Is my MT2 Normal?
hello
I have HPI MT2, it's my first Nitro RC.
with 75 cc tank, .15 engine (T-15), I could only run for about 5 minutes (max)
is that normal? or is there any bad setting on it
PA
Ive actally never timmed my truck but 5 to 7 min. should be about right, I think
. sorry i meant that it is running rich. Make sure that the glo plug is very tight and the manifold is sealed well. Also make sure the carb settings are correct. Look up the factory settings and go from that. Try to lean out the top end a bit, and richen the low end if you need to hold the rpms up to keep it from dieing otherwise lean it, only a small turn at a time. but make sure that you know where all teh screws were origionaly[:@] or you will be out like i was when i first had my truck.
Your only loosing a few min. but that could be harming your engnie, if you cant find the prob. then take it to your friendly neighborhood hobby shop. Good luck!
. sorry i meant that it is running rich. Make sure that the glo plug is very tight and the manifold is sealed well. Also make sure the carb settings are correct. Look up the factory settings and go from that. Try to lean out the top end a bit, and richen the low end if you need to hold the rpms up to keep it from dieing otherwise lean it, only a small turn at a time. but make sure that you know where all teh screws were origionaly[:@] or you will be out like i was when i first had my truck.Your only loosing a few min. but that could be harming your engnie, if you cant find the prob. then take it to your friendly neighborhood hobby shop. Good luck!
Thanks everyone.
right out of the box, I only did the setting for carburetor, which was 3 turn (from the manual), but then I felt no power when I hit the full throttle, so I I turned to 2,5 turn (I got this from the forum).
is there any connection with slippery clutch? maybe to tight.
or, the differential backlash, I think it's too big. the backlash is about 3~4 mm.
Thanks.
Thanks.
125cc from New Era Models, Just installed one on my hpi mt2. Here is the link --->
http://www.neweramodels.com/cgi-bin/...e&part_id=2075
ORIGINAL: jeep1992
What are your thoughts on it so far?
ORIGINAL: Tex_MT2
Awesome. *adds to shopping list*
ORIGINAL: jeep1992
Sweet, thanks for the run-down. This is my first Nitro truck too, and I would really like not to have to stop to refuel too often. I'll wait and see what kind of run times I get out of it once it's run in but if it's not satisfactory I think I'll buy one.
Hey Jeep that looks great! Can you give me a list of the hop-ups you have? And did you have problems with your diff? If so what did you do to fix it? I tried adding the shims but one of my gears was to far gone.
Superscott
I shimed mine front and rear before I ran it. I dont know if I had the updated gears or not. I shimmed it any way seemed to take some of the play out of it. Haven't had a problem yet. Only about a gallon of fuel thru it though.
Hop ups:
F4I Titanium front and rear shock tower: Broke the rear plastic one twice jumping.
New Era Models 125cc fuel tank
Motor Savers Air Filter
HPI Titanium turn buckles with RPM heavy duty Rod Ends the black ones from hpi to short.
HPI Blue colis front and rear: 40wt shock oil
HPI Fiber disk brake
HPI Racing clutch
Formost Check Valve
Golden Horizons Fuel Filters
Boiled the suspension arms Front and Rear
Dynamite race guard Fail Safe
HPI 1200mAh NiMH 6 Volt Receiver Hump Pack: Haven't installed yet need a charger for it.
Thats it....
Hop ups:
HPI Racing clutch
Formost Check Valve
Thats it....
Nice car Jeep,
can you tell me the part number of the shim?
my differentials are fine so far, but like I said, the backlash is just too big.
Thanks for the list Jeep! How does the truck handle with that 40 weight oil, I was going to put 30 in front and 40 in the rear. Can someone explain what "backlash" is?
Sorry if my word make a confusion, superscott.
I use to call the "play" as the backlash.
well, I work in automotive industry, we use to call the clearance between gear contact as the "backlash"
I guess all of you know, functioning mechanical systems, such as gears, need to have a certain “clearance” (“gap”, “play”) between the components transmitting motion under load. Clearance is necessary to avoid interference, wear, and excessive heat generation, ensure proper lubrication, compensate for manufacturing tolerances etc.
as far as I know, if the clearance is too big, the power will be lost for eleminating the clearance it self, also reducing the gears life.
I hope that's help.
Thanks.
I hope that's help.
Thanks.
