rc10 gt plus
I just got it and broke it in already and it runs great... i would have gotten the rc10 gt (not the plus version... what is the difference between them anyway?) but the nearest shop didn't have it in stock so i got the plus.
I really want to make my rc10gt plus run faster but im on a budget so any suggestions
thanks
thanks
AZ
DEFINITELY, pull out the plastic cup like thing (called a carburetor restrictor) that is inside the carb. neck/hole (its white hard to miss) and you will see a SERIOUS gain in power from the AE .15. Also, I would suggest a new steering servo, such as the Hitec HS645mg from towerhobbies or wherever. I have it and a hs635,g (throttle servo) and it makes a HUGE difference.
And if you want to run faster on a track, getting the right tire for your track (the stock proline bowties will work great on blue groove like tracks) and practice, practice, and more practice, will make you faster.
Also, if you gear up or buy some Proline Masher 2000 ST tires you will gain more top-end but have less bottom-end punch. And if you decide to run gears with more teeth then the general rule is you add one tooth on the clutch bell and then get a spur gear with 2-less teeth. At first it doesnt make sense to get a spur with less teeth for a better top-speed but if you dont change the gearing you will "overgear" the engine. Which in turn will make it run hot which is not good.
Hope I helped you out!
-NitroBoy24
-NitroBoy24
PA
if u want to make ur truck faster get a mip stinger 360 exhaust, new air filter, some masher tires for grass not masher 2000's they are smaller than mashers, a 20 t clutch bell and liek a 58 t spur and u will be going good
hey thanks you guys were a huge help... about the carb restrictor i see it but have absolutely no clue how to get it out can you tell me how, and im probably going to get that mip stinger 360 exhuast
thanks for all the help
hey thanks nitro boy i pulled the restrictor off and i saw a big difference... about tires i don't go out to the dirt track much even though its like 10 minutes away i usually at a paved track around the corner of where i live and i need street tires any suggestions on what kind i should get
thanks
thanks
