RC Nitro Stadium Trucks Discuss all aspects of rc nitro stadium trucks here
OFFICIAL HPI RUSH / EVO THREAD
Old 08-05-2005 | 05:35 PM
  #151
ThunderbirdJunkie's Avatar
Default RE: OFFICIAL HPI RUSH / EVO THREAD
ingy, hookin isn't a problem with most 1/10 stadium trucks...at least for me...my AD2 will flip over backwards downhill on dirt.
Old 08-05-2005 | 06:47 PM
  #152
hehe I'm seeing that, what tires do you use for all around dirt driving?
Old 08-05-2005 | 07:27 PM
  #153
all around i'm usually on proline bowties or step pins, but the places i run are usually pretty hard packed, or short short grass.
Old 08-05-2005 | 07:36 PM
  #154
finnally ready to run[8D]
Old 08-05-2005 | 09:05 PM
  #155
hey to all, I have owned a rush for about 6 years now. Ive read all the posts on this thread, and have some info that might help. You should upgrade the chasis to the evo if you have an original rush, it along with the new motor plate makes it alot stiffer. As far as grease in the rear diff, use Tamiya antiwear grease, its super sticky so use sparingly, this also works great to tune the diff. Aluminum arms are okay for show, but once theyre bent theyre bent. Associated spring assortment works excellent on the rush, they have a great rate selection, and are the same length as the stockers. Engines are up to the individual, also depending on what you do, I race mine, so I have to stick with th 12r ss, track rules. As far as spare parts to keep on hand, control arms, spur gear, slipper pads, clutchbells of various teeth count. On the clutch bearing you can replace with ball bearings from Tamiya, I dont know the exact size. Also upgrade the turnbuckles to titanium from lunsford, also available from HPI. I hope this helps. Engine tuning tips, if the tires spin at idle or neutral check your idle speed, if that dosent help check your clutch springs, the stock clutch springs are soft. Hard starts when the engine is hot could be due to the carb setting to lean on the high side. A temp guage will help a lot when it comes time to tune. Tires, for grass I recomend Masher series from Proline or the stock tires from the Cen Mt2 both are aproximately 5" tall, dirt / bashing either dirt hawgs or dirt works, both work for all surface driving. Glad to see that the rush is finally getting some popularity.
Old 08-05-2005 | 09:57 PM
  #156
how does the .12ss compare to the original .15?? looking to change to a .12 also and dont know what direct replacements there are besides the hpi engines
Old 08-05-2005 | 09:59 PM
  #157
nitro, hpi is replacing the original chassis for free. not news here. i've had a Rush since they came out.........
in 2001.
the 12RSS, if it's the correct one i'm thinking of, is an oily leaky blah blah blah.
hard starts when hot usually indicates a worn out piston/sleeve
and it's been a popular truck everywhere else in the world, just not here because the Losi, AE, and Mugen trucks are overall better packages for about the same price. (simply MHO, no flaming necessary)
Old 08-06-2005 | 12:09 AM
  #158
has anyone been able to bend the 2.5 mil chassis yet? i havent had it long (the chassis not the truck) and have already been through 2 2mils.
Old 08-06-2005 | 12:13 AM
  #159
Jneesy, unless you buy the engine mounts, you CAN NOT swap any engine into the rush, but it's like $8 for the engine mounts, and go ahead and buy any standard crank, pullstart, side exhaust engine will bolt right in.
Old 08-06-2005 | 07:22 PM
  #160
Its alive, jus broken the motor in. The spped was fassssssssssttttttttttttttttttttttttttt.[>:] Although i couldnt get to pop wheelies. Any help ingyn?
Old 08-06-2005 | 07:23 PM
  #161
Also bent up my tie rod(the 3rd pair) in the process. Any titanium or harder tie rod outher that would fit?
Old 08-07-2005 | 02:28 AM
  #162
tighten up the slipper clutch if you want to do wheelies.
Old 08-07-2005 | 08:54 PM
  #163
chadchm8's Avatar
I am designing my own custom aluminum rush evo wheels. Does anyone know where I can find the dimensions of the stock rush evo wheels? (I dont want to take off my newly-mounted Pro-lines)
And where does the 2.2 inch business come from? Measuring every outside dimension shows no sizes near 2.2 inches.
