Official Nitro Evader ST Thread v2.0
#5776
ON, CANADA
RE: Official Nitro Evader ST Thread v2.0
I have dirthawgs on my rear and I hate them....almost zero grip on most surfaces...they do hook a little on the grass but pavement/concrete or dirt they just break loose.....even when the truck squats these tires are awfull.....they are wearing very slowly thats the only plus to them
#5777
WA
#5778
FL
from what i've seen and experianced such as when i was at the beach, the dirthawgs LOVE a semi packed surface with a good covering of loose stuff, like where the tide comes in and packs the sand tight but is still loose enough for the nubs to catch onto, and yes pavement they blow ass unless you loosten your slipper some, but they turn nice when on the front =D
#5779
OH
ORIGINAL: docphysics
this one will work:
http://www2.towerhobbies.com/cgi-bin...&I=LXMRE6&P=ML
and if you lost your crystal, then you need these:
http://www2.towerhobbies.com/cgi-bin...=LXH28283&P=ML
this one will work:
#5780
FL
just flush the HSN and the LSN and work from there working them in slowly till it starts rich then tune it again if it's already broken in
#5781
ON, CANADA
go to the OS website and the factory needle settings are there.....did you leave fuel in it while it sat???did you after run it before it sat??if you answered yes to the first and no to the 2nd Q's then you likely have some rust in the engine...in which case pull it aprt and inspect it clean it all out with a good parts cleaner reassemble and try again..
#5782
IA
Ok fellas, I finished the rebuild! Now she goes to the auction block. [&o] Polished chassis, polished pipe, polished aluminum tranny brace, lightened vented slipper, Mach .15, aluminum front bulkhead, all aluminum tranny gears, and new parts! Lemme know what you think?
#5784
PA
Hey, nice job. Are you planning on putting it on marketplace in RCU. If so I will keep an eye on the auction, curious to see what you get for it. Love the body!
#5785
IA
No, I actually kinda have it sold. I am trading it for a sportmaxx and he is selling it on e-bay for the money towards the truck. Thanks for the responces and the body is the old sportmaxx body I made it fit.
#5788
keep rubbing away at that pipe, its not shiny enough hehe. I gotto get mine more shiny, its still not good enough. Mothers alloy mag polish works wonders
The truck should have a OS18cvrx, alloy gears, street rims and tyres and body in a month or so, havnt ran it for about 6 months, as the motor is fried, so i spend time making it look better LOL
#5789
IA
Looking great!!! I would have spent more time on it but I am not keeping it, ya know. I will stick around this tread tho. I have learned alot and might be able to help others. I also will post a pic of the maxx when I get it. It looks like ***** but runs great!
#5791
You could still drive but be carefull on the throttle Just tighten the nut as tight as you can and go to town
#5792
You know what I noticed?, almost every time I post it is the first one on a new page. Weird, I always seem to get the first post
#5794
FL
yeh, i took it apart today and it looks like im gonna end up having to replace everything =( oh well guess it's a good exuse to send an order out to tower =3 i never did get any feed back on my homebrew shock oil o.o
#5796
FL
i used a mix of napa multi purpose grease in the blue tub and some 30weight motor oil, to make it take a good blob of the grease and put it in something you can mix it into and start adding the 30w oil and mix it till it's just becomming smooth enough to run like syrup, it works really well o.O thin enough to not be hard but thick enough to dampen bumps and body roll when your really pushing it =)
when you get it right it looks something like that black rubber road tar the pour into cracks in a highway
#5797
OH
Are you sure thats not too thick? And wouldn't it be cheaper to just buy a 2oz bottle of shock oil. But i guess if you have some grease and engine oil laying around and it works for you than go for it.
#5798
FL
well that's the nice part, you can thin it out using more motor oil if you want it thinner, but what self respecting gear head or anyone with a full size car doesn't have a lil oil n grease stashed away in there garage?
#5799
the motor oil will degrade the O rings in the shocks the o rings aren't designed to go with petroleum products. they'll end up going hard & leeking. i'd stick with the silicon oil if you can.
just my 2 cents.
just my 2 cents.
#5800
ON, CANADA
theres corners you can cut and the there corners you can't....shock oil is for shocks...motor oil is for motors....
