RC Nitro Stadium Trucks Discuss all aspects of rc nitro stadium trucks here
Official HPI MT2 Thread
Old 01-09-2007 | 09:31 PM
  #12176
Default RE: Official HPI MT2 Thread
i just did the factory thing and the setting look good but i have to start it up 2 moro
Old 01-09-2007 | 09:35 PM
  #12177
nickrummy's Avatar
I'm pretty sure the high speed needle is more than 2 turns out from closed....
Old 01-09-2007 | 09:40 PM
  #12178
would u say like 2 in a half and the high speed controls the fuel right??
Old 01-09-2007 | 10:05 PM
  #12179
right??
Old 01-09-2007 | 10:25 PM
  #12180
nickrummy's Avatar
the manual to the motor would tell you the exact amount. I would say the factory setting is usually 2 1/2 - 3 turns out.
The high speed needle effects the fuel put into the engine between mid - full throttle.
The low speed needle effect idle - mid throttle.
The idle stop screw (black screw) controls the opening of the carb at idle.
Old 01-09-2007 | 10:44 PM
  #12181
THANK YOU NICK
Old 01-09-2007 | 10:51 PM
  #12182
46u's Avatar
46u
Any of you guys have the same problem as I? I have some moderator telling me I cannot have STS as my avatar. What is going on with these forum they sure are rocking the boat for no reason!!!!!!!!!!!!!!!!
  #12183
yea the manual says 3 turns
Old 01-09-2007 | 11:01 PM
  #12184
u mean that big orange sign i always see wen u post... well i dont see why they say ur not allowed... wuts the big deal od having sts as an avatar
o yea and 46u... u know tha small black screw under the airfilter to the right. do u know what the factory setting is for that?? i cant find it in the manual
Old 01-09-2007 | 11:21 PM
  #12185
ok so the 2 speeed ofr the MT has no slipper
what if i put a 2 speed off the tower hobbies ST-15 on there
it has a slipper
i want 2 speed because im getting my Ace kicked bye jato's
i keep up oin the track but barely and i hafta really try hard
Old 01-09-2007 | 11:28 PM
  #12186
ok if u wanna beat a jato get a better enqine.. 46u said he beat plenty of them on the track and 2speed is not good for off road.
Old 01-09-2007 | 11:30 PM
  #12187
i see u put the trx2.5 in.. change it to a os.18 cv-rx and also it depends if ur a good driver. the person with the jato just might be better then you no offense or anything..
  #12188
how much faster does the os .18 cv-rx make the mt2 with the .15? do i need the short shaft or the standard shaft? do i need anything else to make it work? besides motor mounts. thanks
Old 01-09-2007 | 11:37 PM
  #12189
no the dirt track is in the process of being built (thats why im not on here much any more) but the tracks i goto in dallas i can keep up on dirt usualy i pas in the turns pretty easy (yes i am considered a decent driver im sponserd by Rose City Racers and Wings And Wheels (ironic because i work at hobby town)
but are local races are all on roaod at the time
so i have a LOT of difficulty keeping up off the line and out of turns
i put the 2.5 inn it becuse i truely HATE traxxas engines
terrible porting this one just needs to be finished off
Old 01-10-2007 | 06:05 AM
  #12190
djheptic's Avatar
ORIGINAL: crohbober
ok guys u need to help me out... i just got fuel and tried starting my car.. i got it started and it wont even stay at idol it revs and shuts off.. is it too lean??
ORIGINAL: crohbober
the idle needle does not have a factory setting. there should be a 1mm gap when you look down the air intake (carb). and when you apply the brakes the gap should not close up. is it cold were you are? if so starting will be hard. are you letting the engine idle for 2mins before running? nitro engines only work best when they are up to running temps. read your manual and set the LSN & HSN to factory. check your idle needle, make sure there is a 1mm gap. and when you apply the brakes make sure this gap does not close up. if it does you will need to screw the needle in clockwise a touch so the gap does not close (dont forget to put the airfilter back on). make sure your glow plug ignitor is fully charged, prime the engine untill you see fuel go into the carb. hold the glow plug ignitor on the glow plug for 5-10secs and then do quick sharp pulls on the pull start. then let the engine idle for 2mins. do a couple of laps. and then start tuning your engine. look for plenty of blue smoke at top end. good luck
((check your fuel line. you sometimes get yellow/orange gunk in the line near the carb. if there is just squeeze it out. remember to burn out all of the fuel when you have finished running for the day & to use some after-run oil.))
Old 01-10-2007 | 06:09 AM
  #12191
djheptic's Avatar
woops[&:][&:] didnt mean to post this...sorry all.
Old 01-10-2007 | 12:19 PM
  #12192
It shows in the book at the back on the page were they show how to rebulid the carb on
ORIGINAL: crohbober
Old 01-10-2007 | 12:45 PM
  #12193
nickrummy's Avatar
crohbober, what engine do you have again?
Here is something for the T15 to look at it. If you aren't running the T15 then pay no attention to this link.
http://hpiracing.com/graphics/instr/...-2_p2o%20S.pdf
Old 01-10-2007 | 12:56 PM
  #12194
Well today my run of bad luck with the MT2 continued. Today was the first day I've had to get the car up and running since it broke over two weeks ago, so it started fine and went okay (it was quite slow for some reason...think the engine was running too rich). Before I could make any adjustments I brought the car back to where I was stood and noticed that the cone washer had come off the CB, and the bearing and screw with it too.
I prepared the car last night with thread lock so I don't know what happened. I have just ordered some more bearings as I only bought the two that I required.
Old 01-10-2007 | 01:04 PM
  #12195
nickrummy's Avatar
you DEFINITELY want threadlock on that bolt which of course I'm sure you know. That coulda got ugly!
Old 01-10-2007 | 01:14 PM
  #12196
ORIGINAL: nickrummy
Yeah, that was my initial thought. I'm lucky I was keeping an eye on it all. I'd bought engine mounts and was checking that the mesh was okay between the CB and the spur gear. I think it was a little off, so I'm going to have to adjust that.
Do you guys apply thread lock a few hours before? How long does it take to dry?
Old 01-10-2007 | 01:16 PM
  #12197
guys got my new exhust to day and it looooooooks really really cool
Old 01-10-2007 | 01:17 PM
  #12198
djheptic's Avatar
ORIGINAL: stadium truck freak
what pipe did you get?
Old 01-10-2007 | 01:18 PM
  #12199
o and djheptic i am gonna keep an eye on ebay for my cars and if i see them il buy it go ther ther house to pick em up and beat the sh1t out of them lol
Old 01-10-2007 | 01:22 PM
  #12200
i got a tasis one the side exhust . the one i showed u guys
