RC Nitro Stadium Trucks Discuss all aspects of rc nitro stadium trucks here
Spur Gear Melted!
Old 04-28-2004, 07:55 AM
Default Spur Gear Melted!
I just finished installing a four shoe clutch, but the new spur that i put on with it stripped within 2 minutes. It was running fine untill i stopped to check the idle, there was some smoke and when i started to go again it stripped. Would it work to richen the high end and but a new spur, or should i order the metal spur from new era.
Old 04-28-2004, 07:56 AM
Default RE: Spur Gear Melted!
Also, has this happened to anyone else, there was also some nylon on the bell that i had to cut off?
Old 04-28-2004, 08:43 AM
My Feedback: (158)
scale only 4 me's Avatar
Sounds like when you put the new spur on the mesh was off,
that's a the most comon reason for a spur to strip.
Was it stripped just in one spot, or was it damaged all around?
Old 04-28-2004, 09:24 AM
It was only in one place, that is why i think it metled. My last one was off and the entire gear was destroyed.
Old 04-28-2004, 11:36 AM
My Feedback: (158)
Well, with the new parts, make sure the mesh is perfect and back off the slipper a little, you can always tighten it up as needed.
Both need to be set right to avoid stripping
maybe the new clutch shoes were just grabing to much
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
