cooling head keeps coming off!! and the engine gets to hot!!!
WA
HELLP!!! my 2.5's cooling head keeps coming off and the engine keeps geting hot and i dont know what to do can anybody help please!!!
CA
RE: cooling head keeps coming off!! and the engine gets to hot!!!
Your cooling head keeps coming off??!? Go out and buy some blue thread-lock, then put a little drop on each screw that goes into the head. Then torque the head down in sequence, and wait for the thread-lock to dry before running it.
Well if your cooling head gets a little loose, you will start to get an air leak. Thus your engine would start to run very lean and overheat.
Hope that solves the problem... Although I have never heard of a cooling head just randomly falling off before..
WA
well the dang thing did not come with screws and now i cant find the head any where!!
MD
ORIGINAL: revokid
FL
ORIGINAL: ICrashThings
Uhmmmm wow i have never in my life heard that...lol...how do u think the head stays on the engine? magic?
ORIGINAL: revokid
omg you just made my day thank you
FL
ORIGINAL: Bgrassguitar
Funniest one I've ever read! Although, if it's for real, it is kind of sad in a way...
this thread is b/s
ORIGINAL: revokid
HAHAHAHAHHAAAAAA LMGDFAO!!!!!
wait...what? the head is meant to be held on with screws????? I thought that was what duct tape was for...
lol jk
CA
Or does he mean the little plastic head protector? those tend to come off alot. And then the overheating could be another problem...
PA
I use a combination of double-sided sticky tape and velcro to hold the head on my trx 2.5. I've also heard that you can use static electricity if your in a bind and don't have double sided tape or velcro. Just take the cooling head off and rub it vigorously on top of your head (or if you have a dog or cat available just rub it on their back). Then set it on top of the engine gently without grounding yourself out, then the static charge will hold it on the engine much like you use static to make balloons stick to walls. Another alternative is chewing gum (my perosnal favorite is BigRed)
CA
ORIGINAL: tommythecat
AHAHAHAH we cut him up now he doesnt even wanna say anything back and if your COOLING HEAD keeps comin off try screwing it on ifu dont have screws buy them from your lhs if cant find the head buy a new cooling head and screws lol and if your only talkin about that little HEAD PROTECTOR on your cooling head just get tie rapps and rapp them around the head and your cooling fin
WI
lmao POP!!! AHHHHHJHHHH LNKSGLNSFKLSF;K
ORIGINAL: losi xxx-ntkid
i dont think it is becuse the first time he starts the truck the head would come off becuse of the compression there would be no way that the engine could even get hot
this thread is b/s
this thread is b/s
