Nitro Evader ST Hop-ups?
AB, CANADA
I was wondering, other than the body parts being changed to metal, aluminum or titanium, what Hop-ups can be purchased for this truck. Any kind of tuned tail pipe fit? Im sure that some of you guys have tried to fit many different kinds of Bodies, pipes...and so on, I so far have only purchased different types of tires and Rims. Just curious what other have experimented with and if it was a possitive outcome or negative.
SC
RE: Nitro Evader ST Hop-ups?
Here you go http://www2.towerhobbies.com/cgi-bin...I=DTXD62**&P=Z
i can sell you a hand made aluminum front shock tower for it if you want i will make you a good deal just pm me if your interested.
AB, CANADA
BUMP....
I assume that most any staduim truck Body will fit on most any Staduim truck, with a few minor adjustments. Such as making a new Hole for antena, new holes for the body mounts, as well as possibly cutting a hole for Cold air to get into cool the engine...Correct me if im wrong please.
SC
*edit* here is a direct link http://www.dynotech-racing.com/partsList.php?carID=9
AB, CANADA
So now I am going to sound even more like a Noob, what would that clutch bell do for you? Where would you get the Gears to go with that? How many teeth would be an upgrade? Would you have to get different clutch shoes? or would the ones that came with the truck work? Im asuming that part would just slip right on where the old one was.
AB, CANADA
ok, I found the Pinion Gears and the New TC3 clutch bell, However the stock clutch bell is 15 tooth and the smallest Pinion gear is 20 teeth..Would 20 teeth be faster or more power? And could it work at all?
AB, CANADA
Ok, after much Debate....lol... We agree here at my work.Not to say I thought you were wrong. I will post my results with what number of teeth I will use.
ORIGINAL: D0G
