RC Nitro Stadium Trucks Discuss all aspects of rc nitro stadium trucks here
How About This for First Setup???
Old 02-19-2004 | 11:08 PM
Default How About This for First Setup???
Ok, here is what I am looking at getting for my first setup:
Associated RC10GT Factory Team /w Pull Start $269.99
Associated AE .15 Pull Start Engine $104.99
Futaba 2PL Radio $64.99
Any thoguhts? Any changes?? TIA!!!
Old 02-20-2004 | 07:28 AM
Default RE: How About This for First Setup???
I take it you are going to be racing with it?
Old 02-20-2004 | 11:18 AM
I would like to eventually, but I will also be doing some "bashing" as it is called. Is this setup a bit over the top? Do you have another recommendation??? Thanks!!!
Old 02-20-2004 | 03:50 PM
Shawnlh's Avatar
My Feedback: (-1)
That setup is fine, going with the factory team gt from the start just gives you a stronger truck, and you don't need to worry about upgrades. IMO
Old 02-20-2004 | 05:22 PM
ericheller's Avatar
shawnlh's statement about it being stronger is false considering most of the parts are graphite. i think it is kinda a dumb idea to buy a ae engine, if your gona do that you should just buy the rtr. go with a better engine. if you plan to race get a .12 for it is illegal to race .15's in most races.
Old 02-20-2004 | 05:24 PM
ericheller's Avatar
and also seeing that that radio is only about $65 i doubt that its very good quality. in such a good truck it would be a shame to have anything less than the best components for it.
Old 02-20-2004 | 06:31 PM
So you are saying I need a $200 radio to make this truck worth while? Some how I doubt that. From what I have read the Futaba PL is a decent radio. What do you recommend then for a first setup? I don't want a truck that I have to turn around and buy $200 in upgrades. TIA!!
Old 02-20-2004 | 06:35 PM
ICrashThings's Avatar
ORIGINAL: Snyperx
$200 is nothing to what i put into my rc10gt...
Old 02-20-2004 | 06:40 PM
ericheller's Avatar
ORIGINAL: Snyperx
i have a jr xs3 in mine, nearly $300 i think. maybe a xr2 or something, but $60 for a radio, you can expect lots of glitching.
Old 02-20-2004 | 06:47 PM
ICrashThings,
Do you ever get sick of talking about your RC10Gt "Mutant"? Just curious. YOu always mention how much you spent, how fast it goes.....blah....blah...blah. Can you give me some useable information? Recommended kits, radios, and egnines? Atleast ericheller is somewhat helping me out.
Old 02-20-2004 | 06:53 PM
Get the O.S. .12 The .15's are not as good. They tend to heat up more and wear out fast. They are bored oit .12's. Also ditch the PS idea, it should be called POS. I started with a PS and it was good for a little while then worked worse and worse. The started boxes are cool and you can get a nice one form tower (OFNA) for about 80 bucks with the battery and glow igniter included. I would also get the factory team truck form the start if you can swing the cost. You will spend lots more upgrading parts than if you just get it now.
Old 02-20-2004 | 06:54 PM
ericheller's Avatar
ill give you suggestions if you explane what you want it for. how much are you able to spend, what do you look for in a rc car. do you want alot of speed or torque and if so can you control alot of power?
Old 02-20-2004 | 07:03 PM
I am looking at doing a bit of everything. I would like to do some "bashing" and also some racing. I suppose I can spend what I have to to get the correct setup, but would prefer to stay under $500. Of course I want plenty of speed, but not overkill. Thoughts on this:
Associated RC10GT Team Factory
Airtronics MX-3 Radio
O.S. .12 CV-RX engine
Old 02-20-2004 | 07:32 PM
ericheller's Avatar
sounds like a good setup, but ive never heard anything about that radio.
Old 02-20-2004 | 07:38 PM
http://www2.towerhobbies.com/cgi-bin...?&I=LXSW03&P=7
http://www2.towerhobbies.com/cgi-bin...?&I=LXXA45&P=7
http://www2.towerhobbies.com/cgi-bin...I=LXDNY0**&P=7
From tower you can save a bit. I like the futaba radio better, the 3pdf is a great radio and has 3 car memory. I like the memory as you can have brake/throttle settings for different track or motors. You may want to start with a OS CV .12 and not the CVR. The .12 is fast and much more reliable to abuse and easy tuning. I have a CV abd CVR and can beat my times with the CV and enjoy it more than the CVR. The CVR is to much por for most tracks and is a bit on the tempermental side.
Also the little air filters are really justy fuel filters. see link
http://www2.towerhobbies.com/cgi-bin...?&I=LX3409&P=7
you can get these at your local automotive parts store for a buck each. don't try to clean them, just replace them and keep the pre filter clean. A dirty filter will make your truck slow and frustrate you when trying to tune it.
Old 02-20-2004 | 09:25 PM
tomass15,
What servos should I go with since the radio comes with none???
Old 02-25-2004 | 10:42 PM
rc10gt4master's Avatar
hitec servos.....525 mg and a hitec high torque servo.....forgot what mine are sorry[]
Old 02-26-2004 | 01:29 AM
First, don't buy the AE .15 engine. Buy either an O.S., or a Fantom. They are much better engines and can be purchased for around $100 without the pull start. I'm guessing the radio you're talking about is the new Futaba 2PL 2 channel computer radio. Its a great radio and will out perform several radios costing twice as much. My question is, where can you get it for $65? For servos, go with metal geared Hi-Tec.
