RC Nitro Stadium Trucks Discuss all aspects of rc nitro stadium trucks here
Cold Starting Tip
Old 03-11-2005 | 04:16 PM
RC Prodigy's Avatar
Default Cold Starting Tip
Heres a good tip for you guys who are out in the cold. You can make starting a whole lot easier by taking an ordinary hair dryer and holding the tip straight down the engine head and onto the glowplug (without the glow starter in) for about 10-20 seconds. Then put the glow starter in and starting up your truck should be a whole lot easier, especially if you have a low heat glowplug.
Old 03-11-2005 | 05:23 PM
Default RE: Cold Starting Tip
A great tactic - rescued my r/c bash on the coldest of days! I always do the crankcase and header for a minute to.
Old 03-12-2005 | 12:09 AM
Any tips on how to do it with no hairdryer around?
Old 03-12-2005 | 12:11 AM
ahah breathe on it!
...or take in inside!
Old 03-12-2005 | 09:17 AM
E-Mo's Avatar
My Feedback: (12)
the hot exhaust from a car will also work
Old 03-12-2005 | 10:50 AM
My Feedback: (12)
also a heat gun will work
Old 03-12-2005 | 11:08 AM
RC Prodigy's Avatar
Yes, a heat gun is actually what I use. The majority of people probably do not have a heatgun lying around their house so I said Hair Dryer. I do not recommend it, but it is possible to heat the engine up to a point where you can start it without the glow starter, again, it is probably very hard on the engine so I do NOT recommend it. Another trick if you don't have a hair dryer is to take rag/towel and one of those instant heat bags that you break and they heat up real fast and cover the engine with it for a little while and then start it. If it's so cold that you can't start your engine at all, then it's prolly a bad idea to run your car in that weather, seeing as how plastic parts break much easier in cold weather
Old 03-12-2005 | 11:31 AM
Om3ga's Avatar
My Feedback: (7)
[X(] A heat gun?.. MAn that thing is hot ... the heat buildup from the gun to the motor will push fuel back to the tank. And you'll have to prime the motor again :P.
Just remeber not to prime first then lol.
