink is a great color u wont lose it at the track
Old 01-02-2007 | 10:55 AM
  #11599
ORIGINAL: rapsucks_07
somebody help him
Old 01-02-2007 | 11:46 AM
  #11600
NewfieNitro's Avatar
Hey guys I'm getting ready to order a HPI MT2 18SS kit off tower and I was wondoring what things I will need with it. I already have CA, air filter oil, diff grease, e-clips, and im getting a bottle of 60 weight oil to use in the shocks instead of what ever comes with it. What else should i get? O and i already have all the radio gear.
Also do you know if this will fit it? http://www2.towerhobbies.com/cgi-bin...?&I=LXFKM8&P=9 I want speed [>:]
Thanks in advance!
