RC Nitro Stadium Trucks Discuss all aspects of rc nitro stadium trucks here
carb?
Old 02-17-2004 | 10:18 PM
Default carb?
how often should i clean and replace o-rings on my trx carbs and can i use 10-wd-40 to clean them i`v heard that u can but i`m not sure.Thanks andrew
Old 02-17-2004 | 10:23 PM
Default RE: carb?
Its a good idea to clean your carb and o-ring often, if you clean it often it wont need replaceing as regular. I would use contact brake cleaner for cleaning the o-ring, it dries up fast and doesnt leave everything oily like WD-40.
Old 02-18-2004 | 12:12 AM
Default RE: carb?
ok thanks but can i use wd-40 in my engine as replacment of after run oil.
Old 02-18-2004 | 07:48 AM
ericheller's Avatar
Default RE: carb?
dont use wd 40 it leaves behind alot of oil. you need to get after run oil.
