Which you prefer? Rotor Start or Pull Start?
AZ
ORIGINAL: cetme308
You need two hands for a roto start. One for the drill and the other for the radio. Maybe your just not skiled enough.
ORIGINAL: NitroRulz23
not skilled enough kitty cat man? ha! ok so what do you do if 1.) you dont have a glow plug igniter that autimaticlly stays in. and 2.) the engine wont start up and you need to choke it? sounds like a 3 hand job to me!
ORIGINAL: cetme308
1.) prime the engine
2.) turn on radio
3.) put ignitor on glowplug
4.) hold glowplug ignitor with throttle hand
5.) yank starter(or push button) while giving the truck throttle
And for future reference, choking the engine is different then priming. Choking is when you limit the air supply so the engine runs richer during start-up. Priming is when you get fuel to the carb.
AZ
ya i kinda knew that. i like to choke it instead of priming. and no, i dont want to hear your opinion on "ohh thats stupid"
Why do you need to hold on to your glow ignitor, dont it just clamp on it? I prime/choke whatever with my radio hand since it only requires a finger.
And just wondering but how exactly would you "prime" the carb?
ORIGINAL: cetme308
I prime my engine a couple different ways, I usually blow into the pressure line, although make sure to be careful when you do this as it can build up pressure and send fuel into your mouth if your tank is full enough. Or I cover the exhaust while turning over the engine.
There are a few more ways that I have heard of, but I consider these the easiest and fastest.
#31
Personally I just want to know how you go about choking it...
#33
ORIGINAL: cetme308
So, if you turn the engine over and cover the exhaust, whats that called?
The only way I can think of to choke our engine is to cover the intake, or richen the HSN(even this is not really a choke, just has the same effect). Although This will in no way help start your engine, unless your mixtures are set way too lean for your engine to run.
#34
AZ
ORIGINAL: cetme308
#35
AZ
ORIGINAL: Skullbasher
Priming..
ORIGINAL: cetme308
#36
AZ
ORIGINAL: ncgrunt
You have to prime the engine, even if you don't realize you're doing it. That is, unless you leave fuel in the car- otherwise you're going to have to get fuel from the tank to the carb.
#38
Yea, I figured that you were used to bikes, lawn mowers, mo-peds, or somthing of the sort that oftens uses chokes. But I feel that withought proper terminology being used on the forums, some people will take something the wronge way, and will eventually lead to disaster..
I too dirtbike, and if I didn't I probably wouldn't know what the hell a choke was..
