-Official Traxxas JATO Thread-
#2077
IA
RE: -Official Traxxas JATO Thread-
i think the guy that makes those is on this site. His own personal set are aluminum(spell check). found them browing one of these sites. maybe it could have been the traxxas forums as well tho. If you search he shows them installed. Ive got a spare few sets but ill deff upgrade later on.
#2078
Can someone please tell me the easiest way to remove the rear battery box so I can put on the lighter wheelie mount. I unscrew pretty much everything at the back end but cant work it out.
Also the chargeing jack on the car, do I need to somehow feed the connection through from the receiver box myself? Otherwise I have to open the receiver box to charge it.
Thanks for any help here.
Dave
Dave
#2083
My jato wont stop rolling forward. I turned the idle down so much that it stalled when the brakes where applied. I have checked the clutch pads they look the same size as new ones but are a diff color. Anyone have any ideas?
#2085
ORIGINAL: twomanytoys
Did you put them in backwards? Also is the spring the same.
And i tried my extra clutch set and it still rolls forward...
#2087
I guess i was talking about the slipper shoes before. But i just took off the clutch bell and looked at the clutch shoes and spring and they look ok. The only thing is the shoes is shaped like a oval not really a circle. Think that could be the problem?
#2091
I did have the carb off a while ago. But i have had this problem for a while to. Anyways after messing with the idle i got it so it barley moves. I had it set so the linkage was not even touching the throttle until i pulled the trigger a little to stop from the mentioned abover problem. Its just weird!
#2094
To relube the diff just take off the diff cover. Unscrew the last 2 screws on the under side of the chassis. Then there is 2 or 4 more on the diff cover. The diff cover is connected to your bumper or bat box.
I use 100k diff oil.
#2097
Correct. Did you open the actual diff or just the tranny case. The diff slides out from the tranny. You have to split the diff apart. You can use a standard shock oil to fill teh diff. The thicker you go the better the traction you will get.
#2100
PA
i greased mine up a little bit...use white lithium grease. you can get a can of it at probly any auto parts store for cheaper than the traxxas grease