Old 08-08-2005 | 01:19 AM
  #164
bead size.
go measure your 1:1 car's rims. if you have 16" rims on your 1:1 car, the outside of the rim is goin to be well over 16".
Old 08-13-2005 | 04:39 PM
  #165
I picked up an old nitro rush on ebay for the hell of it for 35 bucks. Ive never been into land rc, just large boats.
Anyway, i dont know much about nitro engines, and this has the nitro star fe in it (which i realize is not the best engine) Anyuway i can't get it started. I have taken the whole thing apart, and the piston sleeve looks almost brand new and the piston itself has a little wear on one spot buit nothing horrific. There seems to be a moderate amount of compression, and the carb is getting nitro fuel and the ignitor is charged etc. Ive adjusted the carb to original factory specsa as far as i can tell.
What am i doing wrong?? I have been looking a little at new engines but was really hoping not to have to spend more money on it.
Is putting an OS Max engine in it easy, or do i have to change the clutch and evertyhing?
Thanks a lot
a
Old 08-13-2005 | 05:14 PM
  #166
avs, i wish i could find a deal like that for a parts truck, lol
as long as you have a side exhaust, rotary carb, pullstart standard crank engine and the $8 engine mounts, you can swap it into the rush.
Old 08-13-2005 | 06:06 PM
  #167
Yeah i got a decent deal on the thing, but i am still trying to get the nitro star to run, the os max i have is in another car i was planning to sell, but i dont have a lcue how to fix the15fe.
a
Old 08-14-2005 | 04:20 AM
  #168
check to make sure that the piston liner is lined up correctly; that is that the exhaust port etc corrosponds to the ports of the crank case. there should be a notch on the liner, u just have to line that up with the seam line on the crank case.
Old 08-14-2005 | 05:22 AM
  #169
hey, i see we have another thread going here [&:]
anyone got a link to that site where the guy built a .21 rush? cause ive been looking at the chassis on my beloved evo, realised theres some extra holes for the engine mounts, i figure i MIGHT be able to bolt in a pair of 21 engine mounts onto those holes (after drilling the chassis plate) and drop in a used .21 off ebay...i figure the total conversion would only set me back about £5/10, then whatever motor i can come up with, try it if it all works then go spend out on a nicer engine and realy make it fly
what'd you guys think?
Old 08-14-2005 | 10:40 AM
  #170
46u's Avatar
46u
ORIGINAL: compound_goose
Putting a big block in the rush is far from a bolt in persuader! I think New ERA makes mounts? All so get ready to replace parts often, as the big block will break a lot more parts particularly in the gearbox. If you want all out part breaking power get and OS TZ .18 that has as much HP as a lot of big blocks and with just changing the motor mounts will bolt right in. You can still use your stock parts like clutch and so on. [8D]
Old 08-15-2005 | 02:30 PM
  #171
lol, yeah itll blow bits of drivetrain every 2 seconds with a big block unit...but still a VERY cheap buget .21 is going to have a load more power than the equivilant spent on a small block? just a little thought i was having probbably end up drilling bits outa the chass to get it in, well almost certainly, how come nobodys made a bb conversion for the rush? they do one for the rs4 evo3 or whatever the HPI tourer is...?
Old 08-15-2005 | 02:34 PM
  #172
actually new era makes the whole BB swap kit, 46.
I toyed with the idea back in the day, but man, a hot .12 is more than enough.
Old 08-23-2005 | 05:51 PM
  #173
chadchm8's Avatar
Is it possible to dye the black plastic parts on the rush evo? I want to change the color for a new body. Which brings me to another question:
Will any of these [link=http://www.customworksrc.com/products_bodies.html#]custom works[/link] bodies fit a rush evo:
9017, 9010, 9004
Old 08-25-2005 | 08:31 PM
  #174
Nitrus rush's Avatar
Hey compound_goose, I put a bunch of pics of my .21 rush on the other evo thread. My website is http://nitrusrush.tripod.com. It's outdated but it still has a lot of necessary info. If you have any questions on a .21 swap email me at [email protected] or AIM at Jax100386. I'll be glad to help you out.
Old 08-25-2005 | 10:31 PM
  #175
46u's Avatar
46u
ORIGINAL: nitromouse
If all they did is bend and not get any thing else you are lucky. Been throw the alloy thing. I have had my Rush for 4 years. [&:]
