what tires should i use
i have a rc 10 gt with a rosi r12 pixy engine. i reace mostly on gravel and dirt. i cant seeem to get any traction. what kind of tires should i buy?
SC
RE: what tires should i use
Well with the amount of power your engine has it sounds like you just need to control your throttle better, but it might be you spur gear i would play with the adjustment on it.
CA
Go 2 degrees negative camber all the way around first of all.. for handeling.
Then go with gladiators in the rear, and either edge's or another set of gladiators in the front (yeah it sounds weird on a 2wd truck but i saw people at the track doing it with excellent results). Every track is different.. you might find step pins to work better, or another tire, but in my experience gladiators work well.
If your just purely bashing, i recommend getting Masher 2000's all the way around. That'l give you some grip in gravel too... well more than you had before.
Get this tires are great, not too small not too big or heavy like masher2000, perfect for all terrain, I love this tires...
[link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXUM92&P=ML]http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXUM92&P=ML[/link]
or this ones...
[link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXDU11&P=ML]http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXDU11&P=ML[/link]
seeeyaaaaa!!!!!!!!!!!!
or this ones...
